LinkBack Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10th November 2008, 14:51   #61
scoopz
scoopz's Avatar
Garage: BMW M5 E60, Silverstone/Silverstone Full Perf
Send a message via AIM to scoopz Send a message via Skype™ to scoopz
Originally Posted by MiamiDave View Post
Just thought I'd add to the thread:
My U.S.A. LC became operational around 1250-1300 miles, and on a tight engine with just CF removed, even at 80% on the gas pedal (floor to click, back off of click and remove a bit) all I get is a smoke show through first.
I think I need to go from 75% down to 50%, than roll back on it to WOT as the tires hook.
I really don't see how launching at higher rpms will work with stock tires, but for sure give less gas if I ever want to hope of an effectively launch it.
I'm not sure how it works for US spec Launch Control, but for Euro LC, if you don't keep your foot 100% planted (on the little click button) the whole time even after launch then LC will disengage and all you will get it tyre smoke. Even though the DSC is off for launch control, the LC monitors the amount of wheel spin and limits it by modulating the clutch until the tyres bite, so if you come off full throttle (the click) on Euro spec LC to say 80% throttle to try and limit spin then that's the end of LC and you're stuck trying to feather the throttle to limit spin manually.
What happens if you use your US launch control and just keep your foot planted, does it eventually sort itself out or do you just get spin, spin and more spin?
2005-12 E60 M5 :: Silverstone :: Silverstone Full Perforated
Delimited :: Twin rear screens + PS2 + DVD :: Origin B2+laser detect :: Pentagon Security Glass
My Sites :: Twitter :: Blog :: YouTube :: Coopers
scoopz is offline
Old 11th November 2008, 08:58   #62
ppatel9
ppatel9's Avatar
Garage: 2006 Altima S
Send a message via AIM to ppatel9
Damn.....excellent write up. This should be a sticky.
ppatel9 is offline
Old 11th November 2008, 12:36   #63
scoopz
scoopz's Avatar
Thanks It's been added to the FAQ sticky, which if you've not seen is definitely worth a look at.
scoopz is offline
Old 12th November 2008, 06:06   #64
MIA-M5
Garage: 07 Saphire BLK M5 SMG
Originally Posted by monmart2 View Post
By the look of the videos it should be called "Lunch Control".
lol
MIA-M5 is offline
Old 15th November 2008, 17:03   #65
Burnin M
Burnin M's Avatar
Garage: '08 M5 Indianapolis Red
Yeah, I just finally tried this (7,000 miles) and while LC works exactly as indicated, it simply smokes the tires. No point whatsoever, if I used this to race someone from a light, I'd just sit there spinning. I can't comprehend how LC in Europe would work if it revs to 3,500-4,000rpm, if mine is smoking tires at 1,500rpm. Seems like it would be better to ease off throttle or and feather or something...
All you US M5's - what do you guys do? After market wide wheels with stickier tires?
2008 M5 Indianapolis Red Metallic, Silverstone interior
2007 X5 4.8i Space Grey Metallic, 20" OEM's, Sport
Previous rides:
2007 335i, Saphire Black Metallic, sport, 6spd manual, loaded
2003 M3 Coupe Silver/Grey - 6 speed
Imola Red interior, 19" OEM's, NAV, H/K stereo
'03 Black Toyota 4Runner Limited V8, NAV, JBL sound, Flowmasters, K&N filter/charger, 275/75/R16 BFG AT TA KO's
'01 Topaz Blue Metallic 330i Sport 5 SPD M/T
'02 Black Nissan Xterra 5spd SE Supercharged
'97 Black Cherry Nissan Maxima
'88 Faded Black Sterling
'87 Faded Silver Toyota Camry
'84 Red Ford Bronco II
Burnin M is offline
Old 15th November 2008, 22:40   #66
TahBOSS
TahBOSS's Avatar
Garage: Silver Grey Metallic M5
scoopz is the best!!!
2006 Silver Grey Metallic M5
15% Tint All Around
Ipod Integration
TahBOSS is offline
The Following User Says Thank You to TahBOSS For This Useful Post:
scoopz (15th November 2008)
Old 16th November 2008, 16:08   #67
DOUL
DOUL's Avatar
Garage: M5 E60 Black Sapphire - SMG
+1
This thread is by far the most interesting & informative thread here. It has taken him a lot of effort, patience & precision to illustrate the technique accurately. I salute you
Modifications:
  • Engine: RPi / PC Stage 2 ECU Software, RPi ST Underdrive Pulley Kit, RPi Ram Air Intake Kit (Black) & Block Off Plates, RPi SV1 Oil Cooler (Black), M-Sprint Booster
  • Exhaust: RPi GT Headers, RPi Hybrid X Pipe Section 2, RPi GT Section 3
  • Exterior: Vorsteiner CF Vented Hood, RH Type CF Splitter, Upper CF Mirrors, CF Side Skirts, CF AC Schnitzer Style Trunk Spoilers, CF Side & Kidney Grills, Black Powder Coated Lower RaceMesh Grille, CF Pillars, all Roundels in CF, Red Angel Eyes, OEM Smoked Tail Lights, Smoked Side Markers, Brake Calipers Painted in Red with CF ///M Decal
  • Interior: Custom CF Lower Steering Wheel, CF Interior Trim, CF Handbrake, CF Gauges Trim, CF Door Pins, Illuminated Door Sills, OEM Aluminum Pedals
  • Wheels: OEM Blacked Out Rims with Michelin PS2 Tyres (Front: 255/40-19 Rear: 295/30-19), H&R Spacers (12mm Front)
  • Suspension: H&R Lowering Springs
  • Miscellaneous: V-Kool Window Tints
DOUL is offline
The Following User Says Thank You to DOUL For This Useful Post:
scoopz (8th December 2008)
Old 17th March 2009, 15:31   #68
NASCAT
NASCAT's Avatar
Garage: M6 Black Sapphire Metallic
Scoopz,
Many thanks for taking the time to document the whole process step by step including pics & vids. I don't think we could ask for any better. Well maybe an inperson private lesson in a demo so as not to tear up our own car! LOL!
My question being, has any US Spec M5 or M6 owner found a BMW enthusiast / import mods company that knows how to reprogram the US Spec ECU to Non US Spec Standards enabling Launch the REAL Launch Control, raise the 150mph limit etc!!
Michael
NASCAT is offline
The Following User Says Thank You to NASCAT For This Useful Post:
scoopz (17th March 2009)
Old 17th March 2009, 15:41   #69
scoopz
scoopz's Avatar
Originally Posted by NASCAT View Post
Scoopz,
Michael
Thanks, I'm glad to see my research is still useful and appreciated.
I'm almost positive one of the US tuners (and more than likely a board sponsor) has posted on the forum somewhere about reprogramming US cars with full Euro LC but can't for life of me remember which one, sorry.
All I will say is that if you do get Euro spec LC use it sparingly, my clutch retired after ~20 launches.
scoopz is offline
Old 17th March 2009, 15:48   #70
Sharpie12
Garage: 2006 BMW M5 Sapphire Black
Send a message via AIM to Sharpie12
Originally Posted by princealidds View Post
Fine review my friend. I'll try it this weekend. Silly question, when you have lift off, how much tire smoking should I expect
You just saw a video of it being done
2006 E60 M5 Sapphire Black
Neez QD7's Hyper Black
Eibach springs
ASR Cold Air Intake
Dinan 3.91 Diff
Hamann Carbon Fiber front lip
Hardwired V1
Laser Jammers
Eisenmann Race Exhaust
Sharpie12 is offline
Page generated in 0.14866 seconds with 11 queries
