i just got a set of 20" hamann edition race wheels for my car which is lowered on rdsport springs. i dont know what the best tire set up would be. anyone know if i can fit 255/30ZR20 fronts and 305/25ZR20 rears or if the rears will be too big? will they rub? is the sidewall too small? any advice or experience is appreciated
this is the third set. these are keepers though. i love these wheels. cant wait to put them on. just want to make sure on the wheels size. EuroCarFan, what size are your rear tires?
Loyola M5 how wide are your rears? If they are 10.5" or 11" you will be fine with the 305 tire.
I have the HRE P40's, fronts 20x9 and rears 20x10.5" and I have mounted 275/30 and 305/25.
They fit perfect and there is absolutely no rubbing.
The 255/30 you got actually gives you the exact same rolling diameter as the 305/25, so probably better.
Mind you the offsets have to be exactly on the money. I know HRE has this down perfect. The offsets are perfect, NO SPACERS.
I assume that Hamaan has this down also.
BTW those wheels you bought are awesome. As I recall they also had a staggering price .
You should be okay but my only uncertainty are the wheel width and wheel offset.
For reference HRE typically uses something like a 20x9 +9 front and 20x10.5 +28 rear.
125.8K members
