Knowledge base on Peake codes for E39 M5 - Page 63 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 1st October 2011, 15:49   #621
E39LOLZ
E39LOLZ's Avatar
Garage: 13 X1 xDrive35i blk, 13 Mustang blk
Yesterday morning got the dreaded AA code which is well known around here. However, I have been having code AE that I have been tracking for a while and I have eliminated fuel/vacuum leaks as I have had a smoke and fuel pressure tests performed. I know that the AE code is caused by my mafs and recently started to get the AF code (bank 2) as well. Could it be that bad mafs can cause the AA code to go off? 118K miles and I suspect original mafs or a 2nd set on the way out.
Current
13 X1 xDrive35i (04/13-present)
13 Mustang 3.7 V6 coupe premium (06/12-present) Wifey's DD
Past
87 528e (12/96-10/12) too much rust, sold for parts
87 528e/5 4parts (01/10-03/11) sold to junk yard
92 525i/5 (11/06-06/07) sold then totaled by brother in law
92 535iA (08/99-10/06) totaled by stoopid driver
99 528iA Sport (09/06-12/07) traded for e46 xi
01 525i/5 Sport (03/07-05/11) sold
01 M5 (04/11-04/13)
03 325xiA (12/07-10/11) traded for Stang
10 Mustang 4.uh-oh Convertible (10/11-06/12) traded for Stang
E39LOLZ is offline   Reply With Quote
Old 1st October 2011, 16:00   #622
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
IMO: unlikely.
chowdah is online now   Reply With Quote
Old 1st October 2011, 18:15   #623
Sailor24
Sailor24's Avatar
Garage: 2000 Anthracite,
If your car has gone super rich and your passages are partially blocked but not completely blocked it can trigger the code. That does not mean assume that this has happened. Little story I cleaned my CBU out a couple of weeks ago and never saw the code again. This morning I was about to write about my success and the way I got into one of the passages. Started the car and the light came on AA code, so I assumed I did not really clear out enough. Wrong turns out my air pump has decided to only spin slowly.
Diagnose your AA code like you have no other codes. Next cold start go to the front and make sure the fan is running. ETC.
Sailor24 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sailor24 For This Useful Post:
chowdah (1st October 2011), E39LOLZ (3rd October 2011)
Old 3rd October 2011, 01:59   #624
E39LOLZ
E39LOLZ's Avatar
During the past two cold starts (yesterday and today), the fan has been running and then turned off after a minute or so. I have checked for any soft codes over the weekend and the AA code hasn't returned. I really don't want to start another discussion about the AA code as it has been beaten to death on this board, however, it seems that everyone jumps the gun that CB is present whenever the AA code comes up. Could a faulty air pump cause the AA code as well?
Old 3rd October 2011, 02:30   #625
technician117
technician117's Avatar
Garage: 2000 M5 Anthracite
Sales Feedback: (5)
It's a pretty simple system. If you can hear the pump running than it's probably fine. As far as I know the system consists of the pump, some basic piping to each head, and then there are poorly designed passages that clog up, as I'm sure you read all about already. There is also the electrical half, but if the pump is running then you can rule that out. The only thing other than CBU is maybe a break in the plastic tube from the pump that runs to the metal tube..
Tim
UUC ssk
Tubi Catback
technician117 is offline   Reply With Quote
Old 5th October 2011, 00:55   #626
Sailor24
Sailor24's Avatar
All true but the carbon may just be in the tubes or just around the corner in the head. I am, if I get time, going to tell my story. I have got air flowing again to a cordless and a piece of cable. The SAP system really should be fully diagnosed before you chip out the problem.
Old 5th October 2011, 04:58   #627
E39LOLZ
E39LOLZ's Avatar
Well today I took the $196 plunge and got two new OEM mafs with housing. Yes, you read that correctly. One time blowout sale from a vendor from ebay. Once they arrive I will swap them in and they should end my AE, AF codes. AA code has been hiding so far. I have heard that once new mafs are installed its like having a supercharger installed. Every now and then I feel a slight hesitation under WOT and along with my AE and AF codes, mafs are most likely the culprit. Will update if those codes return after new mafs are installed.
Old 5th October 2011, 16:51   #628
Sailor24
Sailor24's Avatar
Are you sure they are OEM MAFs. There are a bunch of guys on Ebay claiming the same but they are Chinese junk or VW mafs. If they are OEM send me a link I will buy them and save till I need them.
Old 5th October 2011, 17:33   #629
technician117
Sales Feedback: (5)
+1
Be careful of MAF's on eBay!
Old 6th October 2011, 09:59   #630
manualshifter
manualshifter's Avatar
Garage: M5 e39
Originally Posted by technician117 View Post
+1
Can confirm that!
I bought VW Mafs from UK few months back- car would not idle, black smoked etc even after driving for a day and quite a few start stop cycles. Took them out.
manualshifter is offline   Reply With Quote
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
