• Latest threads
    • Custom feed
      • Updates
        Old 25th August 2008, 07:23   #1 (permalink)
        polar993
        Car is "pulling" side to side while driving.....what's wrong?
        I'm on the East Coast for a couple of weeks of vacation and work, and I'm borrowing my dad's 650ci (it's actually my old car that I gave him when I bought my M5). The car seems to be "pulling" side to side very badly on the highway, especially when changing lanes. It's almost like the steering wheel has a mind of its own! It's actually quite dangerous to drive!
        Does anyone know what might be causing this to happen? The car has 20" Breyton's with PS2's. Tread life is about 70% remaining on both front and rear. Stock suspension.
        The alignment seems pretty straight. When the car isn't pulling side to side, it stays fairly straight.
        Your thoughts on this would be greatly appreciated!
        -Polar
        2006 E60 M5
        Sapphire Black Metallic w/Full Perforated Black Merino Leather
        All Options except HUD
        Mods:
        - Eisenmann Race Exhaust (Quad Oval Tips)
        - Evosport Pulley
        - Charcoal Filters Removed
        - Hartge (Front) H&R (Rear) Lowering Springs
        - Hartge 21" Classic II Wheels
        - Hartge Front Lip Spoiler
        - Arqray Rear Decklid Spoiler
        - 8,000K Hella HID's
        - Aluminum Pedals
        - RPI Scoops & BMC Filters
        polar993 is offline
        Old 25th August 2008, 08:06   #2 (permalink)
        ThisFlyGuy
        ThisFlyGuy's Avatar
        try a new alignment just to be sure OR re-balance the weights on the rims
        2006 BMW M5
        ThisFlyGuy is offline
        Old 25th August 2008, 08:17   #3 (permalink)
        EM_5
        EM_5's Avatar
        Just cause the alignment seems straight does not mean it is correct. The toe may be off, causing the car to wander. Have a good alignment shop re-do the alignment. i am quite sure that that's your problem.
        Do or Do Not. There is no Try.
        ///M, Faster than a speeding ticket.
        EM_5 is offline
        Old 25th August 2008, 14:56   #4 (permalink)
        polar993
        Thanks guys. I'll get the car re-aligned, and have the toe adjusted. Is there an ideal setting for the toe on the 6-Series?
        New York guys.....Can one of you recommend a decent alignment shop either in Manhattan, Westchester or Greenwich, CT?
        Thanks so much!
        2006 E60 M5
        Mods:
        - Evosport Pulley
        - Aluminum Pedals
        polar993 is offline
        Old 25th August 2008, 15:52   #5 (permalink)
        unfoundhorsepower
        unfoundhorsepower's Avatar
        Stock alignments are best if wanting long tire wear..Have the entire front end checked, tie-rods ect....tire pressure and tire condition as far as belts go...a belt shift can make the car handle poorly. good luck
        See you all at the:
        Mmmmm meet...in Massachusetts, July 2009 for sure.
        unfoundhorsepower is offline
        Old 25th August 2008, 17:26   #6 (permalink)
        m5 deamon
        m5 deamon's Avatar
        Send a message via AIM to m5 deamon
        ck your control arm bushings the 20 inch wheels could have riped them or they are on their way south
        2001 m5 Carbon Black, Black sport interior, m audio
        AA cai with bmc air filters
        AA software going to change to either ess or pc
        UUC Light Weight FlyWheel And Organic Clutch
        UUC evolll ssk \ Dssr
        UUC Big Boy Clutch stop v3
        UUC Transmisson mounts
        Steelbraded clutchline
        Eisenmann Race Exhaust 83mm tips
        Supersprint X pipe
        Steel braded brake lines
        Dinan rear sway bar
        Dinan stress bars front and rear
        Tc swaybar brackets
        PS2 tires
        Axiss ult pads front and rear
        Dinan JRZ suspention kit
        Euro head lights
        Predator ice v2.1 angel eyes
        Bimmian black kidney grills
        DDM xenon fog lamps
        Solaris amber bulbs
        led lic plate lights
        v1 hardwire
        m45 blinders updated version
        To Come... dinan headers, stoptec bbk
        m5 deamon is offline
        Old 25th August 2008, 18:11   #7 (permalink)
        LI-M5
        LI-M5's Avatar
        +1000 on the copntrol aarms !! very common problem for bmw's !!
        2007 e63 amg
        iridium/blk/p30 pkg
        2006 x5 4.8is
        imola/red/blk/alum
        LI-M5 is offline
        Old 25th August 2008, 18:51   #8 (permalink)
        Barry Lausch
        Barry Lausch's Avatar
        Alignment, specifically toe in or out, control arm bushings and tie rod bushings and mechanical connections as well.
        I had a tie rod let go once upon a time...............it's not pretty!
        2008 E60 ///M5 Sepang/Sepang/Walnut
        Barry Lausch is offline
        Old 25th August 2008, 19:50   #9 (permalink)
        orlandom5
        its pobobly control arms bushings if your car pulls under acselaration
        orlandom5 is offline
        Old 25th August 2008, 19:54   #10 (permalink)
        orlandom5
        oh if you try too do alighment they might tell you its fine i had same thing on my m5 alighment was done 2 times before dealer find out it was bad bushing on the control arm
        Old 25th August 2008, 22:36   #11 (permalink)
        polar993
        Is the control arm bushing correction/replacement covered under warranty?
        polar993 is offline
        Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post! Add this post to your Facebook Profile Add this post to MySpaceStumble this Post!
