• Latest threads
    • Custom feed
      • Updates
        Old 28th August 2008, 13:27   #1 (permalink)
        Gus
        Gus's Avatar
        High idle rpm?
        My M5 idles in traffic at up to 900 rpm. Apparently the "official" reason for this is to keep the cats at optimal operating temp. Sounds weird to me..
        Gus is offline
        Old 28th August 2008, 15:36   #2 (permalink)
        Balazs
        Balazs's Avatar
        Mine too. Rarely, like in 10% of the time, it sits lower at about 750. No idea
        Balazs is offline
        Old 28th August 2008, 17:31   #3 (permalink)
        7 speed SMG
        7 speed SMG's Avatar
        I have noticed this also, especially when you are behind another car. I just don't know why...
        7 speed SMG is offline
        Old 29th August 2008, 02:51   #4 (permalink)
        CHRISBURNS
        CHRISBURNS's Avatar
        To waste even more fuel of course
        ///M - The fastest letter in the alphabet.
        CHRISBURNS is offline
        Old 29th August 2008, 22:27   #5 (permalink)
        carlsturm
        Running Air conditionning can elevate the idle RPM's.
        06M5 Silver
        03M3 Imola Red (Supercharged)
        carlsturm is offline
        Old 31st August 2008, 13:31   #6 (permalink)
        ehssan_alkhiyami
        ehssan_alkhiyami's Avatar
        Send a message via MSN to ehssan_alkhiyami Send a message via Yahoo to ehssan_alkhiyami
        mine too , I took to the dealer , ediots after 10 days of keeping the car there , they said I have to change the fuel pump and the fuel tank , I asked the reason why the fuel tank , the guy said that it might start leaking in the future ,, well , after long and long search , I've ordered a new fuel pump , replacing it was pain in the A** . and i found out that they wanted to replace the fuel tank is because if you order fuel tank , it will come with fuel pump installed inside it , they wanted me to pay almost 1500 $ just for the fuel tank .. and anyway my problem still there . most of the time it says at almost 900 .. very strange ... i have TIS software and I've done some search . they have similar cases and all are releated to the fuel pressure .. but at least while driving it doesn't loose HP's ...
        E.K
        ehssan_alkhiyami is offline
        Forum Jump
        Clutch is slipping at high RPM.... bng4god E39 M5 and E52 Z8 Discussion 1 23rd July 2007 00:26
        Oil Analysis of Royal Purple Racing 51 vs LUCAS Synthetic vs Castrol 10w60 vs Mobil 1 KingM5 E39 M5 and E52 Z8 Discussion 41 28th April 2006 22:38
        mysterious high idle Sebring NL E34 M5 Discussion 3 22nd March 2006 22:52
        Optimal Shift Points-it's at 7000 KirklandM5 E39 M5 and E52 Z8 Discussion 26 14th June 2001 01:58
        Page generated in 0.23708 seconds with 11 queries
