Change Brakes? - BMW M5 Forum and M6 Forums
Old 9th June 2008, 14:16   #1
vinid_1
Garage: E60 M5 Silver Grey/Black interior/Alum finish
Change Brakes?
For the last month or so I've been hearing a squealing from at least one the brakes at any speed and any braking force. I took the car to the dealer, they charged me 75$ just to tell me that the brakes are fine there's still 9mm left in the front and 10 mm left in the back. The brakes don't feel right to me, I'm debating to go to a different dealership, I really want to change the brakes, has anyone else had a similar situation?
vinid_1 is offline   Reply With Quote
Old 19th June 2008, 02:28   #2
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
THat is annoying that they charged you for that.
I would not worry about squeal, rather by vibration.
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
Old 19th June 2008, 04:18   #3
ttaillon
ttaillon's Avatar
Garage: 2007 Black M5 (Gone)
Check out this website...
http://www.zeckhausen.com/bedding_in_brakes.htm
Dave Zeckhausen is a board sponsor and a bit of a resident expert on brakes. He was kind enough to spend some time on the phone with me explaining the bedding process, incompatible materials, etc.
My point, and relevance to your question, is it is possible you are not braking hard enough to leave any pad material on the rotors, and essentially have pad against metal rotor (and hence a squeal). I don't want to bore you with all the details if you aren't interested (you can read through his website). But the bottom line is if you drive conservatively all the time and scrub off the pad material from your rotors without ever replacing it (through bedding), you could end up with a squeal. If your rotors are all shiny (no bluish tint), try bedding the brake pads in.
ttaillon is offline   Reply With Quote
The Following User Says Thank You to ttaillon For This Useful Post:
MrCSL (19th June 2008)
Old 19th June 2008, 04:43   #4
roja
Garage: 2008 BMW M5 -- Alpine White
wow. i never knew that was an actual documented process. i've done it since i was younger and felt the improvement in performance and longevity of my brakes. it started out as trying to get rid of the squeal. I have done it on all my cars since and it's proven well. "bedding" haha, now i know. and knowing is half the battle. hahah. i need a drink.
roja is offline   Reply With Quote
Old 19th June 2008, 05:21   #5
roja
a little off the original topic, but has anyone upgraded the brake lines, fluid, and pads? i'm looking into doing this and found a kit from Stoptech-Stage 1. i don't know the stock setup specs, and am wondering if this would work. anybody been here?
Old 19th June 2008, 05:49   #6
MrCSL
MrCSL's Avatar
Garage: E46 M3 CSL Grey, E61 M5 Touring Alpine White
Excellent information, perfect for me to bed-in the brake on my new car. Thanks
_____________________________
85 E24
///M635csi Diamond Schwatz
96 E36 ///M3 EVO 6Sp Alpine White
99 E36/6
///M Roadster Arctic Silver/Black
03 E46 ///M3 CSL Silver Grey
08 E61
///M5 Touring Alpine White
MrCSL is offline   Reply With Quote
Old 19th June 2008, 16:03   #7
ttaillon
ttaillon's Avatar
I went with stainless steel lines picked up from Zeckhausen (I really don't work for them!) to give me a more firm pedal 'feel'. I believe they were StopTech brand. I like that firm response. It also really helps with heel-toe downshifting if you have a 6-speed, although I have a SMG and that's irrelevant.
Stock fluid is fine unless you track your car, in which case something like Motul 600 or other higher temperature fluids helps prevent boiling. The stock fluid is actually pretty good by street standards. If money isn't an issue and you want the best, put in Castrol SRF. To compare in liters, BMW is about $10 per liter (comes in 12oz bottles), Motul is about $30 per liter (comes in half liters), and Castrol SRF is about $80 per liter.
For pads, I don't know any option for the E60 M5 (stock calipers) besides the Pagid Yellow, which you do not want on the street. They squeal REALLY bad, but are a great track option (at $750 I might add).
Please post any information you have about this StopTech 'kit'.
The Following 2 Users Say Thank You to ttaillon For This Useful Post:
Carl Lassiter (19th June 2008), roja (19th June 2008)
Old 19th June 2008, 22:09   #8
roja
Looking at the kit again, it doesnt apply to the e60 m5. Only brake lines are available. I'll get those. and some fluid.
Weird Brake pedal feel. mruiz0280 E39 M5 and E52 Z8 Discussion 27 23rd November 2006 20:43
Squeeky brakes / wheels = £200 ($380) strip down! scoopz E60 M5 and E61 M5 Touring Discussion 11 8th November 2006 01:39
Naka's DIY oil change M-Fünf E39 M5 and E52 Z8 Discussion 45 27th May 2006 10:47
Squealing Brakes Tradeur E60 M5 and E61 M5 Touring Discussion 5 22nd December 2005 19:57
Movit GT2 Brakes! JPK//E28M5 E34 M5 Discussion 3 14th May 2000 19:57
