Old 31st July 2008, 01:44   #31
VTen
Garage: None as Yet!
Jesus Christ!
VTen is offline
Old 31st July 2008, 10:22   #32
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
Originally Posted by M5Ranger View Post
Okay I say again, the stroker motor results have NOTHING to do with the stock motor results and the stock motor with mods! They are two different motors!!!
I repeat myself which pisses me off, the original motor has no relevance. The original motor may have been a monster but it is at Dinan and TMS has whatever Dinan sent them. Remember the issue of the core?
Why can anyone not realize this!!!!!!
Who the hell cares about the SSheaders and exhaust.
This motor was NOT built on the stock motor.
I did notice that on the dyno graph it said flywheel hp. This claimed 564 rwhp to me I believe is bull.
Submit more proof, not a graph that you can't read the details.
I SAY AGAIN, I DO NOT BELIEVE 564rwhp.
Ranger
Why dont you beelive it is built on the stock motor? The just bore out the cylinders, ad a crankshaft that allows more stroke and change the pistons... it is essentially the same block...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 31st July 2008, 13:58   #33
xraym5
xraym5's Avatar
Garage: E60 BMW M5 Black/Sepang
Since there are Supersprint headers added to the Dinan stroker, I wonder what software is being used. If it is Dinan's there would be an increased emissions check engine light, since Dinan's software does not disable that. If software from a vendor other than Dinan's is being used, I wonder how it works with the throttle bodies and intakes, as Dinan has parameters on their software to enhance the functionality of these mods.
I am also curious about the Dinan warranty, with the Supersprint headers, section 2, race cats, and mufflers being added to the stroker. God forbid, but if something goes wrong with the motor and Dinan somehow thinks it is due to the headers, etc., who would have to pay?
2006 M5--Sapphire black/sepang
Dinan: free flow exhaust, Stage 3 engine software, high flow throttle bodies, high flow air mass meter/intake Assemblies, stage 2 suspension, 13% underdrive crankshaft pulley, 5.7 liter stroker engine (I think I am finally done)
xraym5 is offline
Old 31st July 2008, 19:03   #34
r tuned
Garage: E60 M5
I am assuming that the warranty wont void unless if the exhaust or headers were the reason behind the damage.
r tuned is offline
Old 31st July 2008, 19:23   #35
Blockdoc
Blockdoc's Avatar
Garage: 2003 Sterling Gray M5
Hi guys,
Visiting from the E39 side...
My guess is that the customer who brought headers, TBs etc to have them installed. THEN brought a stroked motor to swap out, is in a financial position to "not really care" about the warranty.
Regardless, this sound like one hell of a Beast!
Cheers,
Brian
2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Supercharged by ESS!! (Kit number 01)
Blockdoc is offline
Old 1st August 2008, 05:25   #36
M5Ranger
Garage: 2006 M5 Alpine White
Myke, intrinsically it is not the same motor. The stock (original) motor must be sent off to Dinan and they send you another motor (the stroker).
All motors have their intrinsic characteristics, reason why same stock motors dyno differently.
If this stroker motor was built on the original stock motor then all the prior dyno results and rwhp readings would be absolutely relavent. This is not so when you switch motors.
That is my point.
I'd like someone to explain for us the results from this dyno which measures from the rear hubs with tires off.
How does this compare with Dynojet and Dynodynamic units?
Also, why does the LCD screen on the dyno say flywheel power over the dyno graph?
I would like to be informed
Another point that I have been stuck on is this. There has been a described 50 rwhp gain from the SS headers and exhaust. I find that rather lofty.
Ranger
2006 M5 Alpine White/Silverstone
Upgrades:
Engine: SS headers, Evosport power pulley, ASR ECU remap,
ASR custom air intakes, Dinan throttle bodies, ASR Engineering NOS kit
Exhaust: ASR Engineering Gen. II exhaust.
Suspension: H & R sport spings,Dinan front/rear CF strut braces.
Wheels: HRE P40 w/ 275/30/20 and 305/25/20.
Exterior: Vorsteiner CF vented hood, Vorsteiner CF front spoiler,
ACS rear deck lid spoiler, front kidney grill & side gills in CF.
Brakes: Brembo GT kit, (F) 6 piston monobloc calipers w/ 16"
rotors & (R) 4 piston monbloc calipers w/ 15" rotors.
Interior: ACS titanium CF trim.
Dyno results straight motor 460 rwhp, on nitrous 581 rwhp/461 lb/ft rw torque.
