15th July 2012, 03:20
#769
'02 LeMans Blue M5
Originally Posted by Sailor24
No test 14 is not the same . It has a whole set of different meanings. Is that where you got those numbers from. If it is there are 4 lines post each one. If you have those codes explain where you got them and include if you have cleared them and they came back.
Got them from Test 14. My Peake tool is on it's way so I decided to give this method a try.
1 91 84 000
2 F7 84 000
3 F8 84 000
4 BF 84 000
5 CE 84 000
I cleared them, went for a short drive (5 miles) and they hadn't yet appeared. I have no reason to drive anywhere at the moment but if they return I will pull them again. To be honest I don't really think there is anything wrong with the car. If there's anything wrong, it's awfully subtle. It also recently passed an inspection, with only 1 history of a fault code (random misfire during warmup), but it was ages ago.
