Old 14th April 2008, 08:37   #81
DLSJ5 M3
DLSJ5 M3's Avatar
Garage: E92 M3
Originally Posted by ///WALL_ST View Post
Drew,
Email me your dyno plots from 3 consecutive pulls within 5 minutes and we can talk.
Sounds like a plan, I'll see if I can get the Mustang results too, but those were pre Final tuning, still they'll show any power difference between runs. If I can't get any now, then I'll make sure to post three consecutive runs up from the dyno day that we plan on doing with an assortment of cars. Maybe NAmotorwerks will post their's up as well.
EDIT:
I just found the sheet from one dyno day on a Mustang at Harman Motive, that we had with some p-cars. Unfortunately my car would not go past 7400RPM's, so I wasn't able to achieve peak power #'s. However I did do back to back to back runs, all within 5 minutes. These are BETA Stage 2 #'s with less boost, and not final tuning. I need to scan the dyno sheet but here's the #'s, and you can see that heatsoak was not an issue for me.
Run 1 at 12:19:44 408WHP and 317WTQ, it only went to 7350 RPM's
Run 2 at 12:21:40 408WHP and 314WTQ, it only went to 7400 RPM's
Run 3 at 12:23:54 410 WHP and 316WTQ, it only went to 7300 RMP's
Most likely I would have hit 430 - 440WHP, like I did on another Mustang a few weeks earlier.
Some other cars that dynoed at the D-day as well.
Stock 996TT 338AWHP and 348AWTQ
Stage 1 996TT 383AWHP and 416AWTQ
Stage 2 996TT 404AWHP and 403 AWTQ
Stage III, K24'd 996TT, bolt on's, on race fuel 440AWHP and 488AWTQ.
GT2 996TT with FVD Stage 4 flash, bolt on's, on pump fuel 429WHP and 453WTQ RWD car
GT 700, twin GT28's, 996TT on 100 octane, 504AWHP and 545AWTQ
Stage 3 S4, 420AWHP and 450AWTQ
I'll scan the sheet with the 3 runs, or possibly get the plots from Harmann Motive and email them to you. I did dyno on another Mustang, I'll see if I can get those too, all runs were around 430-440WHP on that Mustang and we did a bunch of pulls, they have moved locations, but hopefully all the plots are still in their database.
Current - E92 DCT M3 - Encore Innovation x-pipe w/HFC's - GIAC ECU Flash - Rogue Pulley - VFE Filter - 363whp
60-130MPH - 3 shifts - 10.80
Previous - E46 M3 ZCP SMG - VFE Stage 2 SC
Best Boosted ET 11.58@ 122 MPH
Best Trap 2+ 124.8
60-130 - 2 shifts - 8.6
DLSJ5 M3 is offline
Old 14th April 2008, 17:29   #82
Fubar
Fubar's Avatar
Garage: 2006 M6 - Black
Drew, it's so much easier when you are just helpful.
Cheers mate.
Fubar is offline
Old 15th April 2008, 07:18   #83
DLSJ5 M3
DLSJ5 M3's Avatar
Garage: E92 M3
Scott,
Here's your 3 runs overlayed with my 3 runs. Two of my runs are consecutive within a minute of each other, the 3rd was done 10 minutes later, regardless my runs are very consistent compared to yours, I"m not loosing any power. After each run your car is definently losing power, ALSO and this is more important when you look at the area under the curve compared to mine, your car is falling apart even early on in the p-band, and your TQ is not flat to redline. Based on the AFR's from the DD's, your car is most likely dumping fuel, probably because you are heatsoaked. This is more likely why in the first two runs you beat the M5, then started to fall back afterward, forget about Mark's Ford GT, you'll never beat that with your M3, nor will I, lol.
Either way it seems your kit was installed improperly in some fashion or the product is defective in some way. I don't know, but cleary your car has issues and is not running right. I've also added the INDEPENDENT Mutang dyno, 3 back to back to back runs, which I posted above from the Dyno Day as evidence that my car is not getting heatsoaked like yours, also remember I couldn't go past 7400 on the Mustang, the car was going into limp mode. I hope this helps Scott.
My runs, with timestamps, 91 octane VF Stage 2.
My plots overlayed with yours.
3 consective runs from the Dyno Day mentioned above, 7400 limit, BETA Stage 2 pre final tuning, slightly less boost, 3 runs back to back to back, it almost looks like only 1 run took place they are so consistant.
Best Trap 2+ 124.8
DLSJ5 M3 is offline
Old 15th April 2008, 09:22   #84
DLSJ5 M3
DLSJ5 M3's Avatar
Garage: E92 M3
More Data Scott.
Here's our graphs with the raw data, no smoothing factor, you can see how spikey your plots are in comparision.
Here's our highest #'s.
Here's our lowest #'s.
Best Trap 2+ 124.8
DLSJ5 M3 is offline
Old 15th April 2008, 10:19   #85
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Drew,
I think this is exactly the type of constructive, thoughtful insight & help Scott has been looking for this entire time.
Kudos to you for pulling together this information. I look forward to future posts from you which add this level of value to the board.
Darren
2008 M5 Interlagos Blau 5.7L Stroked
2008 X5 4.8i Alpine Weiss
darren_dallas is offline
Old 15th April 2008, 17:45   #86
Fubar
Fubar's Avatar
Originally Posted by DLSJ5 M3 View Post
What does he make to the wheels with those mods, smaller pulley, etc.?
I am taking up to Classic BMW's DD machine tomorrow morning. Anyone in the area who would like to watch... it should something to see. I think you might actually need the ear plugs for this one.
This was my last Dyno Jet run.
Fubar is offline
Old 15th April 2008, 18:52   #87
DLSJ5 M3
DLSJ5 M3's Avatar
Garage: E92 M3
Originally Posted by darren_dallas View Post
Drew,
Darren
Darren, I appreciate that. Hopefully this data will shed some light on Scott's situation.
Best Trap 2+ 124.8
DLSJ5 M3 is offline
Old 15th April 2008, 18:54   #88
DLSJ5 M3
DLSJ5 M3's Avatar
Garage: E92 M3
That thing is a flat out beast!!!! More vids please! Stock I think they make around 515 WHP on a dynojet, very nice Mark!!
Best Trap 2+ 124.8
DLSJ5 M3 is offline
M3 Test Drive (vs. 335xi and M6) T Bone E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 8 18th April 2008 15:02
M3 Test Drive (vs. 335xi and M6) T Bone M6 E63 Group Buy and Sponsor Discussion and Offerings 1 3rd April 2008 01:31
BMW M3 - english pressrelease (with lots of pictures) kees E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 43 18th May 2007 15:09
E60 M5 gear ratio equal to E46 M3? jerka E60 M5 and E61 M5 Touring Discussion 0 16th September 2004 14:02
Page generated in 0.77582 seconds with 11 queries
