18th December 2007, 06:16
#2
If ACS has a set of springs available, that means Eibach should be following suit wihtin the year as they usually are the supplier for ACS afaik. That beind said, I find the ACS setup hard to beat. That may be your best option, esp over in HKG as ACS is a well established brand among all the shops there. All that being said, I beleive the springs are different for the two versions jsut due to the different weight and suspension chracteristics but am not positive. Hope this helps.
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
