Knowledge base on Peake codes for E39 M5 - Page 35 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 26th January 2010, 16:01   #341
Seisup
Garage: 2003 M5 Alpine White S2
Originally Posted by chowdah View Post
Sounds like MAFS. You can run the secret menu test, and/or do the spray-clean/disconnect/swap-sides diagnostic to confirm.
Can't speak to code 63.
Thanks Chowdah....I'm gonna try the test and see what the #'s are....
Seisup is offline   Reply With Quote
Old 19th February 2010, 22:40   #342
jimbre7
jimbre7's Avatar
Garage: Hiking Boots
I just got my 01 M5 about a month ago. I drove it home 1000M without a single issue. Now it goes into limp mode right after start-up. Turn it off, turn it back on and it's fine.
These are the codes from my peake:
4e: Coolant Temp Sensor
6b: Control unit self-test, pre check of drive-by-wire system
E6: Drive-by-wire, throttle position failure
D1: Misfire during warm-up, cyl 5
D2: Misfire during warm-up, cyl 6
D5: Misfire during warm-up, mult cyl
I saw these issues with other M5's, but I wasn't sure if some codes would contribute to others. Any help would be great.
jimbre7 is offline   Reply With Quote
Old 24th February 2010, 04:48   #343
GBPackerfan1963
GBPackerfan1963's Avatar
Garage: 2002 Bluewater Metallic M5
4e: Self explanatory
6b and E6: Possible throttle sensor failure
The others are pretty common and will probably go away when you reset it and see what comes back.
2002 M5 Bluewater Metallic/Black & Silverstone leather/
All options/MKIV NAV/VMR VB3 Wheels Square set-up/3M tint
/BT/Intravee II/Ice V5 angel eyes/smoked side markers/
DINAN Front Strut Brace/PowerChip Alpha-N tune/Smoked taillights/Ultimate pedals/
BSW Stage 1 Upgrade w/Subwoofer package/e60 SSK/ZHP Shift Knob/
CF Kidneys/CNS Racing Cat-back exhaust/LED lighting throughout/Euroclear Headlights/
Angeleye DRL's/HID Foglights/Dinan Stage 2 Suspension/
CNS Racing Clutch/ Sink drain/brake duct modification/ExoticsTuning CF diffuser and fog light covers/SuperSprint Headers
"...when a 400-horse 5-series needed only one letter to make its point: M."
GBPackerfan1963 is offline   Reply With Quote
Old 24th February 2010, 21:41   #344
crds
crds's Avatar
Garage: 2003 M5 E39 Imola Red
So I got an E39 M5 last year Feb, and between 6 and 12 months ago I was throwing codes on occasion (mis-fires usually, maybe 1 or 2 cyl's a month, at random) and I reset them, and they have gone away. No worries? Did it just need driven (or well-driven)?
Opinions?
-crds
crds is offline   Reply With Quote
Old 28th February 2010, 01:19   #345
reds2
reds2's Avatar
Garage: 01' Anthracite Beast
ok. I replaced the exhaust CPS Bank 2. I am still getting code 72. Any ideas?
reds2 is offline   Reply With Quote
Old 1st March 2010, 07:39   #346
reds2
reds2's Avatar
Looks like I have a Vanos Solenoid issue. Anybody use Dr.Vanos to repair instead of replace?
Old 1st March 2010, 22:40   #347
GBPackerfan1963
Do a search on Dr. Vanos. There has been a few write-ups and positive comments.
Old 5th March 2010, 11:23   #348
czarmar
Garage: Empty Garage :(
I've been getting 90/91 Fuel Control codes. I'll occasionally see misfire during warmup on multiple cylinders. Car seems strong (no reference to what strong is or isn't) but has a 'lumpy' quality to the running at all engine speeds, esp. noticeable slightly lugging. I thought a bad cylinder or miss, but all sparks look normal, good compression, and no specific cylinder codes. I have some VANOS noises, but no codes for that. The last VANOS code was an exhaust CPS when I bought the car. Replaced it and no VANOS related codes since, although I do have the other three CPS's ready to be installed when I get a chance.
New sparks/MAFs/precat o2/fuel filter/air filters.
Any ideas?
czarmar is offline   Reply With Quote
Old 5th March 2010, 15:46   #349
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Mileage? Hose condition? What is your DavidS secret menu MAFS result?
chowdah is online now   Reply With Quote
Old 5th March 2010, 23:19   #350
czarmar
107K, replaced oil seperator hoses (top), haven't looked under the plenum, I had 135 L/H on both old and new MAFs (I bought new MAFs hoping for 145, but that didn't happen, and I'd say it drives about the same. I'll have to drive a car with bad MAFs sometime, because everyone comments on how new MAFs = new car)
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
