Old 28th November 2008, 02:19   #11
BMWNTHZST
BMWNTHZST's Avatar
Garage: E60 M5 - Black Sapphire Metallic
Sales Feedback: (7)
Originally Posted by cerb View Post
believe me ... it's the rear wheels
\cerb (still braking in ... can't wait to step on it)
On your advise, I'm going to get the rear tires balanced tomorrow morning.
I will update all tomorrow.
BMWNTHZST is offline
Old 28th November 2008, 10:42   #12
///M Lifestyle
///M Lifestyle's Avatar
Garage: M6
pretty sure it is the hub centric rings as unfound has already mentioned...i had this problem with a set of Maya's I had on my car, after hub centric rings were installed all was back to normal again, just make sure you get the right size
///M Lifestyle is offline
Old 28th November 2008, 11:02   #13
CHRISBURNS
CHRISBURNS's Avatar
Garage: 08 M3 V8 ALPINE WHITE
See these rings you are all talking about, we usually throw them away over here for any car.
As I said earlier if you tighten up the wheel correctly there is no need for them. All they do is cause hassle.
PAST - E60 SILVERSTONE M5 GONE BUT NOT FORGOTTEN
CURRENT - E92 ALPINE WHITE M3 V8
FUTURE - F10 M5
CHRISBURNS is offline
Old 28th November 2008, 20:07   #14
BMWNTHZST
BMWNTHZST's Avatar
Sales Feedback: (7)
Ok, I just had all four wheels rebalanced and I still have the wheel shake when driving over 80km.
This might be a stupid question but what is "hub centric" ring a few of you are referring to?
Old 28th November 2008, 20:20   #15
CHRISBURNS
CHRISBURNS's Avatar
It is the basically an inserted piece of alloy in the shape of a ring that fits inside the back of the wheel.
If you take the wheel off and look at the centre you should see the ring placed inside the hole were it mounts onto the hub. You might want to tap out the cap and use a screwdriver and a hammer to knock it out from the outside of the wheel as they are normally a ***** to get out.
When you do that throw it away, you dont need it.
Just make sure the face of the hub is clean and nothing will prevent the wheel from sitting flush and tighten the bolts the way I mentioned before.
If all of your wheels balanced fine it simply cannot be the wheels, it has to be the way they are mounted.
FUTURE - F10 M5
Old 28th November 2008, 20:26   #16
BMWNTHZST
BMWNTHZST's Avatar
Sales Feedback: (7)
Wouldn't this piece of alloy be noticed by the installer at the time of mounting and balancing?
Old 28th November 2008, 20:42   #17
CHRISBURNS
CHRISBURNS's Avatar
Not always, if you watch when they place it on the balancing machine some machines can fit with the ring on, others you need to take it off.
But the point is that either way the 'wheels' are balanced so its fare to say that the issue is elsewhere.
FUTURE - F10 M5
Old 28th November 2008, 21:10   #18
M-bitious
M-bitious's Avatar
Garage: M5 E60 carbon black
When balancing/spinning the wheels look carefully at the top of the tyre and see if it stays 100% flat. If it jumps up and down a bit, you have to reposition the tyre on the rim until it's gone. Also while looking at the edge of the rim itself, check it doesn't wobble. This is often overlooked as people focus on getting the wheels balanced and the weights positioned. Seen it too many times. You could have non-round rims (even when new from the factory!) and/or tyres.
M-bitious is offline
Old 28th November 2008, 21:50   #19
BMWNTHZST
BMWNTHZST's Avatar
Sales Feedback: (7)
I will check the new wheels to ensure they too are true round (no wobbles).
Failing all of this I'm going to assume the wrong rotation of the rubber for approx 7,500km has damaged the rubber Sometimes I wonder where the BMW service technicians heads are when doing simple tasks.
Old 29th November 2008, 18:35   #20
zigfread
zigfread's Avatar
Garage: bmw m3 steel grey
every after market replica that i have had will do the exact same thing with out a hub centric.
I put my wifes winters which are replicas and they did the same thing till i put the centrics on this year.
The rim can go alittle off and then you get the wobble.
This was the same with our M3 and the X3.
2006 interlogos M6
2006 Silverstone M5 gone
2003 Steel Grey M3 gone and missed
zigfread is offline
Page generated in 0.13803 seconds with 10 queries
