Old 23rd June 2007, 05:07   #1
Jeff M5 KNinja
Garage: 2002 M5 Black
Installing one new tire?
Just had a flat and the tire shop only put on one new rear tire. My right rear tire has a little over 3mm tread left (eyeball measurement) and my left is new at 4mm. Is that ok?
2002 M5 [ present & forever ] [ pictures here, pg 4 ]
2003 Kawasaki Ninja 5 [ daily ride ]
1998 Mazda MX-5 [ track weapon ]
------ past ------
2000 Audi TT Quattro [ track machine ] [ 100 shot nitrous ]
1996 Sebring Convertable [ college mini parades ]
1981 Honda Accord [ teen top speed 120 mph ]
1981 BMW 733i [ teen jealousy machine ]
1994 BMX 18 Speed [ top speed 30 mph ]
Jeff M5 KNinja is offline
Old 23rd June 2007, 07:57   #2
ard
ard's Avatar
No, you'll have to take that 75% michelin PS2 and give it to me just to be safe. I'll take all the risk.
It's fine. Just a PITA to track wear now. Be particularly careful when it starts raining again- the worn one should be pretty low by then (depending on your usage).
A
ard is offline
Old 23rd June 2007, 08:07   #3
Anita
Anita's Avatar
Garage: 02 M5 TiSi
I also have a new tire on the front passenger side. I have Kuhmos and the one got corded. So, while decidiing what tires to get next, I just replaced the one (with a different model Kuhmo). That was maybe a month ago. The only thing I noticed was maybe a bit more tire noise coming from that area of my car?
Anita is offline
Old 23rd June 2007, 13:52   #4
jclyman
jclyman's Avatar
Also, if you replace the worn tire, what's to keep you from having another flat? If you decide to replace, I would keep the old tire, just in case.
- Daniel Boorstin
jclyman is online now
Old 23rd June 2007, 15:31   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Excellent advice. And if you replace a set of tires, keep the best take off as a spare, just in case.
gsfent is offline
Tire pressure question: Summer pressure vs. Winter pressure tripleD E39 M5 and E52 Z8 Discussion 3 13th June 2007 02:29
Help! Need info for Alignment unusual tire wear? mruiz0280 E39 M5 and E52 Z8 Discussion 4 13th June 2006 02:30
RunFlat Tires for the Beast??? 04ImolaZHP E39 M5 and E52 Z8 Discussion 29 4th May 2006 18:06
Real time tire pressures... Nolift911 E39 M5 and E52 Z8 Discussion 6 21st August 2004 17:27
Page generated in 0.10033 seconds with 11 queries