ASR TT S85 FULL ENGINE BUILD COMING
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
2010 GT3RS DEPOSIT IN FOR AN ALLOCATION
M5Ranger is offline
Old 1st August 2008, 05:48   #37
MCarRacr07
MCarRacr07's Avatar
Garage: 08 Space Grey M3
Sales Feedback: (4)
Thanks Will for the clarification.
So in a nutshell...you installed a Dinan Stroker Motor in this M6 which already had a Full SuperSprint set-up and came up with these numbers.
I only have two questions: How your particular Dyno works as opoosed to a Dynojet....AND...any ECU upgrades for the E92 M3....I checked your site and did not see anything.
S
MCarRacr
89 M3 (Track Car) SOLD
95 M3 (Track Car)SOLD
08 M3 (lil Beast)
00 M5 (R.I.P)
00 540 Sport (Gone)
03 330xi (Gone)
06 330xi (Gone)
08 328xi(New Arrival)
04 325xi(New Arrival)
MCarRacr07 is offline
Old 1st August 2008, 07:16   #38
Tiptronicsoldier
Tiptronicsoldier's Avatar
Garage: 2K6 M6 Blk/Blk
That is my point.
Ranger
To me, all the numbers stated seem ridiculously high because I've only dynoed my 6 on a dynamics and pulled 424rwhp with exhaust, ram air, no cf's, filters, and dinan software. IMO, I'd rather undershoot than overshoot, then again if I were a speed shop I'd want all the dyno numbers high. Shoot, if I had the cash to get a stroker, I'd go ahead and get that, along with headers, 3.91 rear end, and nitrous(fraction of what that stroker must cost). That would be my dream car right there
"Men wanted for hazardous journey. Small wages. Bitter cold. Long months of winter. Constant danger. Safe return doubtful. Honour and recognition in case of success." - Ernest Shackleton, Ad in London newspaper 1913 for south pole expedition.
Tiptronicsoldier is offline
Old 1st August 2008, 07:51   #39
Myke951
Myke951's Avatar
That is my point.
Ranger
Oh I always thought it was just another stock motor that they just bored out at a machine shop and added their crank and pistons... making it into a 5.7 which seems a plausible feat as it is a v-10 and has many cylinders for improvements... my stock 2.5L 944 turbo motor could have been made into a 2.7L from just boring it or a 3.0L from stroking and boring... .5L difference in only 4 cylinders makes it pretty plausible to get .7L outr of a v10... Can a dinan representative shed light on this?
Myke951 is offline
Old 1st August 2008, 08:17   #40
DRM
DRM's Avatar
Garage: 2002 M5 (Chiaretto Red Metallic)
'Not a Dinan rep, but 'been there and saw the motor being developed. Here's a good description of it from their website; including what internal components are changed: 6 Series*::*M6 (E63) 2006-2008*::*Engine Tuning*::*High Performance 5.7 Liter V-10 Engine It's definately a "core exchange" program. They sell you a completed 5.7 litre balanced and blue printed, tested on their engine dyno, motor; your 5 litre motor is returned to them.
Dan
______________________________________________
Daily Driver
'02 M5 (Chiaretto Red Metallic w/black napa full heritage leather/wood trim/leather Euro cntr console/BSW speakers and sub) Sig series Dinan S/C'd S3 package/ Dinan S3 clutch-flywheel/Dinan high capacity oil cooler /Dinan forged aluminum wheels/Dinan SSK/Dinan - Brembo BBK/Stg 3 Dinan - JRZ suspension/monoballs/275-35-18 RA 1's all around
The "Predator"
'02 996TT w/X50 (slate grey metallic w/full natural grey leather, small carbon package, aluminum trim pieces, exterior color painted wheels, etc, etc).
EVOMS Stage 4 (640hp/615tq)
PSS9 w/F&R H&R sways and EVOMS F&R shock tower braces
Sachs clutch and Porsche SSK
Toyo RA-1's 245/18 fronts; 305/18 rears
DRM is offline
The Following User Says Thank You to DRM For This Useful Post:
Myke951 (1st August 2008)
Tags
bmw m5 m6 dyno video
Dinan 5.7 liter V10 in E39 m5? Jayson E39 M5 and E52 Z8 Discussion 30 5th September 2008 05:50
Press Release no 2: The new V10 Power Unit in the BMW M6: A Masterpiece in Engine... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:15
Page generated in 0.17559 seconds with 12 queries
