Evosport Pulley in High Temperature Climates - BMW M5 Forum and M6 Forums
Old 13th July 2007, 16:06   #1
JamesInLV
JamesInLV's Avatar
Garage: E60 M5 - Interlagos Blue/Black/Aluminum
Now that we're in the heat of summer in the northern hemisphere, would anybody who lives in high temperature climates comment on the reduction in A/C cooling in their car? I know RKN in AbuDhabi had to uninstall his, that it just couldn't hold up to hit temperatures there. Is there anyone in Arizona or Las Vegas with this...or another area with high temperatures but generally low humidity, that has noticed issues with A/C cooling? Darren_dallas...you're in a relatively high temperature, high humidity area. Have you noticed any noticeable cooling loss?
For RKN...he is probably at the extreme. Very high temperatures and 80% humidity is torture on an A/C system...humidity is not A/C's friend. Las Vegas has been as high as 116 or 117 in the past couple weeks, and as the pulley kit is on its way I'm concerned about the A/C performance suffering more than I can accept. Probably should have asked this question before I ordered it!
James
Las Vegas, Nevada
Now driving my 1999 Toyota Landcruiser again.
Wife gets the 2007 Honda Odyssey.
Looking forward to my next M5.
2006 ///M5 SOLD :-(
2002 325i SOLD
1987 325i Conv. SOLD
www.LVHomeResource.com
JamesInLV is offline   Reply With Quote
Old 13th July 2007, 16:12   #2
SCORPIO
SCORPIO's Avatar
Garage: 2006 M5 - Silver Gray
I hope there is no reduction, I LOVE THE A/C in our car! It's awesome!
My wife went to test drive Lexus models and it was 109 degrees outside. Every car we drove was still stifling hot after 10-15 minute test drives. The saleman was telling us that Japanese A/C is the best, there is none better. My wife looked at each other and rolled our eyes (we both drive BMWs). I so wanted to put the salesman in the M5 and show him the A/C we were used to, just to get him to shut up!
Japanese A/C being the best...I have found none better than German engineering!
Good luck with the pulley - if you do get it, can you get a before/after dyno? I know you have several mods already on your car, but would be curious to see.
Best of luck!
SCORPIO
2006 BMW E60 M5 - Active Autowerke's ECU upgrade; Charcoal Filters removed
-Silver Gray with Black perf. interior
-Rear side impact airbags
-comfort access
-front multi-function seats with active width adjustment
-wood trim, walnut
-power rear sunshade with rear manual side window shades
-front ventilated seats
-heads-up display
-3M Ultrashield clearbra
2008 Black BMW 135i Convertible
2008 Black Yukon Denali
2007 Saleen Mustang Parnelli Jones Limited Edition 1 of 500 - Sold
2006 Sterling Grey/Grey BMW X5 4.4i w/all available options - Sold
2004 Chevrolet Corvette Z06 (red) - Sold
2004 Quicksilver Cadillac Escalade ESV - Sold
2003 White Porsche GT3 Cup Race Car - HELL YES! - Pirelli Drivers Cup 2nd/3rd - 2010 Miller Motorsports Park
2003 Cold Stone Creamery #00 Mini Cooper S Challenge Series Race Car - NASA AZ Champion; NASA National Runner-up 2009/2010
2003 Sterling Grey/Black M5 - Sold
2000 White Chevrolet Silverado 2500 HD 4x4 SB Pick 'em up truck - Sold
1994 Yellow Land Rover Defender 90 - Sold
1980 Nissan 2WD pickup - Sold
1971 Fiat Spider - Sold
SCORPIO is offline   Reply With Quote
Old 13th July 2007, 16:31   #3
JamesInLV
JamesInLV's Avatar
Best of luck!
I'm curious to see too. If I get it done with for the pulley kit, I would probably go ahead and do a before/after on the K&N air intakes too. Doesn't take long to swap the air boxes, drive a couple miles to ensure the engine reads the intakes (and warm up the tranny again), and drop the car on the dyno. Anybody know a dyno shop in Las Vegas? If not to pricey, I'll get it done.
