Problem on Brembo BBK - BMW M5 Forum and M6 Forums
Old 27th February 2008, 11:42   #1
HS_01
Garage: BMW M6
Hi Guys,
Just want to share some experience on my Brembo Front 8 Piston and Rear 4 Piston.
I took my car to the track. I stopped the car everytime after 3-4 laps. Total probably 10-12 laps.
After the session, everytime I brake, it makes very loud sound on the brake.
I checked to the dealer. The results, all the front pads (total 8 pcs) are cracking. Rear was okay. I'll post some pics.
Any idea?
BMW 645 ci conversion to M6. HRE 590R 21" or BBS CK 20", H&R Sway Bars, RPI GT Exhaust System, RPI Pulley, RPI Scoop, BREMBO BBK Front 8 Piston, Rear 4 piston.
HS_01 is offline   Reply With Quote
Old 27th February 2008, 13:47   #2
Gustav
Administrator
Gustav's Avatar
Garage: BMW M3 DCT Sedan / Limousine
Maybe you haave street pads? You should change to racepads!
Google+ LinkedIn Facebook Flickr
My email gustav@gtboard.com m5board Member visiting Stockholm, Sweden? PM me to and I'll show you Stockholm! gtboard.com
Gustav is offline   Reply With Quote
Old 27th February 2008, 14:03   #3
DZeckhausen
DZeckhausen's Avatar
Garage: 2012 328i 8-Speed, Mineral Grey Metallic
Clearly you've exceeded the maximum operating temperature of those pads. My suggestion is to run different pads on the street from the track.
Centric makes an excellent low-dust, low noise pad for that caliper - the Posi-Quiet Semi-Metallic. It was designed for the Audi RS4, so it comes with an integrated brake wear sensor and harness. You can either cut off the sensor wire, or you can splice a BMW sensor harness into it and retain the dash warning for low brake pads. These pads are far less expensive than the street pads sold by Brembo for your BBK.
For the track, I suggest the Ferodo DS2500. In a strange departure from standard practice, you will need to purchase TWO boxes of Ferodo pads to fill both calipers. Each box only contains four pieces and you need a total of eight pieces.
These pads can be purchased on-line here: http://store.zeckhausen.com/catalog/...hp?cPath=82_83
When swapping back and forth between street and track pads, follow these instructions to avoid brake judder issues: http://www.zeckhausen.com/avoiding_brake_judder.htm. If you have any questions, email us at orders@zeckhausen.com or give us a call. We'll be happy to help.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed (Sold)
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
2012 BMW 328i Luxury Line, 8-Speed
DZeckhausen is offline   Reply With Quote
Old 27th February 2008, 14:53   #4
6speed
6speed's Avatar
Garage: 1984 Escort GT (loaded)
^^^^^ As always, great info ^^^^^
Cheers ///
6speed is offline   Reply With Quote
Old 27th February 2008, 15:02   #5
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
Remember, tell Brembo you broke the pads in BEFORE you went to the track....so they won't hassel you about your return....funny this happened, did you have racing tires on the car ??
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
Old 27th February 2008, 17:34   #6
HS_01
Garage: BMW M6
Gustav,
I think mine are street pads. Several years ago, I did try my E-46 M3 on the track. It was also equipped with Street pads, Front 4/6 Piston (not sure, forgot already), Rear 4 Piston. I did more laps, and I pushed it even harder than this time. No problem at all. Very weird. Maybe I should change it to race pads.
Old 27th February 2008, 17:45   #7
HS_01
Garage: BMW M6
Wow... Great info. Really appreciate it.
Any idea the disadvantage if I use track pads on regular or street driving?
I rarely go the track, probably once a year, only on some special events.
Weird thing, my friend gasterus (active member on this board also) was driving his M6 at the same time. Same laps, we were probably neck to neck. I know his car was much faster than mine His car was fine. No problem at all with stock M6 brake system. I also tried his car, and I felt the Brembo's are much better.
Isn't Brembo should be more reliable than the stock M6 brake? Just curious.
Thanks....
Old 27th February 2008, 17:49   #8
Cosmos
Cosmos's Avatar
Garage: has lots of porn
Sales Feedback: (3)
Listen to Dave.
Also bed your pads in next time.
And for your friend, you could just be not as good as a driver. Brakes are NOT meant to stop a car on a race track, they are meant to keep the car balanced going around the race track.
Think of the track as a river and you must flow through it, not try to attack it.
"Motion does not equal progress"...Cos
Malo periculosam libertatem quam quietum servitium...
Cosmos is offline   Reply With Quote
Old 27th February 2008, 18:45   #9
trol
trol's Avatar
Garage: M5 E60 Black
Words of wisdom.
“When fascism comes to America, it’ll be wrapped in a flag and carrying a cross” — Sinclair Lewis
trol is offline   Reply With Quote
Old 27th February 2008, 19:56   #10
M5Ranger
M5Ranger's Avatar
Garage: 2006 M5 Alpine White / 2006 M5 Saphire Black
I thought that the Brembo kit for our cars was front calipers 6 pistons and rears 4 piston? That's what I have and at time of purchase there was no other set up. These are the monoblok aluminum calipers right?
2006 M5 Alpine White/Silverstone : car and project are dead. RIP
2007 GT3RS ORANGE / BLACK
2006 M5 BLACK / BLACK
FORGED IN A FIRE LIT LONG AGO, STAND NEXT TO ME, YOU'LL NEVER STAND ALONE. FIRST IN, LAST OUT.
YOU DON'T ALWAYS KNOW WHERE YOU STAND, TILL YOU KNOW THAT YOU WON'T RUN AWAY.
YOU HAVE ENEMIES? GOOD. THAT MEANS YOU'VE STOOD UP FOR SOMETHING, SOMETIME IN YOUR LIFE.
W. CHURCHILL
SOCIALISM IS A PHILOSOPHY OF FAILURE, THE CREED OF IGNORANCE, AND THE GOSPEL OF ENVY, ITS INHERENT VIRTUE IS THE EQUAL SHARING OF MISERY. W.CHURCHILL
A wise and frugal gov't, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good gov't. Thomas Jefferson ...
M5Ranger is offline   Reply With Quote
