So I tried to search, but think it might be faster to ask here:
1. When in reverse or just pulling out in 1st gear, the car seems to tremble a little - as if I'm not giving it enough power, but enough is applied. This only happens when starting from cold. Thoughts? Opinions? Normal?
2. Second gear and generally all gears are pretty stiff to engage. Much stiffer than my M3/4 and nowhere near as easy as most M3 E46s I've driven. Clutch replaced at 45K and seems to be fine (accelerates fine in 6th from 1K).
Normal? I think it is...
3. At all speeds accept 75, the car is perfectly smooth, stiff, but smooth.
At 75, there is a shimmy. Steering stays without moving at all. Seems to be coming from the rear. Thinking it's out of balance wheels/tires or a bent rim. But could be other things? Anyone experience this?
4. Goodyear Eagle GSD3 on the car, loved them on my M3/4 - what other tires are people using? Kumho? Michelin? Bridgestone? Etc.
5. Coolant Temp Needle never really hits center unless I was in stop and go rush hour traffic in 90+ degree weather. It is always left of center. The oil temp usually sits at just left of bottom center, but will drift to center in heavy driving. Normal I presume.
Final comment:
wow. simply wow
