k&n new typhoon - Page 16 - BMW M5 Forum and M6 Forums
Old 31st August 2007, 16:54   #151
darren_dallas
darren_dallas's Avatar
Garage: 2008 M5 Interlagos Blau
Originally Posted by DY1103 View Post
wow thats not good. Hopefully the ECU will learn to adapt the new mods. Take it for a long cruise.
I get mine today, will let you know if I also get this same issue. Thanks
Got mine installed and got the same error when I started it up for the first time.
After driving around the block, I stopped, turned off the car, turned it back on and the error was gone and has been fine since.
2011 X5M Carbon Black
darren_dallas is offline   Reply With Quote
Old 31st August 2007, 16:58   #152
JamesInLV
JamesInLV's Avatar
Garage: E60 M5 - Interlagos Blue/Black/Aluminum
Sorry 905RMP32V1x, you just got the dreaded engine malfunction warning that I've been dealing with since v25 was installed. BMW traced it down to a measurement out of parameters coming from the MAF sensors. They replaced my MAF sensors, held the car overnight and checked it in the morning and got the same error. BMW Germany techs were working with them overnight each of the couple nights, and the end results was them being told to have me swap the stock airboxes back in, and if the problem persists they would continue researching the problem.
The only solution that may work is to get onto updated software. I haven't gone there yet, as I need to know what is in v27 so I can come up with a problem or two for my SA to qualify my car for an update.
So here is how to get rid of the error:
1) Start your car up, wait just a few seconds and start bringing up the RPM to about 2000-2500 and back to idle. Do this a couple times.
2) Give it a couple quickly RPM shots up to about 3,000rpm or so. You might actually here a "click" when you let off the throttle from this. Not sure what that sound is, but might have something to do with the choke?
3) You should be good to go! 1) and 2) above should take you about 20-30 seconds, that is it.
If you start the car and just let it idle there, or start and go into gear without doing this little warm up I described, you WILL get the error almost every time. From there, I just drive normally (it doesn't appear to limit anything except the max RPM) until the engine is mostly warmed up, and at the next chance I have I shut down the car and restart, and all is good just like you experienced.
James
Las Vegas, Nevada
Now driving my 1999 Toyota Landcruiser again.
Wife gets the 2007 Honda Odyssey.
Looking forward to my next M5.
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
www.LVHomeResource.com
JamesInLV is offline   Reply With Quote
Old 31st August 2007, 17:10   #153
905RMP32V1x
905RMP32V1x's Avatar
Garage: M5, Indy Red
It went off after the car was warm. I didn't let it warm up this morning when it went on. We'll see what happens tomorrow.
2006 Indy Red/Blk/Alum loaded,
H&R springs w spacers, 167(M6) wheels,
Dinan 3.91, Evo Pulley
CF grills, CF vents, ACS Spoiler
Vorsteiner CF Vented Hood, CF lower steering wheel
905R-driver
MP32-irons
ProV1x-ball
905RMP32V1x is offline   Reply With Quote
Old 31st August 2007, 17:12   #154
JamesInLV
JamesInLV's Avatar
Guys, don't bug K&N about the error unless you want to return the kit. I've been dealing with this for months, and decided that the performance gains (and induction noise gains) are worth this little procedure above. I've been doing it for months and the only time I ever get the error is when I don't do it. K&N tested a newer 2008 M5 that had just cleared it's initial break-in check, and go no errors. This was only about 5 weeks ago. My guess is v25 software changed MAF sensor parameters, and v26 and later (possibly even later versions of v25) may have backed these out after my car was in and the error was analyzed by BMW.
I'm crossing my fingers that those of you who definitely know you have v26 or v27 software do NOT get the error with the intakes. Then, we'll just have to figure out how to get our nice SA's to update the car when we really have no other problem than this...with an aftermarket part. I'm sure v27 will have an "official" bulletin and you can come up with something on there to help your SA get the software update.
Old 31st August 2007, 21:55   #155
DY1103
Garage: 2006 M5 IB
Thanks James,
So if by chance the engine malfunction error light comes up, doesn that make the car in some sort of limp mode and lose Power?
Current: 2006 E60 M5 Interlaglos blue
http://www.twcompetition.com
DY1103 is offline   Reply With Quote
Old 31st August 2007, 23:27   #156
bonehead
bonehead's Avatar
Garage: Somethin' German
Sales Feedback: (7)
Anyone actually get a K&N set from Vivid yet?
Experiences with Vivid Racing?
Boner
bonehead is offline   Reply With Quote
Old 31st August 2007, 23:34   #157
MarxM3
MarxM3's Avatar
Garage: SB 06 BMW M5
Just thought I'd add that my car is currently at V24. During my last visit to the service dept I was told that the V25 had some "issues" and they were not installing it anymore and waiting for a newer release. This was six months ago... I didn't buy the whole "issues" story, but I'm glad the K&N works well with V24...
2006 E60 M5 Black Sapphire/Black
2002 E46 M3 Carbon Black/Cinnamon
2004 996 TT Black/Black
MarxM3 is offline   Reply With Quote
Old 31st August 2007, 23:41   #158
905RMP32V1x
Its really no big deal. This morning the light came on once and was gone when I restarted it. I'm interested to see what Darren's dyno shows. Especially since he has a vented hood. The filters are perfectly positioned under the vents. It looks like it should help.
Old 1st September 2007, 00:19   #159
Wolverine
Wolverine's Avatar
Garage: BMW E60 M5 Silverstone II/Silverstone/Aluminum
Originally Posted by darren_dallas View Post
Mike,
No worries man, I'll be doing the dyno on Saturday with the hood closed. I'll post my results.
Cheers,
Darren
Outstanding - you and James should get some type of award.
I'm especially interested in the increase in sound as well. Give us your impression. I'm kicking myself for installing the BMC filters when I could be replacing them with these %$!# K&N pieces.
I'm going to tape my fingers together...until I see your results... .
Wolverine is offline   Reply With Quote
Old 1st September 2007, 01:30   #160
905RMP32V1x
Big improvement in sound. You can really hear it rev after about 3K. But not too loud. If you liked removing your resonator you'd love this.
FS: Certificate For One Free K&N Air Filter (ANY PART #) - $30 Shipped... Ben Carufel Parts / Other For Sale or Wanted 1 29th July 2006 07:17
New K&N Filters for E39 M5/ gbogh3 Parts / Other For Sale or Wanted 5 4th June 2006 16:14
2 NEW K&N Intake Kit pride355 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 18th November 2004 16:06
OT: K&N Filters for the X5.... leebro1 E39 M5 and E52 Z8 Discussion 1 6th December 2001 22:33
K&N Filter cleaning... BlueBomber E39 M5 and E52 Z8 Discussion 4 19th November 2001 23:20
