Old 24th June 2007, 23:24   #1
Michael_s
Michael_s's Avatar
Garage: 2007 M5
Sorry... MKIII to MKIV Question
First, let me say that I searched this forum, FAQ section, bimmernav and even sent a PM to a member who did the upgrade..... Please try not to flame too much .
Here's my question..... I have a 6/2002 production car. I would like to upgrade to MKIV..... Is it straight plug and play or does my production month/year have the trimble (sp?) where I have to get the antenna wire from behind the DSP requiring the removal of the CD changer, DSP, etc.???
Thanks in advance.
2007 M5
2007 Range Rover Sport SC
Michael_s is online now
Old 24th June 2007, 23:47   #2
erkan666
erkan666's Avatar
Garage: M5 E39 Carbon Black
the question is which version you have now? mkII or III
if it is mkIII it should be plug and play. as far as i know your pruduction year should be mk III, so it should bevery easy to install.
erkan666 is offline
Old 24th June 2007, 23:57   #3
Michael_s
Michael_s's Avatar
Garage: 2007 M5
I think I have III based upon the build date. How can I tell for sure? I just looked at the "brain" in the trunk and it does not say it on the face or on top......
Old 25th June 2007, 00:04   #4
erkan666
erkan666's Avatar
take a picture and post it here.
erkan666 is offline
Old 25th June 2007, 00:11   #5
red_wings05
red_wings05's Avatar
Garage: BMW M5 Carbonblack 2000, just sold.
Send a message via ICQ to red_wings05 Send a message via MSN to red_wings05
Go to the Setup, in the top-right corner there will be two numbers showing, e.g. 3/61. The first number tellls you what MK you have.
red_wings05 is offline
Old 25th June 2007, 00:20   #6
Michael_s
Michael_s's Avatar
Garage: 2007 M5
Just checked..... 3 - 1/50. So I guess this confirms I have MKIII.
Old 25th June 2007, 00:27   #7
MGZ
MGZ's Avatar
Garage: M5 e39 Carbon Black
Sales Feedback: (3)
I have a 2002/6 as well (made on the 5th of June 2002) it had a Mk III which I have upgraded to the Mk IV.
Just plug and play. A good tool is a bicycle spoke.
MGZ is offline
Old 25th June 2007, 00:32   #8
Michael_s
Michael_s's Avatar
Garage: 2007 M5
Thanks for the input. Just so I am very clear, you did not have to locate the antenna wire from behind the dsp? thanks.
Old 25th June 2007, 05:27   #9
mz3stelios
Garage: m5 e 39 carbon swartz m3 e46 titanium silver
from mk2 to mk4 you need only to buy antena for you gps (aftermarket ist ok)
from mk3 to mk4 its jast plag and play
its apsolutly the same fuse in back side
mz3stelios is offline
Old 25th June 2007, 07:57   #10
jerbro
jerbro's Avatar
Garage: 1999 540i / 6 Titanium Silver
I'm not sure you're right about that, as I had to do no such thing from my mk2 to mk4 upgrade.
There is a separate gps receiver module for the mk2, that has an antennae wire going to it. When you move to the mk4, you no longer need the gps receiver module as it's built into the mk4 - you then just plug the antennae wire that used to be plugged into the gps receiver module directly into the mk4 unit.
Cheers
jerbro is offline
Another MKIV Nav question ICE99M3 E39 M5 and E52 Z8 Discussion 8 26th November 2006 02:15
upgrading from mkIII to MKIV navigation lore E39 M5 and E52 Z8 Discussion 9 30th April 2005 03:02
why are there so many different MKIV part numbers? lore E39 M5 and E52 Z8 Discussion 3 29th April 2005 01:49
Just upgraded to MKIV nav, great new features and speed, MKIII available Redshift E39 M5 and E52 Z8 Discussion 13 5th November 2004 18:03
Sat Nav upgrade MkIII/ MkIV M5SHEFFIELD M5 E39 and E60 tips & tricks 0 16th September 2004 19:18
Page generated in 0.13830 seconds with 11 queries
