5th December 2007, 19:08
#8
M5 Blue/grey/light ash
Originally Posted by sechsgang
Just as an overall "tip". The word of the year for novice track drivers ( and for advanced as well...) is SMOOTH. Imagine a cup of mostly filled coffee on your dash and that you SHOULD be able to go around that track without spilling any of it. That is the goal anyway. With smooth, comes speed, and ALOT of it. When turning in for corners, dont just quickly jerk the wheel, feed the steer into the car and you will find there is a lot more grip to be had. When braking, dont pound the pedal, but be forceful with the application and try to NOT use ABS as it is mostly a fail-safe device that should really be used if only necessary. The same goes with the throttle. SQUEEZE on the throttle, don't just mash it. If you try to keep those things in mind (again summarized by smooth), you should be just fine and you will have a great time learning the balance of your car. Once you know how to balance your car (really you will find the pedals are just there to change the balance of your car as you progress) and you will be amazingly fast. Good luck and have lots of fun!
Very well stated. I totally agree
