Exterior: Vorsteiner CF Vented Hood, RH Type CF Splitter, Upper CF Mirrors, CF Side Skirts, CF AC Schnitzer Style Trunk Spoilers, CF Side & Kidney Grills, Black Powder Coated Lower RaceMesh Grille, CF Pillars, all Roundels in CF, Red Angel Eyes, OEM Smoked Tail Lights, Smoked Side Markers, Brake Calipers Painted in Red with CF ///M Decal
great results..And love the looks of this particular Supra...Hate most of the others dressed up like the one Hulk Hogans kid had ( crashed )
Is the lag in the turbo large? I can imagine its not that easy to drive at low revs?
Wout
__________________ ///M5HD91-229- |Eibach|Koni|Porsche Brembo for looking through the windscreen ///M535iDC71-181-
|H&R|Bilstein|Sparco for looking through the Lexan side windows
B6 3.5 1531-668-
|Dogleg|Glanzschwarz for fun C1 2.5 1531-184-
|D-1 cage|full race spec for looking at chequered flags
his engine is bored and stroked to a 3.4 so I would think down low would be fairly decent...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
