Old 23rd June 2007, 05:08   #1
Vason
Vason's Avatar
Garage: '03 M5 - Carbon Black/Caramel
Sales Feedback: (4)
Troubleshooting rear footwells soaked with water?
So here is the problem. My car is always garaged at work and at home so it rarely sees bad weather. I was out of town for two weeks and my car was outside the entire time. A huge thunderstorm came through the night and the next day I find that the rear footwell carpets are soaked with water, mainly the driver side. Nothing else in my car seems to have gotten wet. Any ideas on what to do about this and what defect is letting water in? Thanks...
'03 M5 Carbon Black/Caramel
'03 M3 Alpine White/Black - Flooded/R.I.P.
Vason is offline
Old 23rd June 2007, 05:36   #2
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
A number of us (myself included) have had that issue. A search will probably turn up some useful info but IIRC there was no definitive answer or fix.
BKH is offline
Old 23rd June 2007, 05:39   #3
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
Check to see that your door drain holes aren't blocked, then Check the vapour seals (I think that is what they are called), behind the door cards, a liner that helps to run the water down inside the door and out the drain holes.
There is a detailed post on here somewhere (I think by louv) about removing the door cards (caution re airbags is present and active), and repairing the seals.
I had my rear passenger side seal repaired (dealer said there was a small split in it) and problem is gone.
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline
Old 23rd June 2007, 05:40   #4
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
It's probably a leaking vapor barrier in the door. Mine did that also a while back and the dealer fixed it under warranty. If you want a DIY:
http://www.louv.tv/cars/m5/leakydoor/leakydoor.html
Thanks to member Louv for his info.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 24th June 2007, 09:27   #5
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Any chance you had a window regulator repaired in that door?
As the above posters have indicated, you likely have a bad vapor barrier seal on that door. I just fixed (I hope!) mine yesterday. Really nothing to it - see the link provided previously...
d-
DouglasABaker is offline
Old 25th June 2007, 10:06   #6
louv
louv's Avatar
Garage: '00 M5 Carbon Black / Caramel
The seals can fail even if no door repairs have been done. I had both rear door seals fail, and no one had ever taken the rear doors apart. But, as mentioned by Douglas, if anyone has been inside the door (like for window regulator repairs) then the likelihood of failure is very high if they didn't use new sealant when putting it all back together.
Be very careful to carefully clean off all the old sealant, and carefully apply the new to get a good quality seal.
(oh, and don't fire a nailgun through the airbag... but that part's probably obvious)
1989 750iL sadly ignored, but still runs great
2000 M5 117,000 miles
2001 Tundra Hauls Stuff
2008 Z4 M Coupe On the cover of Oct. '08 Roundel
2008 Mercedes C350 Sport wifey's car
2009 BMW R1200GS-Adv for on & off-road
louv is offline
Old 26th June 2007, 00:42   #7
suprfknman
suprfknman's Avatar
Garage: 2001 BMW M5 BLACK
The metal trim along where the door meets the window can come loose and water get in there. It is only held on by friction. I took mine off and used a little caulk where it sits to hold it on and have not had a problem since.
Will
01 BLK/BLK
05 Toyota Sequoia (for the winter)
04 S55 AMG
05 S4 Cab
91 JZA70 twin turbo supra RHD
suprfknman is offline
Old 26th June 2007, 01:50   #8
alantd
alantd's Avatar
Garage: 09/02 E39 M5; Carbon Black; Stock
Common (mine is in next week to try and resolve this).
Most likely candidates are the door seals not allowing proper drainage and sunroof gutters. You should be able to tell which by inspecting as you open the door.
If it is the seals, you'll open the door and a load of water will gush out the bottom of it.
The sunroof gutters connect to pipes, which run across the roof lining and down the rear pillars (I seem to recall). If these get disconnected, the water will find its way down the side of the rear seat, under the rear seat cushion and end up in the footwells. If the vertical carpet panel from the footwell to the rear seat is as wet as the footwell, it'll likely be the gutters.
I recall some people have reproduced the problem when washing the car. Mine's never been quite that bad. A search should turn up some relevant threads.
02 Carbon Black Stock
05 Land Rover Defender
alantd is offline
Old 26th June 2007, 23:16   #9
DanQ
DanQ's Avatar
Garage: E39 M5 blue
What's the source of the problem?
I've got the same wet rear floor mats after a hard rain too. "To me" the source of the problem is the door holding water until you open it and it drains out. If the door fills up with water until it pours past the vapor barrier, I can't really blame the vapor barrier for being a poor fish tank!
I need to look at what blocks the door drain when the door is closed, because it is obviously clear when the door is open. Water pours out easily, so the drain is NOT plugged inside the door. Does the weather strip (door gasket) block the drain? I'll look more this weekend. I'll reseal the the vapor barrier while I look.
Seems like resealing the vapor barrier is a work around and not the real fix.
Comments?
Dan
DanQ is offline
Old 27th June 2007, 01:02   #10
DouglasABaker
Actually, if I understand the design intent (which I may not since I'm trying to figure it out after the fact), the "vapor barrier" is actually a waterproof seal that is designed to channel the water to front of the door for drainage.
In fact, if you look closely at the bottom of the door, the holes where the interior trim attaches using the push clips are below the vapor barrier. If the issue were the door filling with water and overflowing, the vapor barrier wouldn't matter.
Based on my investigation this last week, the design is that water runs down the inside of the door (on both the inside of the outer door skin, the outside of the inner door frame and down the vapor barrier), hits the bottom, and channels to the front of the door to drain.
The issue in my car, as backtraced immediately after a light rain that left water in my footwell, is that the vapor barrier was not sealed, and therefore water running down the inside of it was then running down the inside of the inner door frame where is got trapped by the door seals.
So, to answer your question, I believe resealing the vapor barrier completely should resolve the issue since water would then be prevented from running into the interior of the car.
The key observation is that the holes for the plastic trim attachments would leak long before water reached the vapor barrier by filling the door, so I can't see how that is the issue with leakage...
Doug
rattle/knock noise from rear solved! Jacob Lee E39 M5 and E52 Z8 Discussion 4 14th April 2009 21:08
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 16:43
UPDATE: DINAN 3.45 rear diff. GROUP BUY info/details............... FAST 5 E39 M5 and E52 Z8 Discussion 15 23rd October 2003 05:51
Shark Injector for E46 M3 pride355 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 14 11th June 2003 08:47
Page generated in 0.19508 seconds with 12 queries
