6 speed manual needs much LESS oil than SMG! - Page 2 - BMW M5 Forum and M6 Forums
Old 14th August 2007, 23:57   #11
m5 deamon
m5 deamon's Avatar
Garage: 2003 e39 m5 carbon black on black sport interior
yes it will pvr you have to remember that as temp rises metal expands and tolerences get greater
2003 m5 Carbon Black, Black sport interior,
Evolve stage 3 Alpha N with power tune buh bye pc93 tune
Evolve cold air intake
Evovle heads with shrick cams
Raikku Modded Throttle Bodies
SS Headers going to make the jump to evolve headers real soon as soon as a certain some one on this board buys them lol you know who you are!
Zionsville Radiator with spal 2 speed fan
UUC Light Weight Fly Wheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmission mounts
Steel braded clutch line
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braided brake lines
Dinan rear sway bar
Dinan rear stress bar
Custom built M5 front stress bar
Tc sway bar brackets
Stop tech St 40
Kw v3 suspension
Rouge blue control arms
Ground control camber caster plates
L I custom Adjustable sway bar links front and rear
Predator ice v3 angel eyes
Bimmian black kidney grills
VVME xenon 4300k fog lights
Solaris amber bulbs
led lic plate lights
Exotics tunning rear cf finned diffuser
Vorsteiner front splitters
v1 hardwire
m45 blinders updated version
Slimbones xl foglight covers
Euro tail lights with rear fogs hooked up
Bsw Stage 1 with there subwoffer package
Alcanterra shift boot and ebrake boot from leather z
Alcanterra ebrake handle from a m3 csl
Illuminated zhp shift knob
Alcanterra custom wrapped steering wheel
Custom interior orange led in door pockets and handles
To Come... Evolve headers and race cats, this list seems to be shrinking!
m5 deamon is offline   Reply With Quote
Old 15th August 2007, 00:36   #12
bernhtp
Garage: M6 Convertible - Saphire Black, Portland Brown full merino, CF
My 2001 M5 used far less oil than my 2000 M5. My bet it was a function of both better manufacturing tolerances and not pushing it as hard due to being over the intoxication of new power. The clutch quickly started buring up on my MY2000, so I took it easier on the newer one.
I suspect something similar here.
bernhtp is offline   Reply With Quote
Old 15th August 2007, 01:41   #13
BogoKi
BogoKi's Avatar
Garage: 6 speed 07 M5 Interlagos Blue
Originally Posted by pvr View Post
It's been quite obvious that my oil consumption goes up in warmer/nicer weather when I'm driving the car (much) more aggressively, and goes down in the winter when I drive more conservatively.
Hi pvr, I spent the winter in Michigan and drove the car quite aggressivelly there. Now I am in Florida and drive as aggressivelly as before, temperatures here around 90 F. I guess it depends on each car, I am lucky that mine doesn't seem to require much oil. I am sure that it's not a SMG x Manual issue. Few weeks ago driving from the midwest, a 1500 miles one-way trip done in two days, the oil moved only from 0.9 to 0.7.
07 M5 Interlagos Blue/Black/Aluminum Trim/CF Removed/Sirius/Ipod Interface/V1 Hardwired with Concealed Display/Blinder M40/6 speed/Hartge Sport Springs:
03 330i Black Saphire/Black/Aluminum Trim 5 speed
04 545 Titanium Silver/Gray 6 speed, sold
BogoKi is offline   Reply With Quote
Old 15th August 2007, 02:19   #14
m6ontheway
m6ontheway's Avatar
Garage: M6 Vertible 6 speed
I have a 6 speed and go through 1 liter every 750 miles or so.
2007 M6 Cab, Silverstone Silver, Indy Red Full Merino, Fully loaded.
m6ontheway is offline   Reply With Quote
Old 15th August 2007, 03:01   #15
unfoundhorsepower
unfoundhorsepower's Avatar
Garage: 2006 M5-E60, Interlagos blue,all options + 2004 Z4 Red loaded,2004 M3 Luguna Seca Blue, 2009 X5 35d Saphire Black.
Boys, let me help you.....weather you have an SMG or a 6 speed doesn't have anything to do with how much oil your engine consumes...some suck mucho oil, some not,,
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline   Reply With Quote
Old 15th August 2007, 03:12   #16
pvr
pvr's Avatar
Garage: BMW M5 (E60) Black Sapphire (1/06)
Agree that it isn't necessarily the SMG vs Manual, unless SMG users inherently drive at higher rpms. Also agree that highway miles use less oil than running up and down the gears. I run to redline multiple times almost every time I take a drive . Can't help myself. Just more fun that way. Would also add as an aside that my oil consumption is way down overall after the 15k maintenance. Don't even keep track anymore, but it might be somewhere around 1 liter every 4k miles in summer, vs 5k in winter.
Paul
2006 M5, Sapphire Black/ Black Full Leather/Walnut
pvr is offline   Reply With Quote
Old 15th August 2007, 04:00   #17
Wayward
Wayward's Avatar
Garage: 2006 M6 - SB/Black
A brain, a brain, my kingdom for a brain....
Interesting, no one's mentioned the impact of break-in procedures with regard to oil consumption.
Wayward is offline   Reply With Quote
2007 6 speed manual vs SMG in the e60 vs e39? Bagger E39 M5 and E52 Z8 Discussion 21 3rd September 2006 07:31
2006 SMG or 2007 6 Speed Manual? jazz4tune E60 M5 and E61 M5 Touring Discussion 39 28th July 2006 04:12
DIY Dummies Guides to Oil Change using Fluid Extractor HDClown E39 M5 and E52 Z8 Discussion 0 18th September 2005 00:46
Press Release 3: The new sequential M transmission: Shifting gears even faster wit... Gustav Most Memorable Threads' 0 4th July 2004 21:28
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 21:23
