Knowledge base on Peake codes for E39 M5 - Page 23 - BMW M5 Forum and M6 Forums
Like Tree4Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
Old 5th December 2008, 18:52   #221
Shakazulu12
Shakazulu12's Avatar
Garage: 2000 M5
Any ideas where I can get a CPS at a good price? I know there is a link somewhere in the threads that pull up on the search. We should have a sticky for places to get commonly used parts like MAF's and CPS sensors.
Shakazulu12 is offline   Reply With Quote
Old 5th December 2008, 21:11   #222
Shakazulu12
Garage: 2000 M5
Just to update my own response. I called the dealership. 115 bucks for a fuel filter, they had no idea on coil packs and CPS were 200 bucks a piece.
Emailed Chris at Dr. Vanos. CPS 100 bucks a piece, Coil packs 75 bucks a piece and the fuel filter was only 49. I should have got my MAF's from him as well.
Old 8th December 2008, 19:48   #223
wilsodh
wilsodh's Avatar
Originally Posted by IanS View Post
Maybe the other codes are side effects...
+1. Address the cps issue and you might be code-free. Secondary air code is a common 'collateral' code. Often these go bye-bye when cps issues are corrected.
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 10th January 2009, 03:35   #224
Ledfoot
Ledfoot's Avatar
Garage: '01 CB/Black M5
Code 69
SES three times in 7K miles, twice this week. Each code thrown is 69 - engine temp plausibility. Temp gauge rarely gets past the first dot and remains far left of center. Sensor or thermo stuck open? I haven't done the on-board temp test. I'm concerned, since I've read about how operating temp may be related to CBU.
Ledfoot is offline   Reply With Quote
Old 11th January 2009, 15:59   #225
wilsodh
wilsodh's Avatar
Sounds like a temp sensor on its last legs (giving 'implausible' readings).
D
Old 11th January 2009, 23:34   #226
vitacura
vitacura's Avatar
Garage: 2002 M5
I had the same code, I changed the temp sensor (About $40 at dealer) but it came back on. I had to replace my thermostat to get rid of the code.
vitacura is offline   Reply With Quote
Old 20th January 2009, 14:24   #227
jstein
Garage: 2000 M5 Black
I recently had an SES light come on and purchased a Peake reader from bimmerzone. Then a buddy gave me an old one he wasn't using any more, so now I have a spare.
The one I purchased is the "combo" tool which can handle the older under-the-hood OBD connector as well as the one under the dash (it comes with an adapter cable). It works fine and comes with the case and book.
Original cost was $169.90 about one month ago.
I'll sell it for $150 via paypal, includes shipping in the US.
Description from Bimmerzone (http://www.bimmerzone.com/resettool.htm#1)
R5/FCX3-U (Combo) Fault Code BMW Reset Tool (1987-2007 BMWs)
Reads trouble codes/Scans codes, resets Check-Engine, Oil service and Inspection:
The Combo includes the FCX 3 and the AB03 Adaptor
jstein is offline   Reply With Quote
Old 20th February 2009, 05:36   #228
D-RodM5
D-RodM5's Avatar
Garage: 2001 M5 Carbonschwarz Metallic
I too just got a Peake code reader, model R5/FCX3, and I'm having a hard time figuring out which table to look at with codes "1b"..."69"...and "d0" ...anyone find a proper solution for those? I'm assuming "1b" is the table to go to (since it came up first) and that 69 and d0 are the codes in question? d0 = misfire during warm up? How do you fix a misfire? Any help, guidance would be appreciated.
/// M5
Umnitza VXX
BeastPower Brackets
Schmiedmann Blck Chrm Grills
AFE Power Air Filters
XPEL Protection Film
StopTech ST-40
SlimmBones Finned Diffuser
CarbFib ACS-style Front Splitters
TimmayTips
Mesh Fog Housings
Style 65 275/35/18 x 4
Evolve Alpha-N
D-RodM5 is offline   Reply With Quote
Old 20th February 2009, 06:17   #229
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Table 18.
And as far as fixing a mis-fire, you generally just reset and see if it goes away. If it keeps recurring you typically need new plugs although there is a laundry list of other potential causes. In other words, don't worry about it.
d-
DouglasABaker is offline   Reply With Quote
Old 21st February 2009, 19:29   #230
D-RodM5
D-RodM5's Avatar
d,
thanks for your advice. i figured there was not much I could do for a misfire. thing is the engine does not sound like it's misfiring. i'm going to reset the SES light and see if it comes back like you said...if it does i'll have to drive to the twin cities for a fix from a dealer
d-rod
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 17:08
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 21:13
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29