Old 13th July 2007, 17:07   #4
kaninja99
kaninja99's Avatar
Garage: 2013 M5 Silverstone
kuwait
I am not so sure about the humidity being an A/C's enemy. I have noticed that most car'ACs cool quicker in humid weather because it helps keep the condenser wet.
anyway,I live in kuwait where it regulary hits 130 fahrenheit but the humidity is relatively mild and have had no issues with cooling. I have had the evosport pulley for the last two months in this searing heat.
kaninja99 is offline   Reply With Quote
Old 13th July 2007, 17:14   #5
RussRamz
RussRamz's Avatar
Garage: 2011 M3 Coupe Mineral White
YOU are absolutely correct. In fact--humidity is your friend. Humidity IMPROVES engine performance and effectiveness of almost everything having to do with auto performance including AC. High humidity is a common misperception of a reduction of performance. The only thing that will reduce the performance of a car is a high density altitude (heat/altitude) Since humidity is often accompanied by high temperatures, it's often associated with poor engine performance--on the contrary. Water injection (humidity) was a poor man's nitrous system in the early years. It was often used on combat aircraft of WWII and even race cars. I repeat--humidity is GOOD-HEAT=BAD, HIGH ALTITUDE=BAD.
Keepin' it real...
Russ
"Quitters never win, winners never quit. But those who never win and never quit are idiots."
2007 BMW M6 Coupe--Sold, but not forgotten
2008 BMW Z4M Coupe--Sold
2009 BMW 135i--Sold
2010 335d--Given to the wife
2011 M3 Coupe Competition--On order!
RussRamz is offline   Reply With Quote
The Following User Says Thank You to RussRamz For This Useful Post:
Murtaza (5th December 2008)
Old 13th July 2007, 17:32   #6
boarder1995
boarder1995's Avatar
Garage: 2006 M5 in black
Moist air into the condenser helps to pull heat out of the system quicker - we're dealing with an air over tube/fin heat exchanger. It's the same premise as people spraying water over their intercooler on turbo vehicles.
Also, driving the compressor slower will not necessarily make it last longer. It'll be easier on it short term, but it'll be running more frequently. You'll have refridgerant passing through the evaporator slower, thus less cooling capacity (heat removal capacity) for your AC air blowing over its coil (heat exchanger).
Welcome to Thermo and Heat Transfer 101! Crud - I'm actually really enjoying this.
"Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer". (Walter Röhrl)
'06 M5, took ED on Aug. 28th, 2006 in Munich!
Re-delivery on Oct. 20th, in Temple, TX.
VANOS killed M5 engine - totaled out 9/9/2011.
M5 currently in purgatory awaiting its fate...
1. either let go to insurance company and auctioned off for parts, OR...
2. purchased back and reborn with a Dinan stroker engine!
Option 2 please, DONE!
boarder1995 is offline   Reply With Quote
Old 13th July 2007, 17:36   #7
JamesInLV
JamesInLV's Avatar
Learn something new every day. Always thought since A/C's work to remove water from the air, that humidity made the system work harder.
kaninja99, thanks for posting your reply! Your experience with the extremes of your climate is enough to eliminate my worries.
Old 13th July 2007, 18:31   #8
RKN
RKN's Avatar
Garage: M FUNF 06 IN.BLUE
good thread James
well in my case i thing its the opposite from all of you , ill probably re-install in the winter and c the outcome ,
is it havin my ECU programmed by DMS diminished the effect of the pulley?!
RKN
RKN is offline   Reply With Quote
Old 13th July 2007, 18:33   #9
haveboost
haveboost's Avatar
Garage: 06 M5 Interlagos Blue, 04 CTSV Platinum, 27 Ford Model T Roadster
In miami, had it for at least 3 months and no problems. Sometimes if your hard on the car it'll raise the temp a bit but not a big deal.
Go for it!
06 M5 - Interlagos Blue/Black Full Leather (evo pulley, K&N Drop Ins,ASR Custom Exhaust, Ipod Kit, Eibach Springs, Radenergie R20 w PS2's)
07 Cadillac Escalade Diamond White/Blk Int
27 Ford Model T Roadster - Hot Rod (Just Sold)
09-GTR premium on order. White/black interior.
haveboost is offline   Reply With Quote
Old 13th July 2007, 20:40   #10
C_Stradale
C_Stradale's Avatar
Garage: E60 M5 Indy Red
Originally Posted by RKN View Post
good thread James
RKN
RKN, you do know you can go into your iDrive and tell you climate control to be more biased towards cooling vs heating, don't you? I had my car 6 months before I discovered this odd little feature of the climate control.
Steve
'06 Indy Red M5
Dinan diff_Evo pulley_BMC filters_SS Race cans
600hp '05 DSOM 427 LPE Vette Coupe
http://www.pbase.com/sshyone/wheels
C_Stradale is offline   Reply With Quote
M5 E60 Press Releases + High-res Picture + interviews with BMW M Manager Bruhnke Gustav E60 M5 and E61 M5 Touring Discussion 8 6th November 2004 15:52
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav E60 M5 and E61 M5 Touring Discussion 31 4th July 2004 21:23
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
M5 E60 High-res Picture Thread (No posting) Gustav Most Memorable Threads' 2 10th March 2004 23:30
