20th September 2008, 20:49
#4
Hey Rambino, RPI has tested the Block Off Plates and they can give you an estimated 5-7 whp in the range of 4500-6800 rpm. I'm very confident with the RPI's engineering and I don't think that your ECU is unhappy with this set up. May be RPI can give you a more comprehensible explanation.
You have the sole right to inquire about this subject. Personally, I believe that a simple low-priced mode like the Block Off Plates that can be easily removed at anytime is quite an impressive mod to actually give you an approx. 5-7 whp gain.
My verdict is to keep them & forget about them unless you're really uncomfortable with them.
Modifications:  Engine: RPi / PC Stage 2 ECU Software, RPi ST Underdrive Pulley Kit, RPi Ram Air Intake Kit (Black) & Block Off Plates, RPi SV1 Oil Cooler (Black), M-Sprint Booster
Exhaust: RPi GT Headers, RPi Hybrid X Pipe Section 2, RPi GT Section 3
Exterior: Vorsteiner CF Vented Hood, RH Type CF Splitter, Upper CF Mirrors, CF Side Skirts, CF AC Schnitzer Style Trunk Spoilers, CF Side & Kidney Grills, Black Powder Coated Lower RaceMesh Grille, CF Pillars, all Roundels in CF, Red Angel Eyes, OEM Smoked Tail Lights, Smoked Side Markers, Brake Calipers Painted in Red with CF ///M Decal
Interior: Custom CF Lower Steering Wheel, CF Interior Trim, CF Handbrake, CF Gauges Trim, CF Door Pins, Illuminated Door Sills, OEM Aluminum Pedals
Wheels: OEM Blacked Out Rims with Michelin PS2 Tyres (Front: 255/40-19 Rear: 295/30-19), H&R Spacers (12mm Front)
Suspension: H&R Lowering Springs
Miscellaneous: V-Kool Window Tints
