Old 23rd September 2008, 05:57   #31
M5Ranger
Garage: 2006 M5 Alpine White
[quote=avi8tir;1422652]I like the results of the ASR CAI, but its just flat ugly. looks are still of equal importance to me as power.
havent seen any private results on the Dinan CAI, but I am curious and impatient.... so I may just have to guinea pig myself again! [/quote
Yes and at your expense my friend. Stay with Dinan by all means because it makes you happy and they will do great by you .
Frankly I could not give a sh!t anymore. Go with what makes you happy my friend. That is what is important to you.
2006 M5 Alpine White/Silverstone (I miss it)
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
M5Ranger is offline
Old 23rd September 2008, 10:44   #32
BMWPower06
BMWPower06's Avatar
Garage: Indy Red ///M5
Send a message via AIM to BMWPower06
Cousin has the AFE intakes on his car, they sound AMAZING, i dont know how you didnt notice a difference in sound, as for performance, the butt dyno def felt better. I dunno why you lost power with yours. but my cousin and I have been nothing but happy with the AFE Intakes
BMWPower06 is offline
Old 23rd September 2008, 16:11   #33
avi8tir
Garage: M5
At first I couldnt hear the much. Now that Ive had them for a few days, I can hear the difference. From a dig or at low speeds there is a definite growl from the engine bay. At high speeds or high rpm everything else is so loud so its not as apparent.
As far as power goes, proof is proof. The science behind the proof as well (sucking in hot air from the engine bay).
2008 M5
Silverstone on Silvertsone * Dinan Stage 2 Suspension * Dinan Intake * Dinan Mid-pipes * Dinan Exhaust * Dinan Stage 3 Software * HRE P40 - 20" Satin Charcoal w/ PS2's * Carbon Grille & Gills * RPI Scoops
2005 Maserati Gransport
2010 997.2 GT3 (October Build)
2008 Cessna 400
avi8tir is offline
Old 23rd September 2008, 16:36   #34
andrewsherman
andrewsherman's Avatar
Garage: 2007 Silver Grey
How does one test for an exhaust leak? I have the Dinan cans and have been getting a bit more drone lately. Wondering if it could be from a leak.
'07 M5: Silver Grey/Black Full Merino Leather|Walnut Madeira Wood Trim|HUD|Sirius|Comfort Access|Split Rear Seats|Rear Sunshades|iPod Interface|
Goodies: ESS Software|Dinan 3.91 Rear Differential|EvoSport Pulley|Dinan Free Flow Exhaust|Dinan Front Control System|Dinan Rear Sway Bar|RPI Ram Air Scoops|BMC Filters|RPI Oil Cooler|SprtintBooster|OE M6 style wheels w/ PS2s|LED Tail Lights|AngeliBright 3.0|AC Schnitzer Roof Spoiler|Vizualogic A-1250 Rear DVD Sysyem|Huper Optik ceramic tint|clear-bra|V-1 Stealth Install|Blinder M-40|Aluminum Pedals|LED interior bulbs|Blizzak LM-22 255/40VR19 (Winter Rubber)
Past Rides: '04 745Li Titanium Grey/Black|'01 740iL Titanim Silver/Black|'91 K1100RS|'88 K75S
andrewsherman is offline
Old 24th September 2008, 03:20   #35
RPIpower
Company Representative of RPI Power
RPIpower's Avatar
Garage: E60 M5
When all else fails, copy RPi's scoop idea. AFE is making scoops now too.
Eloy
Race Precision, Inc.
www.raceprecision.com
RPIpower is offline
Old 24th September 2008, 03:29   #36
EM_5
EM_5's Avatar
Garage: 2007 M5
I know a good lawyer....
Do or Do Not. There is no Try.
///M, Faster than a speeding ticket.
EM_5 is offline
Old 24th September 2008, 04:52   #37
NobleM400
NobleM400's Avatar
Garage: 06 BMW M5 Silver Gray Metallic
Send a message via ICQ to NobleM400 Send a message via AIM to NobleM400 Send a message via Yahoo to NobleM400
Drone increasing (or becoming noticable) tends to be more a function of muffler packing material burning off (especially with fiberglass packing).
To check for a leak, the easiest way is to turn the car on, lift it up (so you can see the exhaust, then use a spray bottle full of water to spray the suspect locations. If it's leaking, you will see the water bubble.
Gabe
Race Precision, Inc
NobleM400 is offline
Old 24th September 2008, 06:35   #38
BMWPower06
BMWPower06's Avatar
They seem to be pretty well insulated, as good as any other short ram intake i've seen. And, they use plastic tubing as apposed to most others using metal tubing which well get much hotter.
Old 24th September 2008, 21:46   #39
RPIpower
RPIpower's Avatar
Garage: E60 M5
They are no insulated at ALL. There are heat shields which do nothing because its not radiant heat you are trying to block, its actual underhood temps that is hurting the performance. Induction (cone) type intakes simply dont work on new performance cars (most). I have yet to see one of those systems work on any of the new cars we have dynoed.
RPIpower is offline
Old 25th September 2008, 05:45   #40
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
Damn everyone trying to jump on the bandwagon and make imitations... I hope they know that you patented the idea and its bad news if you decide to take them to court...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
New AFE Power Flow Intake JDS M5 E60 M5 and E61 M5 Touring Discussion 25 15th December 2008 09:23
Has anyone done the new AFE Intake on the E60 M5? C's Bimmer E60 M5 and E61 M5 Touring Discussion 49 22nd September 2008 02:25
what the diff: AFE intake vs K&N intake Rated-M E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 5th August 2008 08:47
aFe Intake-E39 M5 Used Racerxjling For Sale or Wanted 6 11th December 2007 19:51
Experiences with AFE intake? lakelife79 E39 M5 and E52 Z8 Discussion 13 8th August 2006 16:59
Page generated in 0.26173 seconds with 12 queries
