LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 2nd October 2008, 20:53   #111
///Marshall
///Marshall's Avatar
Garage: BMW M6 Sapphire Black
+1. Though they should think about having high flow cats as
an optional accessory.
Originally Posted by darren_dallas View Post
No sir...RPI's setup uses straight pipes on flanges so you can swap in/out the stock primary cats for emmissions testing, but it's straight pipes only when not using the stock primary cats.
///Marshall is offline
Old 2nd October 2008, 21:27   #112
EuroCarFan
Garage: 2006 M5 Blk Sapphire and 2004 Dinan 545 Blk Sapphire
Darren/Marshall, thanks for clairfying.
2006 M5 Blk/Blk/Alum Fully Loaded
Engine: Singh Autosport Software | RDSport Headers + Race Cats + X-Pipe + Competition Exhaust + Pulley | RPI Oil Cooler + Ram Air Scoops | Dinan High Flow Air Mass Meter/Intake Assemblies | ///M Sprint Booster
Wheels, Susp & Brakes: Neez QD7s Hyper Black 20x9-10 | PS2s | KW V3s | Dinan FRC + Rear Sway Bar + Front & Rear CF Strut Braces | Brembo 380mm BBK
Exterior: RDSport Roof + Trunk Spoilers | Hartge Splitter + Diffuser | CF Lower Mirror Covers | 3M Clear Bra
Interior: RDSport Alum Pedals | Hardwired V1
Lighting: Eurospec Headlights w/Clear Corners | Eurospec Smoked LCI LED Taillights | MTEC V2 | Bimmian Int Xenons
EuroCarFan is offline
Old 2nd October 2008, 23:25   #113
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
Darren, would the RPI scoops work in conjunction with the dinan airbox as it is supposedly less restrictive and will allow more airflow? extra 20+ hp would be nice!
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 2nd October 2008, 23:44   #114
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Yes they do. I don't know if they provide the same level of gains as on a stock motor with stock air boxes.
SBM6 has the RPI scoops and should be able to chime in once he puts some miles on the car.
Cheers,
Darren
2008 M5 Interlagos Blau 5.7L Stroked
2008 X5 4.8i Alpine Weiss
darren_dallas is offline
Old 3rd October 2008, 00:51   #115
roja
Garage: 2008 BMW M5 -- Alpine White
Send a message via AIM to roja
would stiffer springs help with the traction control (or lack thereof) ?
just thinking that if u had stiffer springs, the force of the torque driving the wheels to the ground would be more efficient (less spinning, and more grip
) or maybe the car has so much more power that it wouldn't matter.
roja is offline
Old 3rd October 2008, 00:58   #116
Myke951
Myke951's Avatar
it would help if you find that right setting as that is why there are drag suspension kits for cars... I think for traction i would go with stiffer setting upfront but softer in the rear as thats what i did when i had the coil-over suspension in my 944 turbo and it helped tons! just gotta find that nice compromise as a stiffer rear would keep the rear up more and it will spin more. At least from my experience
Myke951 is offline
Old 3rd October 2008, 01:18   #117
darren_dallas
At the end of the day, this car is a street monster. While I'll probably use different tires when I go to the track. I'm extremely pleased with my Dinan suspension and cannot believe the difference it made compared to my Eibachs...not even the same league.
Darren
Old 3rd October 2008, 01:31   #118
roja
yup, the dinan suspension is pretty solid. ride quality, i swear, is stock, but performance is so much more solid. got it on mine, with all the other handling goodies.
congrats on the stroker, have fun...
p.s. talk to chuck, he'll tell ya to invest in a radar/laser detector/jammer.
roja is offline
Old 3rd October 2008, 01:42   #119
xraym5
xraym5's Avatar
Garage: E60 BMW M5 Black/Sepang
Ever-growing wish list for Darren (not necessarily in this order):
1. Get a sub 4.0 second 0-60 MPH on your V-box
2. <12.0 second 1/4 mile time
3. Beat the 997 turbo from a dig
4. Race E55 AMG from a roll and dig
5. Top speed run like Russ Ramz (hoping for 210 on the GPS)
6. 0-100 MPH time low-mid 8's
7. Dyno >550 RWHP
8. 60-130 MPH run on the V-Box
9. Race Z06 from a roll and a dig
10. More videos please--never can get enough vicarious stroker thrills
All the above in a controlled and safe environment. Be careful out there!
2006 M5--Sapphire black/sepang
Dinan: free flow exhaust, Stage 3 engine software, high flow throttle bodies, high flow air mass meter/intake Assemblies, stage 2 suspension, 13% underdrive crankshaft pulley, 5.7 liter stroker engine (I think I am finally done)
xraym5 is offline
Old 3rd October 2008, 04:08   #120
SBM6
Garage: '08 5.7L Dinan S3 M6 AW/BLK FULL CF
Sales Feedback: (3)
Originally Posted by M5Ranger View Post
I know you feel I have a piece of sh*t but lets run.
Junky and LIFESGUD will run you.
Ranger
OK Ranger,
I have had about enough of your BS. I didn't say one word about your car or anyone's car for that matter specifically. I was responding to another poster alltogether.
I believe you have a problem with a little word called context. Look it up.
But regardless, I will run you, LIFESGUD, Junky, and whomever else you would like to throw in the mix because win, lose, or draw it will be fun nonetheless. In fact, let's do 10 runs in a row without you getting out of your car to change your bottle!
Now I will just shut my mouth because everyone on here thinks I'm a loser and I have a piece of crap and I will stop posting here alltogether because to he77 with me, I don't know squat!
All in good fun, of course.
SBM6
'08 S3 M6 AW/B/CF
SBM6 is offline
45 minutes discussion with Dinan on the V10 stroker engine + news that there will be a stroker Dinan M3 V8! Gustav E60 M5 and E61 M5 Touring Discussion 24 30th December 2008 14:12
dinan stroker video slickM E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 5th September 2008 15:21
Dinan 5.7 Stroker or ASR NOS? avry8542 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 15 25th December 2007 18:20
Dinan 3.8 Stroker and chip tutash E34 M5 Discussion 6 18th November 2006 02:08
'91 M-5 3.9 Stroker/Dinan Craig Carter For Sale or Wanted 2 7th August 2000 07:03
Page generated in 0.15900 seconds with 12 queries
