24th August 2007, 05:09
#1 (permalink)
Advice on performing burnout?
Question - w/ SMG transmission is there a way to do a M5 burnout? I cannot seem to get my 06 M5 to do it. I've taken off the traction control etc.. and even tried to brakes then putting on the gas.. nothing seems to work.
I can get it to break traction a bit around some corners but thats about it nothing like a burnout..
24th August 2007, 05:45
#2 (permalink)
My 2007 with SMG just sits there and spins if I floor it. I actually have to back off to keep the car straight. Not sure why your car would be any different.
Assuming you are already driving in the higher power setting? If not, set your M Drive to P500S, DSC off, S6, and whatever your pleasure on EDC. Then just floor it. Mine breaks loose from a dead stop, rolling start, straight, turning, whatever. Tires are brand new too. I actually try not to spin them, but have fun if that's your thing.
Maybe reset your clutch so it engages a little better if you have some miles on it.
24th August 2007, 05:50
#3 (permalink)
Thats odd.. I have it set for 500s and s6 etc.. hmm
24th August 2007, 05:54
#4 (permalink)
DSC OFF, 500 HP, and just floor it. Mash the gas without hesitation. You'll burn tires. 2006 stock M5 here, and no problem with this task.
24th August 2007, 05:59
#5 (permalink)
I figured you did. That would have been an obvious answer. You get the warning light on your dash the DSC is off, correct?
The computer is engaging that clutch for you, so feel it engaging through your right foot and dump it. Blip the throttle then floor it. If that doesn't work, try reseting your clutch. Maybe it's worn out a little and slips when you punch it?
Like I said, I'm not even trying to do it. It just happens if I floor it and don't back off. I can't imagine any reason why our cars would react differently.
24th August 2007, 06:25
#6 (permalink)
2006 here no problem laying rubber. I was curious how do you reset the clutch?
2006 m5 e60 white/black
Eisanmann Race
SS headers
AA stage II
Evo Pulley
Charcoal Removed
K&N drop-in
A/C roof spoiler
Hella Smoke Lights
possible future mods
ASR? Thinking about it
EVO sec1&2 cats/resonators?
http://www.icsperformance.com/rides%20ap%20final.htm
24th August 2007, 06:45
#7 (permalink)
Mash it, dump it and then step on the break immediately to get a power stand. DSC off P500
__________________________
06 BMW ///M5 SilverstoneII/Black Merino-Leather
Tubi Style Exhaust System w/ Meisterschaft Sect I & II
Charcoal Filters Removed
FormulaOne Ceramic tint, 35%
Evosport Power Pulley
Dinan Front Roll Control System, Adjustable Rear Sway Bar
Vorsteiner 20" Wheels/ Dunlop Super Maxx
AA ECU
BMC filters
RPI Ram Air Intake
H & R spring set
24th August 2007, 06:53
#8 (permalink)
Can't believe that I am contributing to the destruction of tires for no good reason.....
After you get a good spin going in 1st, shift to 2nd gear.....2nd gear has enough speed to ensure the tires never get grip.
Hard on the tranny.
Don't you want to burn rubber in a meaninngful cause? Like tracking or even drag racing?
"Aerodynamics are for people who cannot build engines"...... Enzo Ferrari
24th August 2007, 07:12
#9 (permalink)
How about tire pressure? if it is low, it might be the cause that you can't do a burnout. just a thought..........
2006 June production
Silver Grey/ Black on Black with Aluminum Shadow
Exclusive Package/ Head-up display
24th August 2007, 08:42
#10 (permalink)
Ah its just the guys at work wanting to see its power and I couldnt seem to get it to unleash... They know its hella fast... They just haven't seen it smoke tires
24th August 2007, 16:51
#11 (permalink)
clutch reset
Not sure of the exact speed required, but I think it is something over 40mph. I do it occasionally on the highway at 60mph or so and it keeps the shifts smooth. Sorry for posting without a hard fact on speed required.
Anyway, somewhere that you have enough space to coast at speed without someone coming up behind you...put the car in neutral and pull both shifter paddles in and hold for a few seconds. You won't hear or see anything, but it resets the clutch to compensate for wear.
Try a search, you'll get a better answer than what I gave you, but that's the idea.
24th August 2007, 20:36
#12 (permalink)
hecjk i've even done it in p400 mode !!
just dump the gas and the rpms will shoot to like 3k or something before the clutch engages then your spinnin !!
2007 e63 amg
iridium/blk/p30 pkg
2006 x5 4.8is
imola/red/blk/alum
