Car is "pulling" side to side while driving.....what's wrong? - BMW M5 Forum and M6 Forums
post #1 of 14 Old 25th August 2008, 06:23 AM Thread Starter
polar993
I'm on the East Coast for a couple of weeks of vacation and work, and I'm borrowing my dad's 650ci (it's actually my old car that I gave him when I bought my M5). The car seems to be "pulling" side to side very badly on the highway, especially when changing lanes. It's almost like the steering wheel has a mind of its own! It's actually quite dangerous to drive!
Does anyone know what might be causing this to happen? The car has 20" Breyton's with PS2's. Tread life is about 70% remaining on both front and rear. Stock suspension.
The alignment seems pretty straight. When the car isn't pulling side to side, it stays fairly straight.
Your thoughts on this would be greatly appreciated!
-Polar
2006 E60 M5
Sapphire Black Metallic w/Full Perforated Black Merino Leather
All Options except HUD
Mods:
- Eisenmann Race Exhaust (Quad Oval Tips)
- Evosport Pulley
- Charcoal Filters Removed
- Hartge (Front) H&R (Rear) Lowering Springs
- Hartge 21" Classic II Wheels
- Hartge Front Lip Spoiler
- Arqray Rear Decklid Spoiler
- 8,000K Hella HID's
- Aluminum Pedals
- RPI Scoops & BMC Filters
polar993 is offline
post #2 of 14 Old 25th August 2008, 07:06 AM
ThisFlyGuy
ThisFlyGuy's Avatar
ThisFlyGuy is offline
post #3 of 14 Old 25th August 2008, 07:17 AM
EM_5
EM_5's Avatar
Just cause the alignment seems straight does not mean it is correct. The toe may be off, causing the car to wander. Have a good alignment shop re-do the alignment. i am quite sure that that's your problem.
Do or Do Not. There is no Try.
///M, Faster than a speeding ticket.
EM_5 is offline
post #4 of 14 Old 25th August 2008, 01:56 PM Thread Starter
polar993
Thanks guys. I'll get the car re-aligned, and have the toe adjusted. Is there an ideal setting for the toe on the 6-Series?
New York guys.....Can one of you recommend a decent alignment shop either in Manhattan, Westchester or Greenwich, CT?
Thanks so much!
2006 E60 M5
Mods:
- Evosport Pulley
- Aluminum Pedals
polar993 is offline
post #5 of 14 Old 25th August 2008, 02:52 PM
unfoundhorsepower
unfoundhorsepower's Avatar
Stock alignments are best if wanting long tire wear..Have the entire front end checked, tie-rods ect....tire pressure and tire condition as far as belts go...a belt shift can make the car handle poorly. good luck
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline
post #6 of 14 Old 25th August 2008, 04:26 PM
m5 deamon
m5 deamon's Avatar
ck your control arm bushings the 20 inch wheels could have riped them or they are on their way south
2003 M5 Carbon Black, Black sport interior.
Evolve Alpha N tune, headers,race cats,heads
Rakkiu modified throttle bodies
Schrick cams
e46 m3 oil cooler gulf oil filter housing
Kw v3 with ground control camber plates , Dinan rear sway bar, Beast power brakets
Stop tech st 40 and st22
UUC light weight flywheel 850csi clutch, Evo3 shifter and dssr
Gas mono balls
Rouge wheel studs aluminum lugs
Vorstiner front splitters
Exotics tuning finned diffuser
Euro headlights and taillights with rear fogs
Euro arm rest
40% Lock lsd
m5 deamon is offline
post #7 of 14 Old 25th August 2008, 05:11 PM
LI-M5
LI-M5's Avatar
+1000 on the copntrol aarms !! very common problem for bmw's !!
2013 F10 M5
Apline White/Black/Black
LI-M5 is offline
post #8 of 14 Old 25th August 2008, 05:51 PM
Barry Lausch
Barry Lausch's Avatar
Alignment, specifically toe in or out, control arm bushings and tie rod bushings and mechanical connections as well.
I had a tie rod let go once upon a time...............it's not pretty!
2008 E60 ///M5 Sepang/Sepang/Walnut
Barry Lausch is offline
post #9 of 14 Old 25th August 2008, 06:50 PM
orlandom5
orlandom5 is offline
post #10 of 14 Old 25th August 2008, 06:54 PM
orlandom5
oh if you try too do alighment they might tell you its fine i had same thing on my m5 alighment was done 2 times before dealer find out it was bad bushing on the control arm
The new 7-series: official pictures Gustav GTBoard.com: General Sportscars 95 16th August 2008 12:25 AM
Article and video:: Weekend with the BMW M5 E60 [From 2005] Gustav E60 M5 and E61 M5 Touring Discussion 4 30th December 2007 10:06 PM
Travel report E34 ///M5 meeting in the Alps 1-4 Sept 2006 raymondw Most Memorable Threads' 4 10th August 2007 09:22 AM
New Owner's Review (VERY long post) 12Special E60 M5 and E61 M5 Touring Discussion 31 18th February 2006 04:22 AM
