Old 23rd July 2008, 19:16   #21
Cosmos
Cosmos's Avatar
Garage: has lots of porn
Sales Feedback: (3)
I look at it this way. You know when you take a stack of paper cups and the top cup is wobbly, but the first few cups are secure. Well, having a wheel with the proper offset of like having two cups, (have to count the hub as a cup) having a spacer and a wheel is like having three cups. There is almost no wiggle, but why stress it if you don't have to. Also the heat from the track sometimes warps the spacers and then make them almost impossible to take off.
I was watching lots of guys pull off the track and just park their cars, so cooling off the brakes and engines did not even enter into their minds.
The size of the spacer should not really matter, whether it is 10mm or 30mm, ( what is 1/2") the stress is there. I actually like the H&R DRE system. They are a large spacer, 25mm and more. This bolts to the hub and then the wheel bolts to the DRE system. You use the same wheel bolts. I think it is a more solid extension of the hub, think of it as larger cup now.
"Motion does not equal progress"...Cos
Malo periculosam libertatem quam quietum servitium...
Cosmos is offline
Old 11th January 2009, 13:08   #22
DOUL
DOUL's Avatar
Garage: M5 E60 Black Sapphire - SMG
Mods please delete this post. Thanks
Modifications:
  • Engine: RPi / PC Stage 2 ECU Software, RPi ST Underdrive Pulley Kit, RPi Ram Air Intake Kit (Black) & Block Off Plates, RPi SV1 Oil Cooler (Black), M-Sprint Booster
  • Exhaust: RPi GT Headers, RPi Hybrid X Pipe Section 2, RPi GT Section 3
  • Exterior: Vorsteiner CF Vented Hood, RH Type CF Splitter, Upper CF Mirrors, CF Side Skirts, CF AC Schnitzer Style Trunk Spoilers, CF Side & Kidney Grills, Black Powder Coated Lower RaceMesh Grille, CF Pillars, all Roundels in CF, Red Angel Eyes, OEM Smoked Tail Lights, Smoked Side Markers, Brake Calipers Painted in Red with CF ///M Decal
  • Interior: Custom CF Lower Steering Wheel, CF Interior Trim, CF Handbrake, CF Gauges Trim, CF Door Pins, Illuminated Door Sills, OEM Aluminum Pedals
  • Wheels: OEM Blacked Out Rims with Michelin PS2 Tyres (Front: 255/40-19 Rear: 295/30-19), H&R Spacers (12mm Front)
  • Suspension: H&R Lowering Springs
  • Miscellaneous: V-Kool Window Tints
DOUL is offline
H&R 10mm and 12mm wheel spacers: Weight? tonyracerX E60 M5 and E61 M5 Touring Discussion 5 14th February 2010 11:27
3mm spacers.. aluminum or steel? rroberrto E39 M5 and E52 Z8 Discussion 5 17th May 2008 22:15
One size fits all lug bolts for my new 6061-T6 spacers? (Rogue Engineering) EM_5 E60 M5 and E61 M5 Touring Discussion 28 25th March 2008 22:45
E39 12MM wheel spacers Chart505 For Sale or Wanted 1 21st July 2006 00:41
Wheel Spacers Mel A E34 M5 Discussion 1 21st April 2000 18:05
Page generated in 0.13291 seconds with 11 queries
