what happens when too much oil is added? - BMW M5 Forum and M6 Forums
Old 17th April 2009, 01:07   #1
typer142
Garage: e60 m5
i just had an oil change at the dealership and now it says too much oil. the car now stutters when i blip the throttle to 2000 rpm! the service tech insists its normal even though i tell him i didn't feel this ever before! he empties some oil, but it still stutters the same way. do you know what is actually damaged when there is too much oil so i can tell this idiot mechanic what to look for?!
also there is a new noise (soft hum) when at idle ever since this happened. any idea what it could be?
the car is back at the dealership and i wanted some advice from this great forum because i really dont trust this dealership after this incident.
thanks in advance!
typer142 is offline   Reply With Quote
Old 17th April 2009, 01:10   #2
FogPuppy
Garage: 2010 M6 Carbon Black
How much too much? 1.2 or 1.3 will not be an issue. Much over that IS a problem per the BMW manual.
FogPuppy is offline   Reply With Quote
Old 17th April 2009, 01:28   #3
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
Need more info...any messages?? How much over?? Like Foggy said....give us the lo-down,,,.....
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
Old 17th April 2009, 01:39   #4
typer142
Garage: e60 m5
it said 1.3 then when he emptied some oil it now says 1. i really want to know what the stuttering is when i blip the throttle no more than 2000 rpm. it feels smooth when driving besides that. no engine lights on right now. all services say ok. engine oil says ok.
Old 17th April 2009, 03:23   #5
handdoc
handdoc's Avatar
Garage: 2008 M5 Saphire Black
dealers suck
handdoc
handdoc is offline   Reply With Quote
Old 19th April 2009, 04:34   #6
typer142
Garage: e60 m5
the car feels slightly worse now, its getting rough at around 3000 rpm. the dealership mechanic told me its not the engine because he had one tech rev the car while his hand was on the intake manifold and he didn't feel any vibrations. its really worrying me now. any ideas what it could be???
Old 19th April 2009, 05:21   #7
unfoundhorsepower
did you take a tech for a ride??? you must show them what your experiencing...is it under a load when it vibrates???is it a misfire??? misfires usually happen under a load....you drive them....
Old 19th April 2009, 05:42   #8
jbracefan1977
Garage: BMW Black
dealers really suck. so did you find out whats wrong? what's the update so far?
jbracefan1977 is offline   Reply With Quote
Old 19th April 2009, 06:42   #9
Glock 32
Glock 32's Avatar
Garage: Sapphire Black 2008 M5
It has been an hour since his posts, do you really think he has any update?
OP You said it drives fine. 1.3 oil shouldn't off hurt anything.
If you are like me, perhaps you are listening too closely as a result of this experience. If there is anything major, you will get a light on the dash, limp mode, etc.
A short blip below 2,000 with no load will not be smooth.
Drive it until you get a real symptom or a light or symptom gets worse and try to put the experience out of your mind, it should be o.k....
Glock 32 is offline   Reply With Quote
Old 19th April 2009, 08:25   #10
typer142
Garage: e60 m5
it only vibrates when i rev it, and not when actually driving/engaged in first gear- it's a six speed. the tech says he's felt the same thing on other m5's and m6's however they were not as rough as mine. the reason i'm worried is because it never happened before the oil change was performed. anyway, i may visit another dealership and provide updates...
Added Options = Added Weight, But How Much? Pio E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 24th November 2007 07:50
added some new mods to the M5. ellinopedo182 E39 M5 and E52 Z8 Discussion 12 29th June 2007 00:42
New M6 pictures added M-bitious Owners Gallery 5 8th January 2007 11:21
added extras shuggy47 E34 M5 Discussion 1 18th May 2005 17:08
E60 added to BMW USA Site Bokke E60 M5 and E61 M5 Touring Discussion 13 12th September 2003 19:44
