15th September 2007, 17:54
#8
white m5 e60
James.
We did a before and after dyno. Right after the intakes were in we started the car. No warning lights. We made three passes. 25-30 rwhp less with the new intakes. Is it possible we did not give the car adequate time to adapt. We installed the intakes while the car was still on the dyno so we didn't even drive the car around the block. I totally agree with you that they should adapt pretty quickly, but maybe the fact that we started the car and dynoed right away is not enough time. I drove the car around last night and put about 50 miles on it. No warning lights. This morning I started the car and I got a engine loss of power message. It went of in as soon as the car warmed up. I have been turning the car on and off intermediately. I read to do this from guys on the board. James I have had nothing but problems and loss of power that is recorded on the dyno form the new OEM flash that BMW put in my car. I here that v27 will cause a conflict with modifications. I am very pissed because I told BMW when they did they change my oil and did the work on my clutch that I did not want the ECU flashed. They did it anyway. I am actively using my connections to find a way to downgrade the car back to its stock Version 24 OEM version. I was told that It can't be done by the dealer. They said only a BMWNAtech with a special unit can down grade the software and the car components. The dealer said that if they just install the v24 software the components that are upgraded in the car will conflict with the older ECU version. It makes sense. I would think its like downgrading windows xp to windows 95. If you dont downgrade your divers to the computer will probably not work right.
If you have any knowledge on this I would really like your advise. Since this new OEM update I had the ECU sent to AA for the stage to re flash. We did get a gain in hp but the car ran weird. The smg was hesitant and the car just felt lower. I heard form several people that BMW put encryption in this new software to make it almost impossible for tuner to enhance the ecu. I know for a fact that before this update my car was a beast. The AA tune was aw some. Not only in power put in drivability and shifts, it was awsome. I know is nothing AA is responsible for. They flashed my v27 ECU with the same parameters as the old one. But is it possible that BMW really did something to not allow the tuners to Work on these cars. Russ Ramz had a thread on this. Maybe AA did give me more Horsepower but maybe there is something in the OEM software that is playing games with the re flash. This all sounds crazy but this is what I am going threw.
Please if you have any advice or you know any BMW tech guys can you find out what is going on.
Do you know if it is possible to downgrade the DME-ECU to version 24 once its been updated to v27
PS. I WANT ALL THE MEMBERS ON THE BOARD TO KNOW THAT IN NO WAY IS THIS A ISSUE BECAUSE OF ANY THING ICS DID OR THE ACTIVE AUTOWRKES TUNE. BMW IS TO BLAME. THE NEW OEM SOFTWARE IS GOVERNING THE CAR. THIS IS WHAT I WAS TOLD BY ALOT OF PEOPLE. DOES ANYONE HAVE ANY KNOWLEDGE OF THIS. IS THERE TRUTH TO WHAT I HAVE BEEN TOLD.
Avery
