Final Verdict On Aftermarket Lowering Springs - BMW M5 Forum and M6 Forums
Old 16th October 2008, 18:28   #1
DOUL
DOUL's Avatar
Garage: M5 E60 Black Sapphire - SMG
I'm in my final stages of completing my must have mods and I'd very much appreciate helping a brother out in deciding which aftermarket springs to go with. I've done an extensive search and came up with the following:
  1. H&R
  2. Eibach
  3. RDSport
From you're personal experience, which springs are the best in looks, noise less, and handling. Which vendors would you recommend? Thanks in advance.
Modifications:
  • Engine: RPi / PC Stage 2 ECU Software, RPi ST Underdrive Pulley Kit, RPi Ram Air Intake Kit (Black) & Block Off Plates, RPi SV1 Oil Cooler (Black), M-Sprint Booster
  • Exhaust: RPi GT Headers, RPi Hybrid X Pipe Section 2, RPi GT Section 3
  • Exterior: Vorsteiner CF Vented Hood, RH Type CF Splitter, Upper CF Mirrors, CF Side Skirts, CF AC Schnitzer Style Trunk Spoilers, CF Side & Kidney Grills, Black Powder Coated Lower RaceMesh Grille, CF Pillars, all Roundels in CF, Red Angel Eyes, OEM Smoked Tail Lights, Smoked Side Markers, Brake Calipers Painted in Red with CF ///M Decal
  • Interior: Custom CF Lower Steering Wheel, CF Interior Trim, CF Handbrake, CF Gauges Trim, CF Door Pins, Illuminated Door Sills, OEM Aluminum Pedals
  • Wheels: OEM Blacked Out Rims with Michelin PS2 Tyres (Front: 255/40-19 Rear: 295/30-19), H&R Spacers (12mm Front)
  • Suspension: H&R Lowering Springs
  • Miscellaneous: V-Kool Window Tints
DOUL is offline   Reply With Quote
Old 16th October 2008, 19:09   #2
G ///McGregor K
G ///McGregor K's Avatar
Garage: '08 M5 Space Gray
DOUL -- you read my mind! I was about to start a thread about the longevity of lowering springs. I was just going to ask specifically about H&R, but nonetheless, looking forward to hearing about this...
2008 Space Gray/Black Full Merino Leather/Alum. trim
Loaded - every option (minus heated steering wheel)
Interior:Hardwired Valentine One with Concealed Display, Blinder Xtreme M25 (J16) Laser Jammer, Bimmian Interior Xenon Lighting Kit and ///M Racing Pedals
Exterior: Hartge Front Spoiler Lip, Hartge Rear Diffuser, Vorsteiner Vented and Domed Hood (Double-Sided CF), Hamann Roof Spoiler, H&R Springs and 15% Tint
"Performance": RPI GT Section 3 Muffler, RPI GT Section I, ASR CAI, Evosport Power Pulley and Hybrid Rear Badge
G ///McGregor K is offline   Reply With Quote
The Following User Says Thank You to G ///McGregor K For This Useful Post:
DOUL (16th October 2008)
Old 16th October 2008, 19:18   #3
Glock 32
Glock 32's Avatar
Garage: Sapphire Black 2008 M5
I would never do just springs, again.
KWV3 Coilovers or even better Moton...
Glock 32 is offline   Reply With Quote
Old 16th October 2008, 19:20   #4
G ///McGregor K
Good to know, but why??
Old 16th October 2008, 19:28   #5
DOUL
DOUL's Avatar
+1
Old 16th October 2008, 19:30   #6
tightie
Garage: e60 m5
whatever you do, do not get RD springs. way too bouncy..
kwv3 was the best mod i did for the m5.. imo
http://i27.photobucket.com/albums/c1...ar/newsig1.jpg
SOLD: BMW E60 M5 Interlagos Blue/Black
CURRENT: 2008 BMW E92 M3 White/Black
tightie is offline   Reply With Quote
Old 16th October 2008, 19:35   #7
Glock 32
Glock 32's Avatar
Too bouncy and handling suffered. Different springs may yield different results. I was using RDSport before I switched. My conclusion was that the springs did not match the dampening of the OEM shocks and that maybe Eibach would have been better, but I did not like the way it sits on Eibach. The ride and handling on KWV3 is incredible and even better than stock and my KW's are set very very low. I felt like I destroyed the handling and the ride with springs and the KW's did the car justice...
Just my opinion as others have been very happy with springs...
Old 16th October 2008, 19:59   #8
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Eibachs retain the OEM feel of the car while lowering it for looks.. The spring rate is a little soft but not much different from OEM... H&R's are a little stiffer, if you are looking for handling i think they are a lil better as you can "feel the road" better, but if you are into smooth rides then I suggest he eibachs...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline   Reply With Quote
The Following 4 Users Say Thank You to Myke951 For This Useful Post:
DOUL (17th October 2008), joenjolera.com (16th May 2009), m5baller (17th October 2008), SyncmasterM5 (16th October 2008)
Old 16th October 2008, 20:08   #9
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
H&R's...the way to go !!
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is online now   Reply With Quote
Old 16th October 2008, 20:18   #10
Vodyk
Vodyk's Avatar
Garage: E60 M5
This coming from the man who doesn't mod!?!?!
+1 tho, I'm torn between just H&R Springs or stage 2 dinan kit.
Vodyk is offline   Reply With Quote
RPi Block off Intake Plates... Final Verdict? Rambino E60 M5 and E61 M5 Touring Discussion 23 20th April 2013 09:30
FS: E60 M5 H&R lowering springs vince516 Parts / Other For Sale or Wanted 4 28th April 2008 08:51
WTB: E39 M5 H&R LOWERING SPRINGS, or any lowering spring!! Virath Parts / Other For Sale or Wanted 13 14th April 2008 13:22
Original alpina springs vs H&R lowering springs (e12 B7) GlennSimon ALPINABoard.com | BMW Alpina Discussion 5 11th September 2006 08:48
Software software - final verdict MAH E39 M5 and E52 Z8 Discussion 3 1st February 2002 02:50
