27th August 2008, 09:04
#1 (permalink)
Just intalled Sec 1&2 MST GT Exhaust -Loss of low end torque?
Just intalled my Meisterschaft Section 1 and 2 Pipes including GT Exhaust. The pipes have horrible fitment. Anyways, I love the sound, but I felt like the car lost a little of low end torque. How do I regain that torque without losing sound? What should be my next mod?
I also have RPi Ram Air.
27th August 2008, 09:28
#2 (permalink)
john, got pics of the new ride and setup?
2006 BMW M5
27th August 2008, 09:55
#3 (permalink)
Hey Mike,
No pics yet. In the process of making my M5 into a beast. Too busy for the pics lol. Hopefully I will see you at the next meet!
-John
27th August 2008, 14:38
#4 (permalink)
A lot of people have been skeptical of how the Meisterschaft products perform on the dyno do to the claims of no R&D behind their products produced in Korea. You should never sacrifice power for sound, especially when other lines R&D to ensure gains (ie. RPI & ASR). Maybe you should sell off your Meist parts and go another route.
'07 M5 Black Sapphire
Evosport Pulleys, Charcoal Filters out, BMC Filters, RPI Scoops, RPI ST Sec 1, RPI R2 ECU, Dinan Exhaust, 20" HRE P40s w/ Michelin PS2s, Dinan Stg 2 Suspension, AIB v3.0, Hardwired V1 w/ concealed display, Black Kidneys & Sides, Bimmian Interior Xenon Kit, Hartge pedals & e-brake, Luminar tint
'04 Mercedes G500
'02 M3 (gone but not forgotten)
27th August 2008, 17:25
#5 (permalink)
If you love the sound and want to gain HP, look at the ASR Gen II exhaust. I love mine.
Sam
PS., the fitment is perfect.
The Following User Says Thank You to ssigarto For This Useful Post:
27th August 2008, 17:33
#6 (permalink)
I am sorry to read about your predicament. I recommend change the exhaust.
Checkout the ASR Engineering full exhaust. You will be very happy with the sound and the power gains. The design, build quality are precise.
The power and torque gains are dyno proven.
Do not accept power loss. Have you called the company?
Good luck
Ranger
2006 M5 Alpine White/Silverstone
Upgrades:
Engine: SS headers,Evosport power pulley,Active Autowerke
ECU,ASR custom air intakes,Dinan throttle bodies, ASR Engineering NOS kit, Evosport 3.91 diff.
Exhaust: ASR Engineering custom exhaust.
Suspension: H & R sport spings,Dinan front/rear CF strut braces.
Wheels: HRE 590R, (F) 20x9 (R) 20x10.5 w/ Michelin PS 2 255/35
& 285/30
Exterior: Vorsteiner CF vented hood, Vorsteiner CF front spoiler,
ACS rear deck lid spoiler, front kidney grill & side gills in
CF.
Brakes: Brembo GT kit, (F) 6 piston monobloc calipers w/ 16"
rotors & (R) 4 piston monbloc calipers w/ 15" rotors.
Interior: ACS titanium CF trim.
Dyno results:Straight motor 460 rwhp, on nitrous 581 rwhp/461 lb/ft rw torque
2007 GT3 speed yellow
2007 GT3RS orange
2007 RS4 imola yellow
The Following User Says Thank You to M5Ranger For This Useful Post:
27th August 2008, 21:27
#7 (permalink)
Company Representative for Gthaus
previous independent dyno runs, we and our customers have tested,
we have gained close to 8 peak torque gains as well as HP gains
with section 1 and 2.
Loosing out the low end torque was somewhat expected,
since you just have lost close to 25% of back pressure (with passing cats, resonators and high performance muffler system), but the other turn, you have gained on high peak RPM Range instead - that is the advantage of less back pressure especially on NA vehicles such as M3, M5 and M6.
Dyno testings are done numerous times, and even with a 4 wheel mustang dyno, it is fairy difficult to measure numbers when the RPM is low. Below 3000 RPM it can be considered very fragile data and can not be dependent on, therfore, we would not be able to extact tell you, you have gained torque or lost torque based on 3000 or less rpm range testings (lower RPM ranges), however all exhaust systems out there, whichever brand it is, if the exhaust needs to serve high RPM range gains, this is somewhat expected.
To regain, the low end torque, we would recommend you to replace the stock cats back on - replace back with original section I. You will have the low end torque back however most likely not feel as fast on high rev RPM range and slower throttle response.
Also, it takes a little bit of time for ECU to adjust your new settings.
The vehicle needs to learn the new flow rate, which will be re-calculated by your F.L ECM. Drive it around at least next few hundred miles, and see if the ECM adjust properly. If you still think the setting is not what you are looking for (power within lower RPM range) then put the original section I catted pipe back on the vehicle.
P.S
have you installed any aftermarket headers?
The reason we are asking: performance headers will break loose another close to 10-15% back pressure.
Indepent dyno runs, we have several results of loosing power in wide band of RPM Range.
Folks with section 1+2+ rear section 3, we recommend not to use any aftermarket headers,
unless you want to remap your ECU and rev it 8.5K for prime peak (with higer octane race fuel) with
weight reduction of vehicle is recommended to better rate the torque.
If you have any questions,
please call us. We should provide you more specific guidelines for you.
thank you.
GTHAUS: 630.787.1600
28th August 2008, 02:34
#8 (permalink)
I love my RPI ST Section 1! Biggest gains in midrange torque and peak Hp, with no loss throughout the band in either Hp or torque.
'04 Mercedes G500
The Following User Says Thank You to bodaddy For This Useful Post:
28th August 2008, 03:21
#9 (permalink)
+1
________________________
'08 M5, SMG - Black Sapphire / Black Merino
'07 X5 3.0si - Jet Black / Tobacco Napa Leather
'04 M3 Conv, SMG - Jet Black / Black Merino (Gone 9/11/07  )
'04 Mini 'S' - Dark Silver/White Top, (mucho mods)
'86 Porsche 951 -White (Son's money pit)
Past Rides (worth mentioning)
'98 M3 -Titanium Silver /Black Merino -Sold
28th August 2008, 17:08
#10 (permalink)
What is RPI ST Section 1? Does it replace the secondary cat with their own version of race cats? Care to elaborate
07 M6 blk/blk
Eisenmann Race exhaust
Evosport Pulleys
Race cats
BMC air filters
H&R springs
Brex White Rings
8000K Xenon
RPI air scoops
