Old 14th November 2008, 00:21   #11
dubai_m5
dubai_m5's Avatar
Garage: Bmw e60 m5
man he cant the drive the m5 !!! what a bad start
2006 E60 M5
sepange bronze
sepange leather seats
aluminume
Full Hartge BodyKit
& Exhaust.
2006 Corvette Z06
Silver/Black
Katech Tourquer
Bolt-Ons
(510 rwhp)
2008 BMW X5
Alpine White
Beige Leather seats
Fully Loaded
2008 G55 AMG
dubai_m5 is offline
Old 14th November 2008, 01:19   #12
M V10
M V10's Avatar
Garage: M5 E60 Silverstone II
He can drive, but it was a mistake starting in 1st gear this day, it was very cold weather and no traction at all. When I raced the RS6 I didn´t mash the pedal, but pressed it very softly, because if I did mashed it, the car started spinning totally crazy even in 2nd gear.
After all, the Audi does have 580 hp and 650 Nm, it´s not a slouch and we need TRACTION.
M V10 is offline
Old 14th November 2008, 01:38   #13
mackyfr
mackyfr's Avatar
Garage: BMW M5 Sepangbronze metallic
Send a message via MSN to mackyfr
I can't? Thanks Maybe you can come to the next event and outrace the RS6 then?
mackyfr is offline
Old 14th November 2008, 14:28   #14
Gumball_Nut
Garage: Car
I think with these comments if a M5 were to meet an RS6 on the road in most situations it would be the same as the vids. RS6 would pull and pull and pull. With different days and different tempurtures the RS6 will always have traction thanks to its 4WD.
But would love to see tuned vs tuned :P That would be insane!
Gumball_Nut is offline
Old 14th November 2008, 14:34   #15
Gustav
Administrator
Gustav's Avatar
Was the shift to early in 1st?
Gustav is offline
Old 14th November 2008, 18:07   #16
ideliver
Garage: E60 M5
Wow...two great supercars...but you just can't beat HP...props to the Audi...its okay....I still love my M5 and is faster than anything I will see
ideliver is offline
Old 14th November 2008, 20:58   #17
Gustav
Administrator
Gustav's Avatar
Correct
Gustav is offline
Old 15th November 2008, 00:21   #18
M V10
M V10's Avatar
It does pull up to 150 mph, after that the M5 gains ground and will beat the RS6.
M V10 is offline
Old 15th November 2008, 00:29   #19
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
You need to get kenny aka keang24 to do some runs! Or rabdog! Kenny with his "detuned" setup beat an f430 with no nitrous! imagine if it had that extra 35whp on all motor tune!
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Video: Audi RS6 Avant vs BMW M5 E60 sedan with 20´wheels Gustav E60 M5 and E61 M5 Touring Discussion 67 23rd November 2008 00:04
2 x video: BMW M5 and Audi RS6 vs Porsche 911 GT3RS (997) 50-270 km/h Gustav E60 M5 and E61 M5 Touring Discussion 4 14th November 2008 23:02
Video: BMW M5 Dinan exhaust + ECu vs Carlsson CK60 vase Mercedes SL600 V12 Biturbo 600 HP 1024 Nm Gustav E60 M5 and E61 M5 Touring Discussion 8 13th November 2008 02:12
2 x video: BMW M5 and Audi RS6 vs Porsche 911 GT3RS (997) 50-270 km/h Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 29th October 2008 03:27
Pictures: First Audi RS6 580 HP crash Gustav GTBoard.com: General Sportscars 1 27th October 2008 13:25
Page generated in 0.12800 seconds with 11 queries
