2008 Dinan Stroker M5 versus 2009 Cadillac CTS-V - Page 4 - BMW M5 Forum and M6 Forums
Old 2nd March 2009, 13:44   #31
cshorter
cshorter's Avatar
Garage: 2007 Silverstone M5
What is the "approximate" price on the stroker upgrade?
2007 M5 Silverstone
6-Speed, with some options and what-not...
1977 Black/Black Corvette
cshorter is offline   Reply With Quote
Old 2nd March 2009, 14:40   #32
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Originally Posted by v8venom View Post
like m5ranger, i too am confused... i understand that proper airflow for the dinan stroker will provide more power, but how come the numbers are so much lower than what had been documented with simple bolt-ons like rabdog's RPI setup? darren... did you guys not have a fan that could give 50mph+ airflow?
again i know numbers don't necessarily translate to real world results but they do give a relative performance picture.
the next obvious question is how much difference is there between RPI bolt-on's vs dinan stroker on the dyno in identical conditions? i recall watching kenny stare down darren's brake lights in a very dark video?
V8Venom,
They had a carpet fan on the oil cooler (it's basically a small shop fan meant for drying up water if there is leak in a house or building).
Basically what it boils down to is that you cannot paper race dynos, especially dynos from different locations/states even if they are the same manufacturer.
I did not run against Rab Dog, but I have run against Keang24 who has the same setup from RPI. Keang24 has run against Rab Dog many times and they even filmed some of the runs in December. Here is a video of Rab Dog and Keang24 going at it. Pay attention to Run #2 and the last run (45-165) and you'll see the cars are almost perfectly even each time:
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
Given those results I suspect if Rab Dog and I run the results will be the same as the times I ran Keang24 here:
+ YouTube Video
Hope this helps.
Darren
2011 X5M Carbon Black
darren_dallas is offline   Reply With Quote
The Following User Says Thank You to darren_dallas For This Useful Post:
M V10 (2nd March 2009)
Old 2nd March 2009, 15:05   #33
V12Godspeed
V12Godspeed's Avatar
Garage: Black CL65-The widow Maker
Nice Kill Darren. Your car is one of my favorite M's. Love the Dinan stroker kit!
04- EV12- The White Bison
Low Boost- http://www.youtube.com/watch?v=E4_HrxXtSBU
05- CL65- "The Black Bison"- SOLD
VRP 825 - (10.72 @128) 2nd Fastest CL65 in the US
http://www.youtube.com/watch?v=caoztJbtaZA
"Capo Regime (North)"
V12Godspeed is offline   Reply With Quote
The Following User Says Thank You to V12Godspeed For This Useful Post:
darren_dallas (2nd March 2009)
Old 2nd March 2009, 16:16   #34
Kelster
Kelster's Avatar
Garage: 2003 M5 S3 #24 Jet Black/Volleder Napa Heritage Schwarz
Sales Feedback: (4)
Umm...
Originally Posted by darren_dallas View Post
Forced Induction cars (Ford GT, CTS-V, etc.) are not impacted really on the dyno and show proper figures since the supercharger is forcing more air in regardless if the car is moving or not.
Sorry Darren, this could explain what happened in your tests but unfortunately this is incorrect. Forced induction cars are even more adversely impacted by the lack of airflow on the dyno. I've had first hand experience with the 'running out of air' phenomena on the ICS dyno with my E39 M5-S3.
Steve Dinan has written about this in his paper "Dynamometer Testing and the Modern BMW Engine" excerpted below:
A lack of air-flow during dyno testing will almost always alter the fuel mixture in the rich direction as the radiator cannot exchange enough heat, resulting in the computer compensating by retarding timing and richening the fuel mixture to prevent the engine from overheating and detonating. In addition, the intake air sensor will read substantially higher temperatures than that seen on the road with proper airflow. This issue is particularly important to address when testing high output cars like the M5 or M3, and even more so on forced induction cars with intercoolers as the heat exchanger is not able to cool as efficiently because of the reduced air flow. [EMPHASIS ADDED] The engine compartment is normally flushed with air driving down the road, particularly at speed, cooling the manifolds and other associated engine components. Cooler engine components and lower air intake temperatures will result in a leaner air/fuel mixture and ignition timing will be advanced, invariably resulting in greater power on the road than on the dyno. In simpler terms, accurate measurements can only be achieved when the dyno tests are conducted in a manner that simulates the car driving down the road, in as much as is possible.
