2008 Dinan Stroker M5 versus 2009 Cadillac CTS-V - Page 7 - BMW M5 Forum and M6 Forums
Old 3rd March 2009, 05:15   #61
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Originally Posted by georgefu View Post
Thanks Darren, when can you arrange a run with an LP560?
George,
I'll see what I can do. I'll contact a few people I know and try to make it happen. That LP560 is a monster though!
Darren
2011 X5M Carbon Black
darren_dallas is offline   Reply With Quote
Old 3rd March 2009, 05:49   #62
NobleM400
Company Representative of RPI Power
NobleM400's Avatar
Garage: 06 BMW M5 Silver Gray Metallic
Originally Posted by darren_dallas View Post
Yes sir, they use the same correction factor for all of our dynos.
Definitely interesting numbers, great data point to consider when only a tiny fan is used.
Originally Posted by Fubar View Post
Gentlemen, I am the owner of the CTS-V in the aforementioned video. I should mention that the race laid out here was my first attempt at launching the V and it was pathetic. I have never tried to race an automatic before and still have much to learn. If I had know Darren intended to post this video on the internet I would have requested a few practice runs to get a feel for it. However, Darren's car is undoubtedly faster... as it should be. And as Daren stated, the main reason we made the runs, revolve around Dyno airflow and the effect on NA cars v/s FI cars.
Please be gentle on my little Cadillac, she is new (only 1500 miles) and I am still learning. I suspect I lost a 20-30 feet waiting for the transmission to downshift after the 3rd honk. The $40k stroker package certainly out pulled my stock CTS even after we got rolling. I suspect he put another 30 feet on me as we traveled down that mexican highway.
I hope Darren will give me another shot in a week or so. I will be better prepared for the launch. Although I don't expect to win, I do hope to be a more formidable opponent.
Thanks for the info and for running. It's always great to get some good info on how other makes/manufacturers do with respect to dynos & runs.
Originally Posted by tranman329 View Post
I was there that day with my 06 M5 with charcoal delete, rpi scoop, bmc filters, and rpi pulley and was putting down 418 whp. I believe mine was right before darrens.
Surprisingly big numbers considering the setup.
Gabe
Race Precision, Inc
NobleM400 is offline   Reply With Quote
Old 3rd March 2009, 07:10   #63
hp99hp
Garage: E46 m3
Sales Feedback: (3)
I did 419 with a similar setup on a much hotter day in the summer. Its about right for Classic's dyno.
hp99hp is offline   Reply With Quote
Old 3rd March 2009, 09:07   #64
Revo
Revo's Avatar
Garage: 2006 E60 M5 Black on Black
Excellent win Darren. That Dinan V10 is really something.
I'll have to agree with the statement that dyno numbers do not represent the real world. This is especially true when only peak figures are generally discussed.
Overall power output across the usable RPM range (when drag racing - whatever the engine operates in most - probably 6000 to 8250 for our S85's), gearing, and airflow to the motor all play a huge part in the acceleration of a car.
I can say with confidence that our mighty V10's will lose significant power without air being actively flowed in. Even though the design of our air intakes are not true ram air, they must contribute somewhat to providing a decent amount of airflow to the engine once the car is moving.
Revo is online now   Reply With Quote
Old 3rd March 2009, 12:00   #65
M V10
M V10's Avatar
Garage: M5 E60 Silverstone II
It was said by BMW that the S85 V10 needs TWICE as much air then S62 V8 engine from the M5 E39 does, that´s a big difference!
M V10 is offline   Reply With Quote
Old 3rd March 2009, 13:02   #66
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
Airflow Requirements - S85 v S62
I'd be interested in learning the source of that information, 'cause intuitively it doesn't make sense to me. For the purposes of a 'quick and dirty' analysis, consider consider each motor to be the equivalent of a 5 liter positive displacement air pump. The delta in airflow pumping capacity would then be the difference in the volume of air moved at the 8200 rpm red line of the S85 and the 7200 rpm red line of the S62. That works out to about 14% if I've done the math correctly
2003 Jet Black lllM5 Dinan S3 #24
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, Speedhut Custom Boost Gauge, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Ground Control Coil-Over Suspension, 430 7" F & 325 10" R, Dinan/Brembo Brakes, Zionesville Radiator, Spal 2-speed Electric Fan, AGA Power Steering Reservoir, Rennline Pedal Set w/ throttle heel/toe ext, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Sub-frame Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Drags: Nitto NT-555R Drag Radials 285/35R-18; Street: Michelin Pilot Sport PS2 275/35ZR-18; Laser Interceptor, Dual Head, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, BSW Speakers with iPod integration, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder. Coming: Howerton Engineering Methanol/Water Injection, Schmiedmann EVO CF Hood.
1/4 mile: 11.795 @122.20 mph, 60' - 1.819 03/11/2008 ATCO
Kelster is offline   Reply With Quote
The Following User Says Thank You to Kelster For This Useful Post:
M5Ranger (3rd March 2009)
Old 3rd March 2009, 14:27   #67
M V10
M V10's Avatar
I did read that statement in a swedish carmagazine, I´ll see if I can get some info about that in english, if so, I will post it.
Old 3rd March 2009, 15:15   #68
M5Ranger
M5Ranger's Avatar
Garage: 2006 M5 Alpine White / 2006 M5 Saphire Black
Forget the Lambo LP560, run a C6 Z06. The vette would be easier to find. This would be NA vs. NA motors. Maybe a ZR1 to up the ante and run a FI motor.
Ranger
2006 M5 Alpine White/Silverstone : car and project are dead. RIP
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
FORGED IN A FIRE LIT LONG AGO, STAND NEXT TO ME, YOU'LL NEVER STAND ALONE. FIRST IN, LAST OUT.
YOU DON'T ALWAYS KNOW WHERE YOU STAND, TILL YOU KNOW THAT YOU WON'T RUN AWAY.
YOU HAVE ENEMIES? GOOD. THAT MEANS YOU'VE STOOD UP FOR SOMETHING, SOMETIME IN YOUR LIFE.
W. CHURCHILL
SOCIALISM IS A PHILOSOPHY OF FAILURE, THE CREED OF IGNORANCE, AND THE GOSPEL OF ENVY, ITS INHERENT VIRTUE IS THE EQUAL SHARING OF MISERY. W.CHURCHILL
A wise and frugal gov't, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good gov't. Thomas Jefferson ...
M5Ranger is offline   Reply With Quote
Old 3rd March 2009, 15:40   #69
hp99hp
Garage: E46 m3
Sales Feedback: (3)
Ranger
i do believe there is a video vs a Z51 with full bolt ons. This car eats up Z06's.
Old 3rd March 2009, 16:32   #70
BlackSheepC6
Garage: 08 Machine Silver Z51 Corvette
Ranger
This is Darren's car against my 08 Corvette with a cam and long tube headers.. It is the base car with the Z51 performance package..
Z-51 vs M5 - DFW Auto Club Forums
BlackSheepC6 is offline   Reply With Quote
The Following User Says Thank You to BlackSheepC6 For This Useful Post:
hp99hp (3rd March 2009)
