Knowledge base on Peake codes for E39 M5 - Page 27 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 25th May 2009, 12:11   #261
arotished
Garage: BMW E39 M5 (Black)
Well, I also got the Code 50, switch-chain grip (sounds like vanos related) but no one has comfirmed what it is.
arotished is offline   Reply With Quote
Old 28th May 2009, 12:19   #262
Polynova
Polynova's Avatar
Garage: M5, Silverstone
Pervailing problems triggered by CPS?
For a while I have been having codes related to inlet and exhaust CPSs so I decided to change 'em once and for all.
However the following codes prevailed as they have been lingering around before the CPS replacement, although the order could be a bit different aside from the common start 8F: E-Box Fan
The newest reading shows the following:-
8F E-box-fan
AA secondary air system, flow too slow
0B Exhaust camshaft pos. sensor, cyl. 5-8
A2 crankshaft/camshalf pos. correlation, cyl. 5-8
D1, D3, D5 Misfiring during warm-up, Cyl 5, 7, multiple
I have replaced my MAFS at about 45,000 km (the car currently registers about 92,000 km) and it was running great for a few years until recently when it hesitates on WOT acceleration [uphill, from 2nd to 3rd]. The only other problem is the occasional inaccuracy in ambient temp readings at the start of the car that is self-corrected after a few minutes (-3 deg C in Hong Kong? ), probably due to a less than perfect IATS kit installation a couple of years back.
Any advice for me/my indy would be appreciated.
PolyNova
99/00 Silverstone
UUC short shifter; IATS
Eibach antisway bars; Bilstein PSS9 coilover;
SS brake lines; StopTech rotors; Axxis Ultimate pads
RE050A (stock size)
Hella HID lights, TPMS
Polynova is offline   Reply With Quote
Old 28th May 2009, 14:43   #263
chowdah
Super Moderator
Garage: sweetness
Sales Feedback: (4)
Pardon this, but I'm going to ask the obvious question first: did you reset (clear) the error codes after changing the CPS's? If you want to rule out the MAFS do member DavidS's test and look for ~130+ L/h.
chowdah is online now   Reply With Quote
Old 28th May 2009, 15:43   #264
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
8F E-box-fan
AA = Carbon Buildup. Get a Powerchip or go pay the dealer $5K to make it go away for a couple years. This code is completely unrelated to the CPS.
0B = You changed all 4 of your sensors? If so, then your next step is to change your driver's side solenoid, as the DME is getting a reading back telling it that the VANOS is not in the position the DME asked for.
A2 = This could be related to the above solenoid issue or could indicate a need for a new crankshaft position sensor. If you recently had clutch work it could also imply that the re-installation / adjustment process was improperly performed.
D1, D3, D5 = You need new plugs or new plasma boots. Start with plugs since they are cheaper
d-
DouglasABaker is offline   Reply With Quote
Old 29th May 2009, 01:29   #265
Polynova
Polynova's Avatar
Thanks for the reminder, I did routinely re-set the code reader every time after pulling the codes so that part is clear. I would conduct the MAFS test sometime following David's routine just to make sure though.
Old 29th May 2009, 01:59   #266
Polynova
Polynova's Avatar
d-
Many thanks for the timely advice as I am bringing my car for service today. Except for the CBU issue (the AA code has only appeared for about 6 months) your analysis relieves me as the problems, if eventually aggravated, can still be dealt with by replacing one or two wear-and-tear parts. The plugs were replaced 25,000 km (~ 15k miles) back and I need to double check the CPSs. In fact 3 of them were replaced in Jan while the 4th one (Bank 1 inlet CPS) was replaced 40,000 km (25k miles) back.
Time to go through the CBU threads.
Old 29th May 2009, 03:19   #267
Bimmertools
Company Representative for Bimmertools.com
Bimmertools's Avatar
Garage: BMW
Hi folks - just wanted to chime in here. We're a new sponsor, and Peake tools are one of our primary product lines. I have a lot of experience with the tools, as well as a close working relationship with Peake Research Corp. I am thrilled to see that so many members here are Peake tool owners and users.
I am, however, not a mechanic. As such, I'm not much use in helping diagnose or repair issues the Peake tools will reveal.
That said, PLEASE do not hesitate to contact me directly if you have any questions about the tools, warranty issues, or any Peake related concerns. Of course, you can email me about other things as well, but we can save that for another thread!
Finally, if you DON'T own a Peake tool, or are in need of one, you can see our full selection at bimmertools.com
My direct email is ken@bimmertools.com. I look forward to hearing from you!
Ken
Please Visit www.bimmertools.com
Please direct all questions to ken@bimmertools.com
Originally Posted by josephi - Bimmertools Customer View Post
I love this Peake tool. What a useful instrument for not just the DIY'er, but for any BMW owner who wants to know what's happening inside his engine.
Bimmertools is offline   Reply With Quote
The Following User Says Thank You to Bimmertools For This Useful Post:
Ted (29th May 2009)
Old 30th May 2009, 20:00   #268
wilsodh
wilsodh's Avatar
Not sure I'd worry about the CBU thing until -
1) the AA code appears in the absence of other codes
2) the AA code re-appears frequently
In my experience (both cars), the AA code is frequently a collateral code that trips when start up conditions are not normal. I have frequently seen the AA code 'bundled' with cps related codes. When I deal with the cps-related codes, the AA code magically disappears and doesn't come back.
The AA code trips when the ECU is not seeing the expected low voltage signal from the pre-cat O2 sensor during open loop (cold) start up. The ECU is expecting a low voltage signal due to the air being pumped into the exhaust. If the signal is above spec, a code is set. Presumably factors that can richen the mixture during start up can set an AA code. For example, if you have cold start misfires (which you seem to have), this could create a richer mixture than the ECU is expecting.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 31st May 2009, 15:26   #269
Polynova
Polynova's Avatar
Dave
Many thanks Dave for responding to my situation even after having written extensively on the issue of CBU which I read with interest and respect. As my car is a European version I did not have the trigger for the SES alarm regardless of the actual carbon build up issue so I do not have to attend to root cause of the AA code as a matter of urgency.
Interestingly the indy diagnosis still points toward a Bank 2 exhaust CPS problem so I am 'borrowing' one to check if my last replacement work in January '09 was not done properly. The AA code did first appear with only the CPS codes though without the cold-start misfires. Will revert with my finding in time when I eventually identify the cause (and fix it hopefully). Thanks again.
Old 1st June 2009, 17:50   #270
wilsodh
wilsodh's Avatar
I've observed AA bundled with cps-related in the absence of misfires on both my cars. It will be interesting to see another data point on this...when you cure the cps code(s), do the AA codes disappear also. Look forward to an update.
Dave
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