Ray
2003 Jet Black lllM5 Dinan S3 #24
621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2-T Intercooled Supercharger, Speedhut Custom Boost Gauge, S3 Oil Cooler, S3 Engine Management Software, OKD Plasma Direct Ignition Coils and Plasma Spark Boots, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Modified Cats & Free Flow Exhaust, BMW 545 Short Shift Kit, Ground Control Coil-Over Suspension, 430 7" F & 325 10" R, Dinan/Brembo Brakes, Zionesville Radiator, Spal 2-speed Electric Fan, AGA Power Steering Reservoir, Rennline Pedal Set w/ throttle heel/toe ext, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Sub-frame Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, Track: Toyo Proxes RA1 275/35R-18; Drags: Nitto NT-555R Drag Radials 285/35R-18; Street: Michelin Pilot Sport PS2 275/35ZR-18; Laser Interceptor, Dual Head, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v31 Custom 'Beast' screen & Navtech 2009.1 DVD Map, BSW Speakers with iPod integration, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder. Coming: Howerton Engineering Methanol/Water Injection, Schmiedmann EVO CF Hood.
1/4 mile: 11.795 @122.20 mph, 60' - 1.819 03/11/2008 ATCO
Kelster is offline   Reply With Quote
The Following User Says Thank You to Kelster For This Useful Post:
wilsodh (2nd March 2009)
Old 2nd March 2009, 16:19   #35
CASEY1
CASEY1's Avatar
Garage: 2006 M5 INTERLAGOS BLUE
I wonder what the total cost of the M5 is. Can buy new CTS-V's for 60k. Many mods are available for it already.
CASEY1 is offline   Reply With Quote
Old 2nd March 2009, 16:33   #36
darren_dallas
Ray
Ray,
I understand what you're saying. It really boils down to simple math:
CTS-V rwhp on Saturday = 456 rwhp
CTS-V advertised crank hp = 556
If you do the math it works out to roughly 18% drivetrain loss, which is in-line for an automatic transmission.
So in this case I believe the numbers make sense are accurate for the CTS-V.
Hope this helps.
Cheers,
Darren
Old 2nd March 2009, 16:35   #37
Qship5
Qship5's Avatar
Garage: 2003 M5 Carbon Black, 2009 C63 AMG Black
Sales Feedback: (3)
Nice run Darren! I'm sure Fubar will be looking for a rematch soon. At least once he dumps a few $ into mods. The V is no slouch in stock form and I would venture to say that with less than $10K in mods will be putting down more power than the stroker.
Qship5 is offline   Reply With Quote
Old 2nd March 2009, 16:35   #38
darren_dallas
It's always been well known that you can mod most of the american cars much more economically than the european cars.
My friend in the CTS-V will no doubt slap on a pulley and an ecu tune and come back with a vengence and stand a good chance of beating me next time.
Old 2nd March 2009, 16:36   #39
Leonie
Garage: Corvette C5 MN6, black on black
I guess the price of the stroker kit (including labour) alone is about the same as a brand new CTS-V??
So I won´t say "great kill" but "obvious kill"...
Best, Bernd
Edit: I see you already made a reply yourself...
Leonie is offline   Reply With Quote
Old 2nd March 2009, 16:39   #40
Tom C
Tom C's Avatar
Garage: '02 M5 LMB (gone), '13 M5, '12 RR Evoque
Regardless of Darren's dyno results...I would rather have a car that performs in real world conditions than a "dyno queen". I think Darren's car has proven its mettle.
Tom
Tom C is online now   Reply With Quote
The Following 3 Users Say Thank You to Tom C For This Useful Post:
darren_dallas (2nd March 2009), Gustav (8th March 2009), Kelster (2nd March 2009)
