Old 28th April 2008, 03:40   #1
paradocs98
paradocs98's Avatar
Garage: 08 M5 Int blue
Front tire rubbing w/ 20in wheels
Hi everybody--I've had my 20in BBS LM wheels and Dinan stage 2 suspension for a few weeks now, and I've started to notice worse tire rubbing in the front on turning the steering wheel. I had no rubbing whatsoever when the suspension was first installed, but I guess the springs have settled over time. There is no rubbing with the wheels pointed straight ahead or over bumps, but when the wheel is turned to go around a 90-deg corner, say in a residential neighborhood or parking lot, I hear a nasty rub from the outside front part of the front tire against the inside plastic fender liner. The liner seems to be smooth and flexible, so I assume I'm not doing a lot of damage to the tires, especially since it occurs during 20mph maneuvers, but it sure is annoying. Anyone else have this issue? Suggestions? Thanks.
paradocs98 is offline
Old 28th April 2008, 04:04   #2
bodaddy
bodaddy's Avatar
Garage: 2007 BMW M5 Black Sapphire
Could be a problem with one of your front Dinan Springs. I know a few members have had spring defects where the spring compresses and doesn't fully rebound. If the spring doesn't rebound completely you could definitely have some rubbing.
'07 M5 Black Sapphire
Evosport Pulleys, Charcoal Filters out, BMC Filters, RPi Scoops & Block-off Plates, RPi ST Sec 1, RPi GT Sec 2 & 3, RPi R2 ECU, 20" HRE P40s w/ Michelin PS2s, Dinan Stg 2 Suspension, AIB v3.0, Hardwired V1 w/ concealed display, Black Kidneys & Sides, Bimmian Interior Xenon Kit, Hartge pedals & e-brake, Luminar tint
'04 Mercedes G500
'02 M3 (gone but not forgotten)
bodaddy is offline
Old 28th April 2008, 05:31   #3
ThisFlyGuy
ThisFlyGuy's Avatar
Garage: 2006 BMW Interlagos Blue M5
what size are you front tires?
2006 BMW M5
ThisFlyGuy is offline
Old 28th April 2008, 17:10   #4
paradocs98
paradocs98's Avatar
Overall rolling diameter is the same as stock--255/35-20 PS2s in front. The LMs do require a 10mm spacer in front to clear the struts, so the wheel is pushed further out than stock--I think by 12mm or so.
295/35/ZR18 on stock rear wheel? M5girl E39 M5 and E52 Z8 Discussion 40 27th March 2009 18:26
Alpina B8 Brake pads CHEAP! mill ALPINABoard.com | BMW Alpina Discussion 50 13th May 2008 12:28
Hunter has a New way to balance tires... Ocean's M5 E39 M5 and E52 Z8 Discussion 7 24th July 2007 03:42
BMW Alpina B5 configurator Gustav ALPINABoard.com | BMW Alpina Discussion 12 7th June 2007 19:47
Page generated in 0.10355 seconds with 11 queries
