Old 9th March 2009, 16:41   #1
Ryanmcd
Garage: 2006 M5 Silver
Tracking the M5
Well I have my 1st track day next weekend and had this car about a week. Anything I need to do to get it ready for the track? I have 3L of oil so far
Ryanmcd is offline
Old 9th March 2009, 16:51   #2
floridaBMW
floridaBMW's Avatar
Garage: 2008 M5 Space Gray/Indie Red Interior
If the brake fluid hasn't been changed recently, have it done.
2008 M5/SMG
floridaBMW is offline
Old 9th March 2009, 17:19   #3
NB
NB's Avatar
Garage: M5, Sepia Metallic
Is this your first trackday?
If so, the most important thing is to enjoy yourself, don't overdrive and if it is availble, take some tuition. I still go out with the instructors, it is good to get any tips etc.
Most important thing and you must not forget. Take some pics and post them here
_____________________________
E60 M5 in Sepia Metallic with Amarone/Amarone
NB is offline
The Following User Says Thank You to NB For This Useful Post:
Gustav (10th March 2009)
Old 9th March 2009, 17:28   #4
Ryanmcd
I have done track days for years just not anything with 500hp and 4000 pounds I was thinking using DSC until I get a feel for the car more and maybe a few track days like that and just run S5 mode
Ryanmcd is offline
Old 9th March 2009, 18:35   #5
NB
NB's Avatar
Good thing with the M5 is that you have a choice with the traction
traction on
MDM
traction off
I personally use MDM the first few laps of the day then take it off, but it will allow you to experiment a little.
The main problem is the weight. This will cause the outside edge of the outside front tyre to wear prematurely. You can help to reduce this, the M5 does allow you to change the camber, there is a small pin in the top of the front strut mounts, if you remove this, it will allow the top of the strut to move towards the engine and hence increase the negative camber. If you take it to a good tyre shop they should be able to do it.
I still remember my first trackday in the M5, the only main issue I had was tyre wear, but the track surface I was on was rought concrete.
You may just want to take the car in stock set-up first though, as it will allow you to make the changes that you want, every driver / track is different etc.
The most cost effective brake upgrade would be to change the fluid to Motul RBF600.
NB is offline
Old 9th March 2009, 18:41   #6
r tuned
Garage: E60 M5
I totally agree with you. First start with MDM as DSC ON will affect the car performance and you will end up with alot less power than you expect.
Also, tires will wear from the outside really quick just like NB have mentioned.
wish you good luck.
r tuned is offline
Old 9th March 2009, 18:45   #7
aminaa76
aminaa76's Avatar
Garage: 2008 BMW M5 6 Speed, Sapphire Black
Ryan,
Im getting ready for track season but still have several weeks to go. I tracked the M5 last year for the first time. Mainly, I had issues with the brakes and fading.
This year, I plan to run ATE superblue, add stainless lines, and am possibly adding the PAGID pads that are used on the N-Ring Taxi. The pads are pretty pricey but short of doing a big brake kit, I think will be worth it. Would love to hear how it goes and snap some pics!!!
_________________
Current Ride:
08 BMW M5 Six Speed, Sapphire Black
Mods: Rogue Engineering Diablo Section 3 Exhaust I Evosport Section 2 x-pipe (no resonator)
Past Rides:
07 Porsche 911 Targa 4S
07 MB SL 55 AMG
06 Range Rover Supercharged
06 Range Rover Sport HSE
02 BMW 540i
aminaa76 is offline
Old 9th March 2009, 18:58   #8
NB
NB's Avatar
Originally Posted by aminaa76 View Post
Ryan,
Is the ATE superblue road legal? I'm not 100% sure, but I seem to remember they did another version that definately was.
Other fluids are the castrol SRF brake fluid and the Motul RBF 600.
NB is offline
Old 10th March 2009, 03:57   #9
aminaa76
aminaa76's Avatar
Im not sure if the ATE superblue is road legal. Ill find out from my mechanic to see if he recommends it for street use or if I have to bleed it when im off the track.
aminaa76 is offline
Old 10th March 2009, 15:32   #10
grizzy
Garage: m5, 911
Send a message via AIM to grizzy
After doing the BMW M performance school- I would not take off DSC at all. Leave in MDM mode. Unless you are 95%+ sure of where the car will go and can control understeer/oversteer at speed and have practiced on open track/road -DO NOT TURN IT OFF.
Its just not worth it- Can you go faster? maybe a little - Is this a race with a cash prize-NO So its not worth the chance of wrecking 100k
Just my 2 cents after driving M3/M5/M6 with DSC on and off on a track with instructors
08 m5 SG/Blk Olive ash every option
04 911--40th anniversary
grizzy is offline
Page generated in 0.14341 seconds with 10 queries
