Old 2nd October 2008, 08:12   #1
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Dinan Stroker and 997 TT rematch
Tonight I was able to meet up with my 997 TT friend for some comparison runs after he received his car back from the dealer.
The results were dramatically improved from this weekend when I couldn't pull him at all and we were neck and neck during the runs.
This time we started from 40 mph and I instantly walked him and kept putting car lengths on him until I decided to let off. We rinsed and repeated the process 2 more times with the same results and the second time I started at 4,500 RPMs (definitely not the traditional sweet spot for our cars).
When we pulled over he a seemed very impressed and said he never missed a shift once and nailed the RPMs perfectly for his car. He also mentioned he started at full boost each time and couldn't believe how I could pull him immediately when we would start the run.
We'll get some videos for everyone this week to help put some perspective on the difference, but it was dramatic. Of course the 997TT is no slouch at all so the gap wasn't like it was in the videos I posted against the stock M5, but they were still impressive and enough where he was clearly a few car lenghts in my rear view mirror when I decided to let off. We also didn't run as fast as we did in the video against the stock M5.
Just thought I would share. Don't worry, we will post some videos for everyone to make their own conclusions.
I continue to be very impressed with the Dinan stroker conversion and would highly recommend it to anyone!
Also, I just had to order a new set of 305mm rear tires today.
Cheers,
Darren
2008 M5 Interlagos Blau 5.7L Stroked
2008 X5 4.8i Alpine Weiss
darren_dallas is offline
The Following 7 Users Say Thank You to darren_dallas For This Useful Post:
boarder1995 (2nd October 2008), bodaddy (2nd October 2008), gasterus (2nd October 2008), Gustav (9th October 2008), IndyredNJ (5th October 2008), keang24 (2nd October 2008), xraym5 (2nd October 2008)
Old 2nd October 2008, 08:16   #2
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
awesome, used m5 out of warranty plus a dinan motor seemslike the way to go...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 2nd October 2008, 08:38   #3
Rated///M
Garage: 2003 996TT EVOMS GT750, 2008 Alpine White M5
Congrats man! Nothing like N/A power!
2008 Alpine White M5 (The Beast)
Meisterschaft Section 1 Test Pipes, Section 2 X-Pipe, GT-Exhaust with Carbon Fiber Tips, RPi Ram Air Scoops, BMC Filters
2003 996 Twin Turbo EVOMS GT750 (The Animal)
Evo Clubsport Intercoolers, Fabspeed Cat and Muffler Bypass Pipes, Brembo GT 6 Piston Brakes, KW V3, HRE C21 est. 650awhp
2008 Lamborghini Superleggera
Larini Insulated Test Pipes, Larini Sports Exhaust
Previous Cars:
01 BMW M3 / 03 BMW M5 / 02 Corvette Z06 / 04 CL55 AMG / 03 BMW 760Li
Rated///M is offline
Old 2nd October 2008, 08:48   #4
DAKU-M5
DAKU-M5's Avatar
Garage: M5 Silverstone/Silverstone
Cant wait for vids, or my moneys so I can get that shiznit.
DAKU-M5 is offline
Old 2nd October 2008, 09:24   #5
avi8tir
Garage: M5
I would expect these results. too bad it takes $40k to walk on a 997TT.
2008 M5
Silverstone on Silvertsone * Dinan Stage 2 Suspension * Dinan Intake * Dinan Mid-pipes * Dinan Exhaust * Dinan Stage 3 Software * HRE P40 - 20" Satin Charcoal w/ PS2's * Carbon Grille & Gills * RPI Scoops
2005 Maserati Gransport
2010 997.2 GT3 (October Build)
2008 Cessna 400
avi8tir is offline
Old 2nd October 2008, 09:34   #6
DAKU-M5
DAKU-M5's Avatar
$40K, hmm, I would pay even $50k. Still would be cheaper than the 997 turbo and more comfortable, but I wouldnt compare the two cars. I think Darren was racing the 997 turbo to confirm that he and others with the stroker have the fastest 4 door luxury sedan available, oh did I mention is still has warranty! That alone makes it very tempting, Maybe after santa comes over I will be heading to Dinan, UNLESS gets to me first, LOL.
DAKU-M5 is offline
Old 2nd October 2008, 09:35   #7
bodaddy
bodaddy's Avatar
Garage: 2007 BMW M5 Black Sapphire
Sounds great Darren, cant wait to see the videos. How is torque down low from a dig? I'm curious to hear how much better that is.
'07 M5 Black Sapphire
Evosport Pulleys, Charcoal Filters out, BMC Filters, RPi Scoops & Block-off Plates, RPi ST Sec 1, RPi GT Sec 2 & 3, RPi R2 ECU, 20" HRE P40s w/ Michelin PS2s, Dinan Stg 2 Suspension, AIB v3.0, Hardwired V1 w/ concealed display, Black Kidneys & Sides, Bimmian Interior Xenon Kit, Hartge pedals & e-brake, Luminar tint
'10 BMW X5 35d Monaco Blue
'02 M3 (gone but not forgotten)
bodaddy is offline
Old 2nd October 2008, 12:30   #8
kaninja99
kaninja99's Avatar
Garage: 2007 M5 Silverstone
it doesn't take $40,000 to walk a 997TT
avi8tir,
raced 997 turbo (auto) and the mighty GTR!
see my post, it doesn't take $40,000. all you need is aftermarket headers, pulley and straight pipes. then you can walk a 997 TT past 200 km/h and even catch a GTR by the toe!
i figure you can get and install the parts mentioned above for around $7,000 USD which is quite a reasonable deal!
kaninja99 is offline
Old 2nd October 2008, 16:06   #9
darren_dallas
Originally Posted by kaninja99 View Post
avi8tir,
I think what is most interesting is that we started from around 40 mph and I walked him instantly. We didn't have to wait until 120+ mph to pull him.
The torque down low is so instantaneous it's incredible. It feels like I'm driving a supercharged V8 when I'm in low RPM because it's so different than my non-stroked engine.
Hopefully my friend with the 997TT (Quintinnn, aka Drift King ) will share his thoughts on the run as well.
Darren
The Following User Says Thank You to darren_dallas For This Useful Post:
bodaddy (3rd October 2008)
Old 2nd October 2008, 17:17   #10
m6ontheway
m6ontheway's Avatar
Garage: M6 Vertible 6 speed
Very nice!! I love to read this story!! Well worth the $$ if you ask me. You now have the sickest machine ever by a bmw!!
2007 M6 Cab, Silverstone Silver, Indy Red Full Merino, Fully loaded.
m6ontheway is offline
Dinan Stroker In Action darren_dallas E60 M5 and E61 M5 Touring Discussion 568 11th January 2009 16:29
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 14:12
dinan stroker video slickM E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 5th September 2008 15:21
Dinan 3.8 Stroker and chip tutash E34 M5 Discussion 6 18th November 2006 02:08
'91 M-5 3.9 Stroker/Dinan Craig Carter For Sale or Wanted 2 7th August 2000 07:03
Page generated in 0.15391 seconds with 12 queries
