Knowledge base on Peake codes for E39 M5 - Page 43 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 21st August 2010, 13:46   #421
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Doug, just to confirm he had code 69, not b9.
Also Apples, for 8C, engine noise too high, it might be worth checking the water pump shaft for excess play, as this may cause an issue for the knock sensors....just a thought though. Doug knows exactly what he is talking about.
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 22nd August 2010, 01:44   #422
Apples
Apples's Avatar
Garage: 2000 M5 Blue
Yep it looks like a 69 code as its got the top horizontal line. (Engine coolant temperature plausibility) WTH...
Apples..
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/3:45 diff/BBS LM 19's 275's rear, 245 fronts 440-460hp
YouTube M5 Kelleners Exhaust (race) www.youtube.com/watch?v=v5cJA231c-8
YouTube M5 Exhaust removed...the real beast sound www.youtube.com/watch?v=ozS31-SuO4o2003
2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear.... SOLD, LOVED EVERYDAY IN IT
YouTube Gallardo Kreissieg www.youtube.com/watch?v=pQwqqvyL0RY
YouTube Gallardo NO exhaust www.youtube.com/watch?v=zYsxA9UetYY
2003 M5 (was Yoda) now transformed in a "Aussie UTE"
www.m5ute.com.au
2006 Ford GT Heritage blue
Apples is offline   Reply With Quote
Old 22nd August 2010, 01:56   #423
GBPackerfan1963
GBPackerfan1963's Avatar
Garage: 2002 Bluewater Metallic M5
Apples..
Stuart,
It's probably time for either a new thermostat or the easy fix of a sending unit gone bad. GL.
2002 M5 Bluewater Metallic/Black & Silverstone leather/
All options/MKIV NAV/VMR VB3 Wheels Square set-up/3M tint
/BT/Intravee II/Ice V5 angel eyes/smoked side markers/
DINAN Front Strut Brace/PowerChip Alpha-N tune/Smoked taillights/Ultimate pedals/
BSW Stage 1 Upgrade w/Subwoofer package/e60 SSK/ZHP Shift Knob/
CF Kidneys/CNS Racing Cat-back exhaust/LED lighting throughout/Euroclear Headlights/
Angeleye DRL's/HID Foglights/Dinan Stage 2 Suspension/
CNS Racing Clutch/ Sink drain/brake duct modification/ExoticsTuning CF diffuser and fog light covers/SuperSprint Headers
"...when a 400-horse 5-series needed only one letter to make its point: M."
GBPackerfan1963 is offline   Reply With Quote
Old 22nd August 2010, 02:02   #424
Apples
Apples's Avatar
You mean it could be giving bad readings that the computer doesn't make sense of and trips the 69?.
I've seen no spikes in temps, I never go past 210deg on a hot FL day..
SA
Old 22nd August 2010, 02:05   #425
GBPackerfan1963
SA
Get into the secret menu and see if your running less that 74ºC when warm. If you are, then it's time for a new thermostat. Our beasts thermostats always go buns up in the open position.
Old 22nd August 2010, 02:37   #426
Apples
Apples's Avatar
I was asking about that "secret" menu this morning and I printed out the instructions and had no luck at all.
I've got the 4:3 screen and step3 says push "right button"...sorry dont have one...
I tried that on the left and only button and nothing.
SA
Old 22nd August 2010, 03:35   #427
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
SA
They mean the buttons on your cluster. If you don't have 2 then we need to start questioning whether you really have an M5
DouglasABaker is offline   Reply With Quote
Old 22nd August 2010, 04:01   #428
GBPackerfan1963
+1
Old 22nd August 2010, 12:18   #429
Apples
Apples's Avatar
Well why didn't you say that.
I love my wanna be M5.... imagine how good a real one would be.
Apples
Old 31st August 2010, 05:25   #430
roverguy10
roverguy10's Avatar
Garage: 2003 e39 M5 Carbon Black & 1991 e34 M5
I kept pulling the same fault on my M5, and replaced the thermostat, temperature sender, and the double teperature switch (for the fans) and the fault went away. I did notice that the car was running cooler than should be expected per the temp gauge on the hot summer days here in FL, and after reading some threads discovered that LUCKILY these thermostats fail in the open position thus not overheating the car.
roverguy10 is online now   Reply With Quote
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
