Knowledge base on Peake codes for E39 M5 - Page 28 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 9th June 2009, 07:26   #271
Polynova
Polynova's Avatar
Garage: M5, Silverstone
With the exhaust CPS replaced, all codes went away except for the following:
8F - E-Fan Box, and
AA (it did go away at the instance right after the CPS replacement, but came back again the next day, probably due to a cold start)
If the latter eventually disappears I would try to look into factors that could be the triggering magic. Wishful thinking but at least I don't have SES warnings to deal with.
Thanks again.
PolyNova
99/00 Silverstone
UUC short shifter; IATS
Eibach antisway bars; Bilstein PSS9 coilover;
SS brake lines; StopTech rotors; Axxis Ultimate pads
RE050A (stock size)
Hella HID lights, TPMS
Polynova is offline   Reply With Quote
Old 9th June 2009, 18:04   #272
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
There is a DIY e-box fan replacement post somewhere, though it's not the easiest thing to reach if I remember correctly.
chowdah is online now   Reply With Quote
The Following User Says Thank You to chowdah For This Useful Post:
Polynova (10th June 2009)
Old 9th June 2009, 19:25   #273
wilsodh
wilsodh's Avatar
8F - E-Fan Box, and
Sounds ominous. Do a few resets, and if you really do have full carbon occlusion of the SAS, you'll see the AA code come back every 2nd or 3rd cold start.
That's a drag!
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
The Following User Says Thank You to wilsodh For This Useful Post:
Old 11th June 2009, 21:55   #274
vixpix
Garage: 2000 M5 Titanium Silver
SES light on - codes 69, AE, AF
Hi - have a quick question on these codes.
Just recently replaced the MAF sensors and have driven approx 100 miles. Recently started the car (already warm after a short drive to my indy shop) and the SES came on. Just purchased a Peake today and am looking at:-
69 - Engine coolant temp - plausability
AE - Air-fuel adaption, bank 1
AF - Air-fuel adaption, bank 2
Could the new MAFS (Bosch) cause the AE & AF?
Not sure about 69...I had been driving slowly (under 45MPH) and the coolant level is normal.
The beast is a stock MY2000 with 71K miles
vixpix is offline   Reply With Quote
Old 12th June 2009, 22:43   #275
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
100mi seems like enough to let the DME adapt to new MAFS. You can run a "secret menu" test from member DavidS to confirm their performance.
AE and AF are not very specific. With all Peake codes, note them, reset them, and wait for them to come back (if at all). 69 is a pretty common code. Do a search with the error code words; "69" is too small for the search engine here.
Old 13th June 2009, 01:38   #276
vixpix
Thanks for the reply. I reset the codes today and will wait and see.
After I posted I found all of the thermostat related discussion on "69"
Monitored the K Temp yesterday and it never got above 78C...it was 75F outside and I drove it on the freeway and back roads. The temp needle never got to the 12 o'clock position always just to the left of center.
Old 13th June 2009, 06:07   #277
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
You mean "below" not "above," right? Typically it's easier to expose a worsening thermostat condition in colder ambient conditions. Your needle position is normal.
Old 13th June 2009, 19:40   #278
vixpix
It varied between 75C and 78C after warming up. I had read that it should be >79C for optimal coolant temp. Just wondering if this was enough to trigger the SES.
Old 22nd June 2009, 21:09   #279
Kleintje
Kleintje's Avatar
Garage: E39 M5 Dark Green
After my engine start shaking (cas was shaking from left to right (or other way arround)) I did some research;
18 Ignition Coil Cyl #4
54 Secondairy air control circuit
46 Misfire detected, catalyst damaging, Cyl #8
4A Misfire detected, catalyst damaging, Cyl #12 (12? Thought I had a V8)
71 Camshaft position sensor, Cyl #1-4
29 Air mass sensor
51 Secondary air system, cyl #5-8
39 Misfire, Cyl#2
4D Air contaiment valve, shrouded injectors, Cyl 5-8
D1 Misfire during warm-up, Cyl #5
D2 Knock sensor, Cyl 1-2
D3 Knock sensor, Cyl 3-4
D4 Knock sensor, Cyl 5-6
D5 Knock sensor, Cyl 6-8
95 Misfire w/empty fuel tack (tank?)
C8 Misfire w/fuel cutoff, Cyl #5
C9 Misfire w/fuel cutoff, Cyl #6
CA Fault code memory error
CC Idle speed increase -CAN Bus
CE Knock control test pulse
91 Fuel control, Cyl #4-6
It seems I'm reading also old errors.?
Before I put the car away (its in my garage sinds 16th of April) I did a hard reset on the car. I removed the battery and put the + and - cable together (not from the battery....but from the car). Sinds then I did a battery recovery and its on a slow (smart) charger...
Time for a new car?
Kleintje is offline   Reply With Quote
Old 22nd June 2009, 21:27   #280
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Only you can find out if they are old errors - by resetting the codes and seeing which return.
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
