Just in case anyone is interested in where the drilled discs can crack.
If you are very hard on your brakes you will eventually get hairline cracks radiating from the drilled holes which is exasperated by the holes getting clogged.
This happened to my brothers cosworth with a BBK many years ago, he just kept replacing the discs. No idea why he didn't buy slotted
Obviously different pads may reduce the holes getting clogged in the first place which would help.
Never had an issue with clogged holes with stock discs / pad combo even on a track.
If you are going to seriously abuse your brakes, go with slotted discs.
The brake discs will loose most of the heat through the viens that radiate out from the centre to the edge in the middle of the disc, so I don't believe there is much difference in heat performance between the slotted and drilled.
Another plus for the slotted disc is that they are supposed to improve the initial bite, though I've never swapped discs on a car with the same set-up so have no idea if this is true.
