Congratulations! And congratulations to Dinan for evidently being able to crawl out of their E60 slump and pull out a winner. Naturally aspirated motor with that power on a warranty.
Time to find an '07 or '08 for a good price and do the stroker swap! With prices of used M5's dropping like concrete shoes, the 40K investment for pure performance is one hell of a deal!
Thank you for taking the risk and sharing. Good luck!
________________________
'08 M5, SMG - Black Sapphire / Black Merino
'07 X5 3.0si - Jet Black / Tobacco Napa Leather
'04 M3 Conv, SMG - Jet Black / Black Merino (Gone 9/11/07 )
'04 Mini 'S' - Dark Silver/White Top, (mucho mods)
'86 Porsche 951 -White (Son's money pit)
Past Rides (worth mentioning)
'98 M3 -Titanium Silver /Black Merino -Sold
Sort of, the are similar because they use the stock headers as the basis for the solution. They differ because my setup use high-flow cats and I don't get the CEL penalty.
Hope this helps.
Darren
Maybe someone from RPI or someone with the RPI set up (Kenny?) can confirm but I thought RPI's system also includes race cats and do not have any CEL warnings.
Darren, would you mind doing 60-130mph please? since they all use 60-130 as a bench mark on 6speedonline.
Thank you, sir.
Edit: regarding RPI headers setup, they replace prime cats with straight pipe with a little twist that will not throw the CEL. Their high flow cats were on section1. In my case, I have ESS to disable the rear O2 sensor, so it doesn't matter. I think RPI have tested with their M5 (NobleM400) with stock ecu and no CEL.
__________________ The Good Die Young R.I.P. BALL...11/15/88-06/22/06
No sir...RPI's setup uses straight pipes on flanges so you can swap in/out the stock primary cats for emmissions testing, but it's straight pipes only when not using the stock primary cats.
Thank you, sir.
Edit: regarding RPI headers setup, they replace prime cats with straight pipe with a little twist that will not throw the CEL. Their high flow cats were on section2. In my case, I have ESS to disable the rear O2 sensor, so it doesn't matter. I think RPI have tested with their M5 (NobleM400) with stock ecu and no CEL.
I'll work on it. People who do those runs are freakish about how to tweak every last bit of power/time out of the run. For example, they have only 1/8 tank of gas, they strip out everything in their car, they look for tail winds, etc.
In other words, it can be manipulated nicely and not reproducable on regular intervals. Just FYI...
