2nd March 2009, 13:22
#30
Not only did Kenny stare at his brake lights, he got walked pretty hard and it would have been the same result with RabDog's car. The point is...
Obviously the dyno tells only a small piece of the story. If you go by dyno performance here, same hp, same weight, 100+ lb. more tq to the Caddy, then Darren should have been anihilated. But it wasn't even close. It was an immediate run, not walk, away from the Caddy and once again the 997TT.
Great job, D! Way to rep for the stroker crew. I think Fubar might want a rematch in his other blown domestic vehicle. The outcome might be a little different! lol
Originally Posted by v8venom
like m5ranger, i too am confused... i understand that proper airflow for the dinan stroker will provide more power, but how come the numbers are so much lower than what had been documented with simple bolt-ons like rabdog's RPI setup? darren... did you guys not have a fan that could give 50mph+ airflow?
again i know numbers don't necessarily translate to real world results but they do give a relative performance picture.
the next obvious question is how much difference is there between RPI bolt-on's vs dinan stroker on the dyno in identical conditions? i recall watching kenny stare down darren's brake lights in a very dark video?
SBM6
'08 S3 M6 AW/B/CF
