Old 3rd July 2008, 20:46   #1
Rambino
Rambino's Avatar
Garage: M6
12mm spacers all around too much?
I had a set of 12mm HR Spacer with longer lugs laying around from my 335.. I put them on my M6 to clean up the look and improve handling.. I know some people just put them on the front to diminish understeer and others use them to make aftermarket wheels fit right, but Im keeping the stock wheels. I also apply them all around to keep the vehicle dynamics similar and also widen my track.. I noticed a great improved handling feel esp. at high speeds and a much more stable ride not to mention the wheels are now flush with the fenders which looks great....
I am however worried that by putting 12mm all around, I may be stressing the stock suspension and putting stress on bearings and areas where it was not designed.. I was considering dropping down to 10mm all around. Should I really be concerned about this.
Rambino is offline
Old 3rd July 2008, 20:59   #2
carlsturm
Garage: 06M5.Silver-03M3.Red
If you do it - I'm subscribed for the pics.
06M5 Silver
carlsturm is offline
Old 3rd July 2008, 21:03   #3
r tuned
Garage: E60 M5
If I was you i would add pictures of your car and the spacers installed to get quicker attention
pics pls
r tuned is offline
Old 3rd July 2008, 21:18   #4
Rambino
Rambino's Avatar
Garage: M6
Ok Ill get pics.. But the real question is.. Is adding 12mm spacers all around going to cause me problems because im altering the suspension load points...
Rambino is offline
Old 3rd July 2008, 22:24   #5
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
12mm is pushing them out !!1 they are of course hub centric, right ???
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline
Old 3rd July 2008, 22:42   #6
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
With stock wheels and tires, the 12mm rear spacers may require you remove material from the inside of the wheelwell. I've been running H&R springs and spacers (12mm front, 10mm rear) on the stock wheels/tires for over 50,000 miles and dozens of track sessions with no problems whatsoever.
2006 E60 M5 Silverstone II/Silverstone/Aluminum, All Options, 35% tint, Aluminum Pedals, Valentine V1 and Passport 9500i Hardwired, Blinder Xtreme M40, Michelin PS2's on 20 inch BBS RS-GT's, Winter Pirelli Sottozeros on OEM 19 inch wheels, Resonator Delete, Charcoal Filters Removed, Eibach Springs and Spacers, Active Autowerks ECU, BMC Filters, RPI Air Intakes, Evosport Pulley. Retired from track duty 10/08. Dinan diff replaced with OEM at my cost due to failure at 56,000 miles.
Wolverine is offline
Old 3rd July 2008, 22:42   #7
///Bruno
Garage: 2007 E60 M5 Silver-Gray
Do it.
///Bruno is offline
Old 3rd July 2008, 23:14   #8
CBarton
CBarton's Avatar
Garage: 2006 Black M5
Sales Feedback: (3)
you are not stressing the suspension components any more than by changing to wheels with the same amount of offset......
Chris Barton
2006 M5 Singh ECU, Miro 20's, H&R, Dinan, ACS Style Rear Window / Trunk Spoiler, Evo, More to come
2001 996TT Stage 4 - 600hp - Sold
2001 F250 10" Lift, Many Mods, Toy Hauler
1966 GT 350 Replica-427 SBF 570hp
1983 GS 1100E Built just right...
2003 ZRX 1200 Many Mods
1974 H2 750 - Lotsa fun!
CBarton is offline
Old 4th July 2008, 00:27   #9
Glock 32
Glock 32's Avatar
Garage: Sapphire Black 2008 M5
I am not so sure 2mm makes that big of difference since some of the aftermarket wheels offsets (i.e. HRE) I have seen would push the wheel face out as much as 18mm on the rears and apparently the owners experience no rubbing...
Keep in mind 12.7mm is only 1/2" so 3mm is roughly equal to 1/8" so we are talking less than 1/8" here being the difference between 10mm and 12mm spacers.
Has anyone actually tried a 12mm spacer on the rear and experienced rubbing? This would worry me as the wheels I have coming and my calculations say would equate to the wheel being pushed out 18.35mm.
This was discussed in the thread on tightie's KW's that I guess I kind of jacked (looking back).
http://www.m5board.com/vbulletin/sho...5&postcount=63
Glock 32 is offline
Old 4th July 2008, 00:35   #10
keang24
keang24's Avatar
Garage: E60 M5 SG
For normal driving/safety are concern regarding addtional stress on suspension, I think spacer up to 20mm is safe. Remember vaguely from one of the post from NobleM400
Edit: for tracking purpose, member Cosmos told me to remove spacer for tracking, but didn't explain why, still curious about that too, anyone?
The Good Die Young
R.I.P. BALL...11/15/88-06/22/06
keang24 is offline
3mm spacers.. aluminum or steel? rroberrto E39 M5 and E52 Z8 Discussion 5 17th May 2008 22:15
One size fits all lug bolts for my new 6061-T6 spacers? (Rogue Engineering) EM_5 E60 M5 and E61 M5 Touring Discussion 28 25th March 2008 22:45
H&R 10mm and 12mm wheel spacers: Weight? tonyracerX E60 M5 and E61 M5 Touring Discussion 3 15th March 2008 23:08
E39 12MM wheel spacers Chart505 For Sale or Wanted 1 21st July 2006 00:41
Wheel Spacers Mel A E34 M5 Discussion 1 21st April 2000 18:05
Page generated in 0.20987 seconds with 11 queries
