• Latest threads
    • Custom feed
      • Updates
        Old 26th August 2008, 11:10   #1 (permalink)
        fear_999_
        How can we close the Trunk permanently ?
        Hi !
        How Can we Close the trunk permanently ?
        so we can put our things inside without any fear that any one can open it if he have the key !
        Is their any 12v socket back in the trunk where it is located ?
        Many thanks,,
        fear_999_ is offline
        Old 26th August 2008, 12:40   #2 (permalink)
        AvusAndy
        AvusAndy's Avatar
        my friend im confused, if we lock the trunk permentatly then how do you retrieve what's inside??
        E30 M3 My first Love.
        AvusAndy is offline
        Old 26th August 2008, 12:49   #3 (permalink)
        fear_999_
        what i mean is that to have like akey or a switch button that lock the trunk so no one can open it like what the 7 series have inside the arm rest .
        Old 26th August 2008, 16:08   #4 (permalink)
        unfoundhorsepower
        unfoundhorsepower's Avatar
        ya, place man with gun in trunk, no worries !!
        See you all at the:
        Mmmmm meet...in Massachusetts, July 2009 for sure.
        unfoundhorsepower is offline
        Old 26th August 2008, 17:01   #5 (permalink)
        boarder1995
        boarder1995's Avatar
        There is a 12V outlet in the trunk.
        I don't know of a way to "lock" the trunk unfortunately.
        '06 M5, took ED on Aug. 28th, 2006 in Munich!
        Re-delivery on Oct. 20th, in Temple, TX.
        boarder1995 is offline
        Old 26th August 2008, 17:09   #6 (permalink)
        m5 deamon
        m5 deamon's Avatar
        Send a message via AIM to m5 deamon
        take your key insert and insert it in the trunk lock and manually lock the trunk.
        2001 m5 Carbon Black, Black sport interior, m audio
        AA cai with bmc air filters
        AA software going to change to either ess or pc
        UUC Light Weight FlyWheel And Organic Clutch
        UUC evolll ssk \ Dssr
        UUC Big Boy Clutch stop v3
        UUC Transmisson mounts
        Steelbraded clutchline
        Eisenmann Race Exhaust 83mm tips
        Supersprint X pipe
        Steel braded brake lines
        Dinan rear sway bar
        Dinan stress bars front and rear
        Tc swaybar brackets
        PS2 tires
        Axiss ult pads front and rear
        Dinan JRZ suspention kit
        Euro head lights
        Predator ice v2.1 angel eyes
        Bimmian black kidney grills
        DDM xenon fog lamps
        Solaris amber bulbs
        led lic plate lights
        v1 hardwire
        m45 blinders updated version
        To Come... dinan headers, stoptec bbk
        m5 deamon is offline
        Old 26th August 2008, 17:53   #7 (permalink)
        fear_999_
        there is no key in the trunk or outside where do i insert the key ?
        The Following User Says Thank You to fear_999_ For This Useful Post:
        unfoundhorsepower (27th August 2008)
        Old 26th August 2008, 17:54   #8 (permalink)
        fear_999_
        i didnt find the 12v can u please explain its location inside the trunk ?
        Old 26th August 2008, 18:22   #9 (permalink)
        T-Town M5
        The valet key is your answer. Look in your glove box and you will find a shell (or outer case) of a key. Remove the key from your FOB and then insert it into the shell that you removed from the glove box.
        To remove the key from the FOB you will need to pinch both sides and will slide out.
        I hope this helps.
        2006 - Alpine White
        2003 - 540i M-Sport (for sale)
        T-Town M5 is offline
        The Following 2 Users Say Thank You to T-Town M5 For This Useful Post:
        m6ontheway (26th August 2008), unfoundhorsepower (27th August 2008)
        Old 26th August 2008, 18:41   #10 (permalink)
        fear_999_
        I hope this helps.
        Ya ! but wht is the point from doing this what will happen if i remove the plastic shell from its place and insert it into my metal key.
        What will happen next ?
        Old 26th August 2008, 19:59   #11 (permalink)
        avlnch
        avlnch's Avatar
        Then whoever has your m5's shell with the metal key inside can only drive your car & cannot open the trunk because there are no buttons on the key.
        Try it and see if the trunk will open when you push the button inside the car. Just make sure that only the shell is in range and your set of keys arent.
        2008 BMW ///M5 {Black Sapphire/SilverStone II/Aluminum Trim}
        ~Mods: Black Grills, Black Gills, Black Roundels, White AngelEyes, Charcoal Filters Deleted, RPI Scoops, BMC Drop-In Filters, DINAN Software, DINAN Exhaust
        Other Vehicles: 09 MERC S65 AMG, 08 MERC S63 AMG, 07 BMW ALPINA B7
        Previous Vehicles: 06 RANGEROVER S/C
        avlnch is offline
