• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 28th February 2008, 23:06   #1 (permalink)
          BD 997
          BD 997's Avatar
          Vibration at steering wheel -help-
          I'm having a little vibration at the steering wheel at speeds over 50mph... Its not bad but a little noticable. I just had my guy check everything under the car and everything is nice and tight. I had it aligned last month after installing h&r springs. I installed spacers after the alignment. Anyone have any ideas of what it could be? Much appreciated!
          BD 997 is offline
          Old 28th February 2008, 23:18   #2 (permalink)
          T Bone
          T Bone's Avatar
          If it occurs consistently around the same speed, sounds like your front wheels are out of balance.
          "Aerodynamics are for people who cannot build engines"...... Enzo Ferrari
          T Bone is offline
          The Following 2 Users Say Thank You to T Bone For This Useful Post:
          BD 997 (28th February 2008), unfoundhorsepower (29th February 2008)
          Old 28th February 2008, 23:20   #3 (permalink)
          Carbon Black
          need a new alignment and also check tire pressure
          Carbon Black is online now
          The Following User Says Thank You to Carbon Black For This Useful Post:
          Old 28th February 2008, 23:23   #4 (permalink)
          LJM5
          LJM5's Avatar
          Most likely an out of balance front tire. Have them rebalanced, and only on a ride-matching load bearing Hunter balancer. Discount tire uses them if you request, or most other big tire chains. YOu have to ask around or request it.
          2007 E60 ///M5:Silverstone Silver/Indy Red/Aluminum
          2006 E60 550i: Monaco Blue/Auburn/Anthracite Maple
          LJM5 is offline
          The Following User Says Thank You to LJM5 For This Useful Post:
          Old 28th February 2008, 23:30   #5 (permalink)
          BD 997
          BD 997's Avatar
          ok... so check the balance and alignment...
          BD 997 is offline
          Old 28th February 2008, 23:37   #6 (permalink)
          T Bone
          T Bone's Avatar
          Dont bother checking the alignment.
          You wouldn't have snow or mud in your wheels would you?
          T Bone is offline
          Old 29th February 2008, 00:41   #7 (permalink)
          M5 Rocks
          I went through this w my e39. i checked balance, pressure, tire wear, rims, and all the other infrastructure btw wheel and car. Turned out i needed new bushings even though a visual inspection suggested they were fine. Good luck!
          M5 Rocks is offline
          Old 29th February 2008, 01:41   #8 (permalink)
          BD 997
          BD 997's Avatar
          nope... Happens even right after a wash
          BD 997 is offline
          Old 29th February 2008, 01:43   #9 (permalink)
          BD 997
          BD 997's Avatar
          New bushings? I only have 2,450 miles
          BD 997 is offline
          Old 29th February 2008, 01:47   #10 (permalink)
          T Bone
          T Bone's Avatar
          You could have easily knocked off a wheel weight. I would bet mega dollars on your front wheels being out of balance.
          T Bone is offline
          The Following User Says Thank You to T Bone For This Useful Post:
          BD 997 (29th February 2008)
          Old 29th February 2008, 02:02   #11 (permalink)
          Barry Lausch
          Barry Lausch's Avatar
          +1 Absolutely...........I'll bet a cheeseburger
          2008 E60 ///M5 Sepang/Sepang/Walnut
          Barry Lausch is offline
          The Following User Says Thank You to Barry Lausch For This Useful Post:
          Old 29th February 2008, 02:04
