Can a loose battery connection lead to alternator failure? - BMW M5 Forum and M6 Forums
post #1 of 8 Old 10th July 2007, 11:47 AM Thread Starter
scoopz
Moderator Emeritus
scoopz's Avatar
[admins - this relates to my father's E39 530i not an M5 so please move elsewhere if neccessary]
Summary of story below:
Question - If a battery terminal is loose can it cause an alternator to fail?
Full story:
My dad's car went into the bodyshop to have one side completely resprayed. When he got it back he noticed the clock in the car was not set right and assumed they disconnected the battery for some reason.
A few days later, after no more than 40 miles, he ended up with a warning light on the dash, a battery icon, followed immediately by trans fail warning (it's an auto) and he lost all power on a very dangerous and fast stretch of road that had no hard-shoulder. He waited for recovery, whilst waiting the battery was so low that the hazard warning lights wouldn't work after 5 minutes use and he couldn't gain access to the trunk to get the warning triangle
The RAC recovery arrived and towed him to a safe location then set about trying to jump start him. He then noticed that the positive terminal on the battery was completely loose. He tightened it completely before attempting to jump the car. He then diagnosed that the alternator wasn't charging the battery.
The vehicle was then recovered to the local dealer (same chain as bodyshop that didn't reconnect the battery properly).
Diagnosis from BMW - the alternator has failed and it needs a new one (£600) and there's now way that could've been caused by a loose battery terminal according to them.
We asked for the exact problem with the alternator, they have just got back to me and said "something inside failed, we don't know what".
I did some quick Googling and found that a loose terminal could cause the alternator to run at 100% for a while or perhaps intermittent connection could make the alternator run on-off-on-off in rapid succession? If there is any evidence that a loose terminal could cause alternator failure please let me know so i can pass-the-buck when it comes to paying.
2005-12 E60 M5 :: Silverstone :: Silverstone Full Perforated
Delimited :: Twin rear screens + PS2 + DVD :: Origin B2+laser detect :: Pentagon Security Glass and most important of all a BMW Extended Warranty!
My Social Links :: @scoopz :: Blog :: YouTube :: G+
My Businesses :: Coopers Consulting Engineers :: C Inside Media - Google Street View Team
scoopz is offline
post #2 of 8 Old 10th July 2007, 04:53 PM
verhagke
verhagke's Avatar
Not sure, but I would think that if the alternator wasn't working when the car left the shop, the light would already have been on. At least a fair amount of time before the car stopped.
verhagke is offline
post #3 of 8 Old 10th July 2007, 05:19 PM
jclyman
In Memoriam
jclyman's Avatar
I have NEVER heard of that happening, BUT ... what Google said is correct as far as I know. Somewhere years ago, I read to never DISCONNECT the battery while the engine is running as it may "cook" the alternator circuitry, so it "could" happen on any car with an alternator ...
A body shop usually disconnects the battery while working on the cars (for safety reasons) ... but, normally they tighten the clamp when finished.
Since it isn't BMWs fault, you'll need to hit the body shop up for it though ...
- Daniel Boorstin
jclyman is offline
post #4 of 8 Old 10th July 2007, 05:43 PM
ard
Super Moderator
ard's Avatar
The intermittant connection can cause the internal voltage regulator to fail.
The shop is responsible for returning the car with a tightened battery connection.
Getting them to agree the alternator is their fault will be tough....
ard is offline
post #5 of 8 Old 10th July 2007, 05:59 PM Thread Starter
scoopz
Moderator Emeritus
scoopz's Avatar
Thanks for the comments guys.
I agree, but I wander if the alternator was operating ok but somehow bumps in the road etc made the battery connection jump on and off and fry some circuit in the alternator? Guess I'll never know now. How far would an automatic car drive without an operational alternator if for some reason no warnings appeared?
Sorry i may not have been clear on that, it WAS a BMW bodyshop at a BMW garage that did the respray and didn't reconnect the battery properly
I know, I thought as much. I was hoping there would be some well documented examples of situation similar to my own but guess not.
scoopz is offline
post #6 of 8 Old 10th July 2007, 06:04 PM
boostmiser
boostmiser's Avatar
Strange that the positive was loose. Generally you only need to remove the negative terminal.
I just got my car back from the body shop after two weeks. The battery was very weak and wouldn't hold a charge. I ended up buying a new one. Didn't think I had much lleverage for them to pick up the tab since it was 5 years old.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
post #7 of 8 Old 12th July 2007, 01:03 AM
M Cinco
M Cinco's Avatar
M Cinco is offline
post #8 of 8 Old 12th July 2007, 11:34 AM Thread Starter
scoopz
Moderator Emeritus
scoopz's Avatar
Thanks for the responses guys.
We've had the new alternator fitted now and just waiting to an independent report back on what caused it to fail. That way I'll hopefully know one one way or the other whether they were definitely to blame or not.
scoopz is offline
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 03:43 PM
Battery tender question.... leebro1 E39 M5 and E52 Z8 Discussion 27 12th April 2007 09:08 PM
Interstate MTP-93 Replacement Battery - check your installation greg E39 M5 and E52 Z8 Discussion 2 9th September 2006 12:10 AM
Weak battery kalvin E39 M5 and E52 Z8 Discussion 43 15th December 2005 07:44 PM
