Anyone with TUBISTYLE & Evosport Sec. 1 & Sec. 2 Setup? - BMW M5 Forum and M6 Forums
Old 23rd January 2008, 17:40   #1
EMVY
Garage: BMW M5 Interlagos Blue, 325i Silver
I just got my TUBISTYLE RUMORE.
The inside diameter of the tube is 60mm. and the length is 950mm. I'm still waiting for my Evosport Sec. 1 & Sec. 2 which is not arriving to me until mid to end March. So I decided to have it installed now.
But I found out that in doing so, I need to cut the original BMW pipe and weld it since the outside diameter is exactly the same as the TUBISTYLE. I was given another alternative which is to use a "pipe to pipe connector" in between. This said, the BMW guy told me to just wait for my Evosport Sec. 1 & Sec. 2.
I wondering if anyone has the TUBISTYLE + Evosport sec. 1 & sec. 2 setup? Was the TUBISTYLE welded to the Evosport Sec. 2 or a "pipe to pipe connector" was used?
EMVY
2007 M5
Interlagos Blue
www.bmwforum.ph
I am really annoyed every time I open my hood to worship my beast's manly organs.
ACS style carbon chin with splitters / CF kidney grill / CF side vents / CF rear diffuser / Reiger sider skirt with CF / Reiger trunk spoiler / DPE S20 - 19" / H&R lowering springs / Evosport sec. 1 & sec. 2 / Tubistyle Rumore / Evosport Pulley / RED CF Inlay ENGINE COVER / GRUPPEM CF airbox
EMVY is offline   Reply With Quote
Old 23rd January 2008, 17:47   #2
keang24
keang24's Avatar
Garage: E60 M5 SG
Member "rodster" has similar setup except he has Tubi Regular. I assumed evosport section1&2 you refered to is 2nd cat/resonator removed, not the hi-flow cat/resonator. Search for his video.
I have heard Tubi Rumore just muffler in person, and it sounds very nice.
Congrats
keang24 is offline   Reply With Quote
Old 24th January 2008, 02:13   #3
Rodster
Rodster's Avatar
Garage: BMW M5 2006, Silverstone Silver Metallic
That's interesting, my Tubi fitted perfectly with the eisenmann sect 1 & 2.
__________________________
06 BMW ///M5 SilverstoneII/Black Merino-Leather
RPI GTS Full Exhaust System
Charcoal Filters Removed
FormulaOne Ceramic tint, 35%
Evosport Power Pulley
Dinan Front Roll Control System, Adjustable Rear Sway Bar
Vorsteiner 20" Wheels/ Dunlop Super Maxx
AA ECU
BMC filters
RPI Ram Air Intake
H & R spring set
Rodster is offline   Reply With Quote
Old 24th January 2008, 02:21   #4
keang24
keang24's Avatar
Garage: E60 M5 SG
If you just replace just the muffler, no matter what exhaust brand, you still have to cut the OEM part and either welded on or your a clamp provided. My friend has Tubi Rumore and he said the pipe diameter fit perfectly
I would recommend you wait for section1&2, in that case, you don't have to cut the OEM part because the OEM 2nd cats is bolt-on to the pre-cats/headers. So, your OEM exhaust system is a "virgin"
Old 24th January 2008, 03:17   #5
EMVY
Thanks Keang24 for letting me know that the OEM part must be cut.
My next question is....
Yes, the diameter of TUBI matches with the OEM and should therefore match the Evosport sec. 2. But how do you connect them? By welding? Or using a pipe with smaller diameter that will go in the middle of Sec. 2 and TUBI exhaust? Then use the clamp to tighten the Sec. 2 and TUBI.
Old 24th January 2008, 05:37   #6
keang24
keang24's Avatar
Garage: E60 M5 SG
Don't weld them. I'm sure the clamp provided by Tubi should fit section2 OK, and a clamp should be provided from Evosport to connect between section1&2 (section2 should slide over and fit on section1 while section1 will be bolt-on headers.) Otherwise, just go buy a band clamp I believe 2.5-3" diameter but not sure on diameter.
My clamp provided by exhaust manufacturer not exactly fit and leak the air, but my shop(RPI) used band clamp instead and it work very well (no leakage)
Old 24th January 2008, 09:08   #7
EMVY
Dear Guys,
Sorry for all the confusion I have caused. I just unscrewed the screws and found out that this was a clamp.
So now I know that the clamp holds the TUBI exhaust and my incoming EVOSPORT sec. 2.
Thanks to Keang24 for taking time in answering my questions.
Old 24th January 2008, 11:17   #8
gasterus
gasterus's Avatar
Garage: M6, Black/black
Dear Guys,
Hi Emvy,
Can you give me the diameter of the clamps, I need to get those when I intend to get the section 1&2. Makes it much easier to switch back to stock setup when required.
07 M6 blk/blk
RDsport RS58 stroker with custom ECU tune
Decated stock headers, supersprint x-pipe, E-Race mufflers
Evosport Pulleys, BMC air filters, RPI air scoops & oilcooler
H&R springs, Dinan FRC & rear sway bar
20" Ac Schnitzer V with Yokos advans sport
Brembos 6-pot 405mm front+4-pot 380mm rear
08 E92 M3 S.Graphite/Red
gasterus is offline   Reply With Quote
Old 24th January 2008, 14:35   #9
EMVY
Dear Gasterus,
Sure! I will measure them tomorrow. Yes, easier to go back to stock.
Where did you get your TUBI in Indonesia? What brand of Sec. 1 & Sec. 2 are you using?
Old 24th January 2008, 14:54   #10
gasterus
gasterus's Avatar
Dear Gasterus,
Thanks Emvy! I got the E-race not the Tubi, there is a local distributor for Eisenmann exhaust, but ordered mine from CA Automotive UK..got better price deal and I like dealing with them, very friendly service. I'm planning to have my local muffler shop replace the secondary cats with straight stainless steel tubings. It is a cheaper alternative to aftermarket section 1
M5 vs the Audi RS's matthewpenn E39 M5 and E52 Z8 Discussion 32 25th January 2006 02:43
CLS 55 faster than the M5, QUARTER MILE?? BlackBM E60 M5 and E61 M5 Touring Discussion 39 3rd September 2005 17:30
BMW M5 compared to Mercedes CLS55 AMG guffit E60 M5 and E61 M5 Touring Discussion 48 27th March 2005 18:17
How fast does the M5 do the 1/8 mile in? EBMCS03 E39 M5 and E52 Z8 Discussion 17 18th July 2001 05:09
m3/m5 comparison baggio E39 M5 and E52 Z8 Discussion 12 21st July 2000 00:36
